Question about 3M Office Equipment & Supplies
Need to know what kind of printers can print on apollo transpency
Need to know what kind of printers to use for the transpency paper
SOURCE: printer will not print
same with me
Posted on Mar 03, 2008
SOURCE: Apollo 2600 printer installed ok, but wont print
I don't believe Vista is compatible with Apollo any more. I know OS XP will work
Posted on Mar 17, 2008
sugarfree
  • 31 Answers
SOURCE: driver for apollo p-2150u in xp windows
Check this link frfom printer-drivers.com
http://www.printer-drivers.com/drivers/80/80788.htm
Posted on Jun 16, 2008
SOURCE: DELL 962 PRINTER. WHILE PRINTING PAPER GOT JAM.
Paper was got stuck in the roller. Removed the paper and tested printer working fone.
Posted on Sep 18, 2008
  • 105 Answers
SOURCE: I need your help please.
Make sure you are using the paper that come under the specifications of the printer (102 x 153 mm (4 x 6 inches) for a Photo Paper). Though you are using the correct paper and you are getting the same message, then just set the paper type as "Plain" and try to print from the photo paper. It works in most of the cases
gud luck
Posted on Oct 26, 2008
I want to use photo paper to print photos and the printer tells me I do not have the correct paper
When you give a print command (ctrl + P) You have the possibility to select the Print Properties. If you press that button, there has to be somewhere a possibility to select the right kind of paper. I don't know which kind of printer you have. This works well with inkjet printers. The settings in your driver has to match the paper you use.
If you have a dye sublimation printer (there is no ink, but a ribbon with coloured dye) you need the right brand of paper, because otherwise your printer doesn't detect the paper.
Jul 03, 2011 | Office Equipment & Supplies
I am trying to print but seems to be out of ink because the labels are coming out blank. There is nothing in manual about print heads or ink. I am thinking I need to replace something and I don't know what...
LP2824 is a direct termical printer, does not use ink of any kind, it means that it requires a special paper for it to print, printhead burns the special paper in specific areas to show the pattern, if you are sure that you are using that special paper and it keeps not printing, is very posible that the printhead need to be clean up or replaced.
Mar 12, 2011 | Zebra Printhead for LP2824
When I begin to print a document, the printer will print, but as it gets fed through, it wrinkles the paper and eventually will paper jam. How do I fix this?
Kindly let me know if the printer is under warranty if its then needs a service as the paper rollers needs to be serviced basically clean.
Jan 13, 2010 | Dell 1110 Laser Printer
After I print a few on a good quality paper the print is smurred and gets worst as it prints could it be my fuser
first check if the media(paper) you used are correct in the printer drivers, HP for each kind of paper quality, have diferent speed to cross the fuser, when de printer are new, the fuser are good and dont need change that, but before 10 months you need say to the printer what kind of paper are used.
If your paper are from more tha 20 lbs, used the paper say heavy paper.
If after you check this and dont correct, probably 70% are the fuser.
Aug 07, 2009 | HP Color LaserJet 2600n Printer
Epson Lx300+ printing problem
hi
pls check printer test print
  1. switch off the printer .
  2. insert paper in printer
  3. hold the button ll/ff pressing .
  4. switch on the printer
if you get test print OK then. you need to be Reinstall Printer Drivers on your Pc
May 22, 2008 | Epson LX-300 Matrix Printer
Reg. Installation of Apollo P-1200 Printer on Windows XP
This driver is provided by Microsoft and is included with the Windows XP os.
Installation instructions:
1: Click START, then click on PRINTERS & FAXES
2: Click on ADD A PRINTER
3: At Welcome screen click NEXT
4: Select LOCAL PRINTER (if printer is attached directly to computer) and click NEXT
5: Choose LPT1 (in most situations) or a different port if not LPT1 then click NEXT
6: Select Apollo in left window
7: Select Apollo P-1200 in right window
8: Click NEXT
9: Type name for printer or accept default name
10: Click No to "Do you want to print test page".
11: Click FINISH
12: Test printer by sending a print job to printer.
If you experience problems after installing this driver, please consultthe printer user manual for proper lpt bios settings. eg: spp, ecp,etc. and change the lpt pc bios settings to match manufacturer'ssuggested settings. quote.gif Jerry K View Public Profile Send a private message to Jerry K Find all posts by Jerry K reply.gif
Mar 04, 2008 | Pitney Bowes Hewlett Packard HRK-300 Black...
Jan 30, 2008 | HP Apollo P2600U InkJet Printer
Problem on printing on a thermal paper (Fax Roll Paper)
i have not drivers of samsung ML1610-XSG laser printer
Jan 02, 2008 | Samsung ML 1610 Laser Printer
Printer Is Not Printuot
I can solve it through instructions my email is syedimran555@yahoo.com.
Nov 07, 2007 | HP LaserJet 2200dn Printer
60 people viewed this question
Top 3M Office Equipment & Supplies Experts
Lampdeng.com
Lampdeng.com
Electro Med Services...
Are you a 3M Office Equipment and Supply Expert? Answer questions, earn points and help others
