Question about Whirlpool Refrigerators
Door handle came unscrewed
Door handle came undone at bottom
2 Suggested Answers
  • 2692 Answers
SOURCE: want to reverse door handles
On most you take the top hindge off. Lift the door off the bottom one then remove the bottom hindge.
Posted on May 09, 2009
Remove citroen c3 rear door panel
Check out how the door panels are attached to the car. Most panels use screws and bolts but others have snap-in fittings. Gather all the tools you need for removing the door panels. If the panel is attached with screws and bolts, you need a screwdriver or ratchet and socket. Car door panels with snap-in fittings are easily removed with a flathead screwdriver.
Locate where the screws and bolts are before starting. These are usually found in the arm rest area, along the bottom or sometimes near the door lights.
Roll down the car door window. Begin removing all screws and bolts that hold the door panel onto the car. If your car has snap-in fittings, pry gently on the bottom corner of the door panel until the fittings pop out.
Remove the power window control panel if your car has power windows. The control panel should pry out easily, and then you unplug the wiring harness from the back and place it to the side.
Use an L pick and flashlight when locating a manual window crank. Look behind the window crank and slide the pick under the edge of the metal clip that holds the crank in place. Remove the clip and pull the crank off.
Remove the door handle by unscrewing the small screw located in the center. Gently pull the door handle out until you see the back of the handle and unclip the rod from the door handle. This should remove the handle unless the handle and door lock are attached, then you just unclip the rod from the lock and remove them both together.
Unscrew the cap off rear upper corner door panel locks. These don't have a rod attaching them to the handle and unscrew separately from the door handle.
Pop the door panel off after you've removed everything. Gently pry on the bottom edge of the door panel until it releases. Pull out and up to completely remove the door panel.
GM Tech2 GM Diagnostic Scanner with 32MB Card and TIS2000
Oct 10, 2014 | 2006 Citroen C3 1.4i
How can I change the mirror control panel?
Firstly, get a replacement switch. Carefully take off the cover of the door handle (mine is the diagonal kind - 2002) and then unscrew the two screws at the top and bottom of the handle. Then Unscrew three screws at the very bottom of the door panel - they are the "star" kind - a tork screw. Carefully pull out the snaps on the sides of the door panel. They just pop out of holes in the door frame. Be carefull not to pull too fast or suddenly. Then pull straight up on the door panel. It can be very sticky at the top but gently work it out of the rubber slot at the top. OPTIONAL: Now that the panel is free, disconnect the electrical and door pull cables. Make a note of what connected where! You can skip this step if you can do the next step in a tight spot... You'll see the assembly for the door handle, lock, and mirror switch. There is a screw by the door handle. Unscrew that, then carefully pry open the clips that hold the assembly in. The whole assembly will come forward out of the door panel. Now, carefully unclip the mirror switch. It will come forward out of the assembly. Place the new switch back in its place, and re-clip. AT THIS STAGE, RE-CONNECT THE ELECTRICAL WIRE TO THE SWITCH AND TEST! Replace the assembly back in the door panel. Replace the screw by the door handle and re-connect the wires and cables. Then "Hook" the top of the door panel on the rubber slot. You can check the other door to make sure it's right. Carefully snap back in the sides of the door panel then reconnect the three screws at the bottom. Finally, replace the two screws in the door handle, and replace the door handle cover.
Best of luck
Jan 11, 2011 | 1999 Volkswagen Beetle
How to, removing front right door panel on 1996 concorde chrysler 4dr sedan
How to remove a door panel, first u must open the door and unscrew the screw that is in the door handle then with a flat head screw driver unhook the plastic conectors to the cover of the handel becarfull not to pull to hard gently pull it as needed then pull the door handle as if opening and then pull the cover of handle out wards and then un detach the electric conector for the door locks then on the bottom handel unscrew the screw that is in the handle then pull out the case that holds it. then unscrew the screws that are on the inside towards the interior of the car there are two then two on the bottom then on the side that opens there should be on or two then pull the panel upwards and then towards your self you should be able to also detach the electric conector for the windows then when your done fixing it the instalation is reverse make sure that you conect the window and door lock conectores and make sure that the door falls in place with window latch. good luck buudy.
Aug 16, 2010 | 1996 Chrysler Concorde
How do I remove the door panel on a 1995 Mercedes
pull off rear mirror panel, pull off electric seat adjuster knobs, pull off plastic around door handles. Unbolt top of handle. Pull out light at bottom of door. Unscrew plastic stiker plate and remove. Unscrew lock knob to remove. Then your ready to wiggle and pull the panel up and off, be careful of the area around the door handle, you may even want to pry that area out before you begin.
Apr 07, 2010 | 1995 Mercedes-Benz E-Class
Broken door handle
The in side door panel ( at total pain) must come off
If the damage to the bottom is not too bad.
On mine I took the cover for the handle loose from the bottom ( it pops off, but be careful).
and put screws at the bottom
Jan 12, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
Want to reverse door handles
May 09, 2009 | Refrigerators
Remove Rover 45 driver door trim to replce wing mirror.
what you need to do here is pull out door trim from bottom & then give it a good bang at bottom it should slide out of top guide but you need to give it a good bang asthey are quite tight in there.
Mar 12, 2009 | 2000 Ford Escort
Replace front speakers
its actually pretty easy. just remove the screws on the door panel. dont forget the one in the handle at the bottom. then remove the little triangle cover behind the mirror on the door. lightly pull from the bottom and the door panels pop clips will slowly come undone....once the door panel swings outwards pretty easily just lift up on the panel and it will come off....once its undone you can either remove the harness for the window switches and lock or just let the panel sit to the side still attached. either way works its just preference. then you just remove the speaker and replace with any 6.5inch you would like... reinstallation is the same..
Feb 18, 2009 | 2005 Scion xB
The back door handle came undone on my 1979 Ford Granada
there should be a door panel you can take off to get to the mechanisim.
Aug 15, 2008 | 1978 Ford Granada
Refrigerators Logo
15 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
