Question about Mitsubishi WS-55511 55" Rear Projection Television
Same problem powers on for a couple of seconds
Then shuts off. I am getting the 2 blink code. What does that mean?
  • abemc23 Jun 15, 2009
    What bdoes the overcurrent shutdown mean . Is it expensive to fix
  • 126 Answers
If the code is two blinks short pause two blinks long pause then repeats then over 95% of the time it's because the convergence output IC's need to be replaced as they are drawing too much current. A 2-2 code means overcurrent shutdown.
Posted on Jun 15, 2009
  • hatman1 Jun 16, 2009
    The microprocessor in the set is detecting too much current draw. As I said most of the time it is because of bad convergence output IC's. They need to be replaced. Depending on where you live the average repair by a reputable shop runs between $200 and $300.
Push power button and it stays on for a couple seconds and then shuts back off. No picture comes on. Thank you Jeanette
To determine what your problem is:
UNPLUG TV ANDTHEN PLUG BACK IN---TURNON---GREEN POWER LIGHT COMES ON FOR A MOMENT ANDGOES OFF.
PRESS AND HOLD "device" and "menu"buttons on front of tv for at least 5 seconds and then release both together.
Watch for power light to blink in a sequence:
1 blink-then 2 blinks-------no error
2 blink-then 1 blink-------X-ray protection
2 blink-then 2 blink-------SHORT PROTECTION*******
2 blink-then 3 blink---------deflection circuit problem
2 blink-then 4 blink---------vertical circuit problem
******2, then 2 is most common---usually means one of the fuses that protectthe Convergence IC or IC's is blown---set will detect no voltage to convergenceIC and shut down.
SET WILL REPEAT BLINK ERROR CODE UP TO 5 TIMES ANDTHEN TO GET IT TO REPEAT MORE YOUHAVE TO UNPLUG SET AND TRY TO TURN ON AGAIN.
IF IT IS 2 AND THEN 2---USUALLY
CONVERGENCE CIRCUIT PROBLEM
let me know what you find--hope that you find 2 blinks, a pause and twoblinks--this is the most common and easiest to fix.
Let me know
SDTECH
Jul 29, 2011 | Mitsubishi WS-65819 TV
Tip
Mitusbishi shuts off instantly...
Most of the Mitsubishi rear projection sets made from about 2000 through 2006 have a self diagnostic check feature. It will indicate if there is a error or not and point you in the direction of your trouble.
Based on the error code I or others can tell you more based on the error code and the EXACT model number of the set.
Here is what you do if it turns on for a few seconds and then the power light goes off.
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} UNPLUG TV AND THEN PLUG BACK IN---TURN ON---GREEN POWER LIGHT COMES ON FOR A MOMENT AND GOES OFF.
PRESS AND HOLD “Menu and Input"(or device) buttons on front of tv for at least 5 seconds and then release both together.
******2, then 2 is most common---usually means one of the fuses that protect the Convergence IC or IC’s is blown---set will detect no voltage to convergence IC and shut down.
SET WILL REPEAT BLINK ERROR CODE UP TO 5 TIMES AND THEN TO GET IT TO REPEAT MORE YOU HAVE TO UNPLUG SET AND TRY TO TURN ON AGAIN.
If someone has one of these codes and needs help let me know.
SD TECH
on Dec 02, 2009 | Televison & Video
Screen went black. Shut t.v. off and tried to turn it back on. Power comes on, front light is green, and in about 3 seconds the t.v. shuts off, green light goes off. Was playing dvd at the time. Shut off...
MOST OF THESE SETS HAVE A SELF DIAGNOSTIC:
UNPLUG TV AND THEN PLUG BACK IN---TURN ON---GREEN POWER LIGHT COMES ONFOR A MOMENT AND GOES OFF.
let me know what you find--hope that you find 2 blinks, a pause and twoblinks--this is the most common and easiest to fix. SD TECH
Jul 15, 2011 | Mitsubishi WS-55819 55" Rear Projection...
When I turn the tv on the power light goes green for a couple of seconds then it shuts off and the picture never comes up.
Mitsubishi self check: MOST OF THESE SETS HAVE A SELF DIAGNOSTIC:
Jun 03, 2011 | Mitsubishi WS-65315 65" Rear Projection...
I have a 65611 Big Screen TV. The TV shut itself off. Pressed the reset button, It flashes green then off. Pressed power again and it just shuts off. Unplugged the tv and replugged. Have a power strip...
Hello it looks like you a problem with your main board, maybe a horizanal deflection. you can get the problem by run troubleshoot codes, first hold the buttons mune and input or device until starts blinking account the blinks, it will blink few times and the it will pause for a second again will blink. get blinking number like, 2 the 2, or 2 then3. that means 22 or 23. 22 means convergance problems. feel free to call me if you need more help with your tv. 602-810-7149 i live in mesa az
Dec 31, 2010 | Mitsubishi WS-65611 65" Rear Projection...
When I turn the tv on, either manually or by remote, the power stays on for just seconds then shuts itself off.
hello my is rico, check your lamp, lamp cover, fans. second power on the tv when it shuts off itself hold buttons menu and input or device, it will start blinking , it will blink 1 or 2 and then its gone pause for a second andthen will start blinking again count the blinks like, 2,3 -2,2 it means code 23 or 22 and then needs call misubishi for the codes means. if you need more feel free to call at 602-810-7149 at anytime i live in mesa az
Dec 30, 2010 | Mitsubishi WD-57733 57" HDTV
Turns on for a couple seconds and immediately turns itself off.
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} MOST OF THESE SETS HAVE A SELF DIAGNOSTIC:
PRESS AND HOLD “device” and “menu” buttons on front of tv for at least 5 seconds and then release both together.
Let me know what you find and I will tell you what I know.
SD TECH
May 10, 2010 | Mitsubishi WT-42313 42" Rear Projection...
In my WS 65809 projector tv, when I turn on the power, the green light clicks on for a couple of seconds, then clicks right back off.
DO THIS AND LET ME KNOW WHAT YOU FIND:
If this information has helped you rate this solution as I do this here for free.
SD TECH
Dec 06, 2009 | Mitsubishi WS-65809 65" Rear Projection...
Mitzubishi projection tv power shut down and won't power back up. green light comes on for a second then it shuts down immeditately
MOST Mitsubishi sets have a self check feature:
When power light goes off: On the front of the set press and hold MENU and INPUT (device) BOTH FOR 5 SECONDS OR LONGER AND RELEASE.
POWER light should blink a two digit code: for example:
2 blinks, a pause and 2 blinks----it will repeat the error code several times.
2,2 is the most common and the least expensive to fix.
LET ME KNOW EXACT MODEL NUMBER and the blink code and I will tell you what it means and if 2,2 how to fix it.
If this information helped you, rate this solution as I do this here for FREE.
SD TECH
Nov 14, 2009 | Televison & Video
Power problem
How many blinks is it doing? It has a built in self diagnosis code that it will blink. Pause a second then blink again. Count the blinks then let me know.
Jan 17, 2008 | Panasonic PT-47WX49 47" Rear Projection...
Mitsubishi WS-55511 55" Rear Projection Television Logo
126 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
