Question about Toro Garden
Rear Self New drive belt was replaced but still seems to be slipping-You can push it faster than it want to go- even in third gear
    Problem Solver:
  • 10 Answers
Check to make sure tensioner is traveling all the way. check to make sure drive pulleys aren't slipping on shaft... or if all else fails get a smaller belt lol good luck
Posted on May 01, 2014
  • 21 Answers
SOURCE: Troy Mower Belt Slippage
If you have an tension adjuster on the handle loosen up until you can slip it back on. If thats not enough remove the spring at the tranmission.
Posted on Jun 21, 2009
harlan301
  • 205 Answers
SOURCE: drive belts slipping
on the top of the trany there should be a screw tighten in down. if there isn't one you my have ether a bad cable or belt.you might want to look at the engine pulley assay make sure the belt did'nt ride up over the pulley, we see that all the time in my shop.
Posted on Oct 14, 2009
  • 80 Answers
SOURCE: ned a rear wheel replaced on self-propelled push
look on craftsmans website and see it they have the wheel or look on partstree.com and they might have it!! have fun!! :)
Posted on Apr 02, 2010
vincob
  • 718 Answers
SOURCE: the front wheel drive is slipping - seems to be
Go to psep.biz and you find what you need if uncomfortable with that site, try Toro site but they will b more expensive. Good Luck...
Posted on Apr 19, 2011
  • 6468 Answers
SOURCE: how to replace drive belt on self propelled toro commercial push mower
the should be a plastic cover under the engine
Posted on Mar 29, 2012
Why does my husqvarna running slow
Try changing the drive belt, even a slight slip on the belt will appear as a loss of power.
Aug 11, 2014 | Husqvarna Garden
I have a 1987 Toro GTS Self propelled walk behind mower- My question is that it runs fine but but seems to be slippling and can't get out of it's own way
  • Check for belt stretching even if it looks good. Next possibility
Is worn smooth, or oily surfaces on drive wheels. Can you tell if it slips on drive wheel, or those driven. Some Hondas have belt tensioners which can be too loose. See if axle on drive wheel is in a slotted, rather than round whole, meaning you could loosen/retighten while putting pressure on it to lengthen distance to driven wheels.
Apr 01, 2014 | Toro Garden
I have Model YTH2548 riding mower. The RPM's are set as high as they will go but the mower moves along very slowly. Could the drive belt be slipping? Is there a tensioner pully that may need to be...
When you raise the front or rear of the tractor, and push on the belt (engine off of course), is there a lot of play or slack in the drive belt. At this point from what I have read, the issue is the drive belt, and is slipping when in gear and when it heats up. The next thing to do would be to replace the belt, but I not sure if this procedure is an option for you. When you inspect the under side of the tractor, and inspect the moving parts and pulleys, if any of these components are in need of replacement, you will be able to tell by either rotating them manually or visually inspecting them. At this point due to the low hours, I suspect the drive belt is stretched out, and is considered a maintenance replacement part procedure.
Jan 20, 2011 | Husqvarna Lawn Tractor 48" Deck, 23 Hp,...
Self propelled JS63 Deere Lawn Mower Transmission is driving axle but rear wheels act like they are slipping. It seems like gears on end of axle are not engaging the drive gear on the inside hub of...
some times you can add a thin shim to the out side of the wheel mounting center to push the wheel gentally a little more to the drive gear for more positive engagement to the wheels inside gearing, also check your gear drive mounting pins/ keys for wear if thier warn it will engage the end of the drive shaft iradically appearing as slipping type movment at the wheel hope this Helps Steve
Aug 01, 2010 | Garden
Super Bronce is Jerking while going forward
your bevel gear forward my be out or you input shaft gear my be slipping. check your vauble drive pully sys make sure your bearing are not bad and you may check your belt to see if you have flat spots. if you have a lot greas your seals are out axles. ther are no gaskets used on this trany body. sealint only
Oct 03, 2009 | Troy Bilt 5.5hp Self Propelled Mower
Craftsman front wheel self-propelled, push mower: belt keeps slipping off tension pin. Also, the wheels don't rotate as rapidly as when I first bought it last year.
Make sure the pulleys are aligned perfectly straight and replace the old belt with a new one. The pulleys have an allan head set screw you need to loosen to adjust the pulley.
May 03, 2009 | Garden
Belt seems to be slipping
good evening. I would suggest checking the tine bearings as well alignment. I had (have) a 2003 mtd rear tine which blew the entire bearing box for the second time. The times should have little to no flex when push or pulled. Fortunately, MTD came good for the first rebuild even though my warranty had expired...they covered the parts and labour was all mine. If the tines seem properly working, possibly try out this website to get the 100% correct belt....hope this helps.
http://www.milacalawn.com/parts.asp
Apr 17, 2009 | Troy Bilt, Tuffy, Rear - Tine Tiller, 4.0...
Garden Logo
20 people viewed this question
Top Toro Garden Experts
Joseph Mueller
Joseph Mueller
Mike Squire
Roland W VanLue
Roland W VanLue
Are you a Toro Garden Expert? Answer questions, earn points and help others
