Question about Ricoh Aficio AP610N Laser Printer
Sc 542 erro sc542
boyrevel
  • 71 Answers
SOURCE: sc 542 error code
Error SC 542 indicates a fuser temperature problem. Once the error is detected, the printer is toast until you manually clear the error from the keypad. Even though the printer is physically fine, it won?t come ready until the prior error condition is cleared. The magic keystrokes, clear the error code: The Fix In order to clear error SC542, you must perform procedure 5810. Press and hold online + escape, then power on. Use up and down arrow keys to select SP2 Press Enter Use up and down arror to locate SP5 Press Enter Use up and down arrow keys to select 810 Press Enter Confirm the selection Power off and on. The error code is now cleared.
Posted on Aug 14, 2007
Bubbabear64
  • 2794 Answers
SOURCE: ricoh aficio 2027
SC542 is a warm up error from the fuser.
SC 870 is an address book error.
Turn the power off on the copier. Wait 30 seconds and then turn the power back on. See if it goes away.
Let me know if it doesn't.
Posted on Jul 12, 2008
SOURCE: im having an error sayig SC:542 so how can i solve this kid of problem?
This is a 'fuser" warm up error. You could have a blown out heater lamp, or fuse, but most often this is caused by a power fluctuation. The reset for this is done by simply entering the service mode, and turning the machine of/on with the main power (red button).
enter service mode as follows:
"Clear Modes"
" 1, 0, 7 "
then hold "Clear/Stop" for 2-3 seconds.
The display will change with "service mode" in the top corner.
Now turn power off/ on (red switch)
** Never go further into the service mode, as you can cause all kinds of difficulty.
If the code comes back, then you will have to get a technician on site to troubleshoot the fuser.
Please rate me :)
Posted on Apr 24, 2009
ricohmaster
  • 10 Answers
press clear (yellow) and press 1,0,7 and press and HOLD the stop button 5 secs. (red) press 1 when u see the copy sp mode and press 7 (datalog) and press ok, look for the sc/ jam counter reset. press the execute 2x. turn of the machine in the main switch (orange switch on the lower front side) the shortcut mode is by pressing 7807 na press execute
Posted on Sep 19, 2009
  • 903 Answers
SOURCE: Hi i have problem on my copier model Ricoh aficio
If you've done all of those steps and the problem keeps happening, it's most likely a dirty or defective thermistor, or a blown thermostat. The simplest solution is to replace the fusing unit as a whole, but if you want to save money, you can take the fusing unit out (the black unit on the upper right side, the one that heats up) and using a multimeter, determine if one of the thermostats is bad. Also, check the thermistors (the sensors that lay against the hot roller) for any built-up toner, and check the continuity of the fuser lamp while you have the unit opened up.
Posted on Jun 05, 2010
What is error code SC542 for ricoh aficio 9005?
Ricoh Aficio MP2510, 3010 Error code sc542 on Lanier ...
? 6:08
https://www.youtube.com/watch?v=58MQVyjfDyg
Sep 3, 2013 - Uploaded by Used .Copier
Are you getting Error Code sc542 on your Ricoh, Lanier,Savin or Gestetner copiers? ... Ricoh Aficio 1022 ...
How to reset Ricoh Error Code sc542 sc546 sc548 problem ...
? 2:41
https://www.youtube.com/watch?v=3CnGl1Ytp34
Sep 21, 2015 - Uploaded by Copier Liquidation Center
How to reset Ricoh Error Code sc542 sc546 sc548 problem ...Ricoh Aficio copiers : AFICIO 1013 F
Dec 02, 2015 | Ricoh Aficio Office Equipment & Supplies
Codigo sc 542 en ricoh sp 3510 como resetearlo
Oi por favor. Gostaria de resolver meu problema com minha impressora ricoh 3510sf que estar dando o erro sc542. Me manda resposta. emiliomartinscte@gmail.com
Apr 09, 2013 | Ricoh Aficio SP 3510SF Laser Multifunction...
Sc:542 error message on the screen
You need a firmware update…
SC542 SP1-103-2 Off + Temp has been newly added to prevent SC542 from occurring at machine power-on under low-temperature conditions.
Note: For this fix, it is necessary to use Controller firmware ver5.15.1 or newer.
Apr 02, 2010 | Ricoh Aficio 2015 Copier
Ricoh 2090 SC542 error
model 2090 richo sc 542 thermistar and hetar mail cancektar parobelam
Aug 22, 2009 | Office Equipment & Supplies
Sc 542-00 trouble code
SC542 is a fuser error code and can ONLY BE RESET by a tech. Type pressing clr mode (button) then 107 then press and hold CLR Stop until a menu pops up. turn offf main power then on again. If there is no serious problem the code will not come back. IF it does call a trained tech. DO NOT CHANGE ANY SETTING in the menu that comes up after pressing in the code. YOU COULD RENDER YOUR COPIER INOPERABLE!!!!!!
Mar 27, 2009 | Gestetner Copier
Ricoh Aficio MP 2510 SC 541, SC 542 Errors
To clear level A SC codes such as this SC541, you need to
Enter SP mode, and then turn the main power switch off and on, only.
Please check if the thermistors are the proper ones and are installed correctly in their position properly.
This is also useful for SC542.
Please check the thermostats and fusing lamps for open circuit.
Good luck and please rate me, thanks.
Jan 17, 2009 | Ricoh Office Equipment & Supplies
Sc 542
SC 542 is a fuser code that may need resetting. and this should be only done by an qualifyed service representitive as it requiers going into service mode and going into copy sp 5-810 and having it reset or if this does not work you may need a new fuser unit! Again service mode will need to be entered to reset the SC542 as this is a safty feature built in to the copier to keep it from ferther damage
Jan 13, 2009 | Ricoh Aficio AP3800C Laser Printer
Ricoh aficio 2027
Jul 12, 2008 | Ricoh Aficio 2027 All-In-One Laser Printer
Ricoh aficio 2022 error code sc542
1. Mode(Yellow Button)
2. 107
3. Press STOP Button for 3 second (RED Button)
4. Copy Sp
5. 5810#
6. Excute
7. Power Off
8. Power On
Oct 23, 2007 | Ricoh Aficio 2022 All-In-One Laser Printer
Ricoh Aficio AP610N Laser Printer Logo
22 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
OfficeServiceAjnc
OfficeServiceAjnc
fares
Level 1 Expert
SOURAV KAPOOR
Level 1 Expert
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
