Question about Olevia LT42HVi 42 in. LCD Television
How do you remove the base from 42 INCH OLEVIA
On my tv (42 inch) there are sixteen screws on the middle set up in four rows of four each. these are about two or three inches long.
take these out and the base comes off.
hope this helps.
Posted on Aug 04, 2009
SOURCE: removing the base on a tv
There are 5 screws on the back of the TV under the inputs in an x pattern:
X X
X
X X
Remove these and set aside. You should also see 2 screws on either side of the X pattern, loosen these. You should then be able to slide the TV off the base. Remember to re-tighten the loosened screws. Place the removed screws in the base in case you ever wish to use it in the future.
Posted on Dec 02, 2008
SOURCE: How to Remove the Base
The 2 screws on each side directly above the stand legs need to be removed. You do not need to remove the big plastic back panel. Remember the TV is heavy, the screws are under pressure and when the screws are removed the TV will drop. I suggest 3 people, 1 to remove the screws and 2 to hold up each side during and after the screws are removed.
If you want to remove the speakers, just disconnect the wires at the TV source, & remove top 2 screws from the brackets on each side of the centerline. Lower the speakers & rotate the bottom forward & out the front.
Posted on Jan 06, 2008
SOURCE: Red spots on Olevia TV
pixels are bad/going dead. look up dead pixel issue on PSP for really good explanations, or just trust me.
Posted on Mar 31, 2008
SOURCE: trying to take the base off my son's 42 inch olevia 542-b12
There are 16 phillips head screws on the back of the TV above the base, remove all of them and the base just falls out.
Posted on Jan 26, 2009
  • 93 Answers
SOURCE: Year old 42 inch Olevia 1080p won't turn on...
Sounds like you need to download the latest update, unfortunately Olevia went bankrupt and doesn't answer the phone. If I find out anything that is being done to correct the situation, I post it
Posted on Sep 17, 2009
Hi, My Olevia 42 inch, model342-B11, has a problem with its picture. At first I had vertical lines running down the screen, then it turned into small squares. What do you think is wrong with it?
Parts are hard or impossible to find for this brand but it sounds like the "main" board which processes all signal in and out of the display.
Apr 30, 2012 | Olevia 742I 42 in. LCD TV
My RC LTL remote control has quit working.
Try website like Remotes.com to buy an exact original or compatible remote.
May 26, 2010 | Olevia 742I 42 in. LCD TV
My Olevia 42 inch wont turn on the blue light isnt even on, The TV is only 2 yrs old
Mine had the same problem. You simply remove the dozen or so screws on the back and pop the back off. If you follow where the power cord goes into the tv and trace the wires you will see a small fuse. I believe it was a 5amp and cost less than a buck. I'm not sure why mine blew but I have had no issues since.
Dec 29, 2009 | Olevia LT42HVi 42 in. LCD Television
Sep 17, 2009 | Olevia LT42HVi 42 in. LCD Television
Remove base from tv?
How many screws did you remove? You should have eight, there are 2 screws along the bottom that are easy to miss. Make sure you check each hole with a flashlight just to make sure you got them all.
Jan 03, 2009 | Olevia LT42HVi 42 in. LCD Television
Trying to take the base off my son's 42 inch olevia 542-b12
Dec 31, 2008 | Westinghouse LTV-40w1 HDC 40.02 in. LCD...
Olevia 42'' flat screen TV
I'm looking for a logic board for a olevia 540i 42 inch
Nov 13, 2008 | Olevia MN-20LCDTV-SN 20 in. EDTV-Ready...
Dec 22, 2007 | Olevia LT42HVi 42 in. LCD Television
I have an Olevia 42" TV. I was able to remove the base by removing 16 screws on the back side. They were arranged vertically in 4 sets of 4. The screws go through the back panel, through the base and attach (without nuts) directly into the inside of the TV. After removing the 16 screws the stand simply slides out.
I tried removing two screws underneath the base area. They were small screws and were a pain to remove. I thought I would try that first instead of removing 16 screws but that did nothing.
Dec 10, 2007 | Olevia LT42HVi 42 in. LCD Television
Olevia LT42HVi 42 in. LCD Television Logo
388 people viewed this question
Top Olevia Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Jaime Hernandez
Are you an Olevia Televison and Video Expert? Answer questions, earn points and help others
