Question about HP Office Equipment & Supplies
Hp cm6040 disable network card
How can disable embeded network card
Hp CM6040 MFP fuser error
You have a bad fuser, contact a local service provider for a new one. On average the price of a fuser is usually close to the price of a new printer, you may have to invest on a new one.
Aug 03, 2017 | HP Office Equipment & Supplies
HP Color Laserjet CM6040 only prints in black and Cyan no yellow or magenta ?
Have they printed 21,000 pages yet, or 10 reams of paper?
Check in the Printer Settings under Maintenance for clues and run the Tests and Maintenance steps.
HP Color Laserjet CM6040 Google Search
Mar 14, 2017 | HP Office Equipment & Supplies
Hp laserjet m5035 mfp error 49 ff04
I think you are since the dc controller only controls paper movement and nothing else. A 49 error is a firmware error and has many causes from applications, network and just defective formatter. If the errors occurs with the printer not connected to anything, then the formatter would be the logical issue if the firmware has been updated. Keep in mind having a jet direct card in the slot can cause the error, so the only true way to test is with everything removed with the exception of firmware, memory and power. Also keep in mind that if the 4250/4350 series power is derived from the lvps and not the dc controller. Also with this model the embedded jet direct card is known to occasionally have issues. When you upgrade the firmware for the formatter it also upgrades the firmware on the embedded nic card. Again the only true way to test would be to disable the embedded nic card on powerup.
Read more... HP Support document HP Support Center and HP Printer Support
Jun 27, 2014 | HP LaserJet M5035 MFP Printer
How to reset roller kit warning on hp laserjet
Hi the HP Laserjet CM6040 how to reset the document feed roller go to administration then go to reset menu then in reset menu scroll down until you see the new document feed roller select either yes or no. Hope this helps
Jun 10, 2014 | Premier Hp - ROLLER KIT CLJ MFP CP6015...
Error 49.4C02 on cm6040 mfp
Replaced formatter ,disk drive plus memory card .problem solves
Nov 30, 2011 | Office Equipment & Supplies
49.FF95 SERVICE ERROR
Please look on: http://www.fixyourownprinter.com/
There are much solutions of this problem listed ...
For example this (it see good):
http://www.fixyourownprinter.com/forums/printer/46157#1
HP Laser Jet 4250n by TLYNN (3/20/07 12:22 PM) reply + / -
Anybody know the error code "49. FF95 Service Error"
We can't get around this...
Firmware Error 49 by Stephen (edited 3/20/07 12:29 PM) reply + / -
It could be a bad job.
First disconnect it from your network and any PC it might be attached to.
Power cycle it, then if it goes to ready status try the built in test pages, do they work?
If the printer will go to ready status and you have a parallel cable with the proper connector, then you can try upgrading the firmware from a PC, you can also try to upgrade the firmware over the network.
More reading:
http://www.fixyourownprinter.com/search/forums?f=&q=49+4250
Re: HP Laser Jet 4250n by TLYNN (3/20/07 12:59 PM) reply + / -
Still won't go back to ready status. Turns on to the same error code....
Cold Reset HP Laser Jet 4250n by Stephen (3/20/07 1:03 PM) reply + / -
Try a cold reset, it will reset the JetDirect settings, but it's the next step.
Cold Reset:
Power off printer, wait about 5 seconds, then power it on, when asterisks start appearing on the display press and hold the check mark until all 3 lights come on solid, then use arrow keys to find cold reset and push check mark to perform the reset.
Re: HP Laser Jet 4250n by TLYNN (3/20/07 1:06 PM) reply + / -
Thank You so much for your help... but that didn't work either. Same error code showed up.
Re: HP Laser Jet 4250n by Stephen (edited 3/20/07 2:27 PM) reply + / -
Then you probably need to replace the formatter.
Do you have another printer you can swap parts with?
There is a slim chance the memory DIMM is bad, you can try it with the DIMM removed, if there is more than one DIMM you can try installing just one and then the other.
A 49 error indicates that the formatter could not understand or execute an instruction within a file or cannot interface with an accessory, DIMM, or EIO device. Troubleshooting 49 errors is done through process of elimination. First determine if the printer functions in a stand-alone mode then test communications to the printer.
These errors can be divided up into two categories; the associated troubleshooting depends on the circumstance the 49 errors are occurring.
A 49 error is always followed by Hexadecimal numbers, for instance, 49.00FF. The Hex code is a memory address. Most Hex codes are not documented.
Re: HP Laser Jet 4250n by dmzcompute (3/20/07 2:26 PM) reply + / -
I do not see anywhere where the printer has been disconected from everything. If you have not done so already disconnect every cable from the printer with the exception of the power cable and turn the printer back on and see if you get the error and if not report back here for further instructions.
Re: HP Laser Jet 4250n by Stephen (3/20/07 3:28 PM) reply + / -
You might also try disabling the embedded JetDirect.
To disable the embedded LAN port
Turn the printer power off.
Power on the printer and watch for the memory count to begin.
Hold down the SELECT (Checkmark) button, when you see the memory count begin.
Continue holding down the SELECT (Checkmark) button until all three printer control-panel lights flash once and then remain on. This might take up to 10 seconds.
After the message SELECT LANGUAGE appears on the display, press the UP ARROW button or the DOWN ARROW button until EMBEDDED LAN DISABLED appears on the display
Press the SELECT (Checkmark) button. The printer then continues its power-on sequence with the embedded LAN disabled.
If this works the JetDirect built into the formatter is bad, you can either replace the formatter, or buy an JetDirect to install in an EIO slot.
Re: HP Laser Jet 4250n by Trev Pearson (3/20/07 10:08 PM) reply + / -
The only other thing to try, before spending money, is to get the network administrator to clear the print queue for that particular printer and then turn it on.
The theory being that a 'corrupt' print job is still in the system and as soon as the printer is turned on, that 'corruption' floods the network card with garbage which promptly goes 49.
If the printer comes 'ready', great. Then do a firmware upgrade. If not, then you will have to spend money on a new formatter.
Regards
Trev
Re: HP Laser Jet 4250n by roadrunner178 (6/21/07 2:09 AM) reply + / -
hi.
With a cold reset ,my problem solved.
try this as a first solution.
thank you
Re: HP Laser Jet 4250n by Anonymous (7/31/07 1:20 AM) reply + / -
THANK YOU WERY MUCH
FROM TURKEY
ZAFER
Jan 02, 2009 | HP LaserJet 2420dn Printer
Can I connect the printer directly to my laptop using ethernet cable
Hi! If the computer is connected to an HP All-in-One on a network, you can access the Embedded Web Server that resides in the HP All-in-One. The Embedded Web Server is a web-based user interface that provides some options not available on the HP All-in-One control panel, including advanced network security options. The Embedded Web Server also enables you to monitor status and order printer supplies. For information on how to use the features available in the Embedded Web Server, see the onscreen help within the Embedded Web Server. To access Embedded Web Server help, open the Embedded Web Server, then click the Help link under Other Links on the Embedded Web Server Home tab. NOTE: Only use the Embedded Web Server to change network settings if you cannot access the HP All-in-One control panel, or you need to change an advanced option not available on the control panel. Access the Embedded Web Server Use the following instructions to access the Embedded Web Server. You can only access the Embedded Web Server on a computer that is connected to an HP All-in-One on a network.
  1. Press Setup on the HP All-in-One.
  2. Press c00706174.gif until Network is highlighted, then press OK . The Network Menu displays.
  3. Select View Network Settings menu, then press OK .
  4. Select Print Network Configuration Page , then press OK . A configuration page prints, including the IP address. You will use the IP address in the next step.
  5. In the Address box in the Web browser on the computer, type the IP address of the HP All-in-One, as shown on the network configuration page. For example, http://192.168.1.101 . The Embedded Web Server Home page displays, showing information for the HP All-in-One. NOTE: If you are using a proxy server in your browser, you might need to disable it to access the Embedded Web Server.
  6. If you need to change the language displayed in the Embedded Web Server, do the following:
    1. Click the Settings tab.
    2. Click Select Language in the Settings navigation menu.
    3. In the Select Language list, click the appropriate language.
    4. Click Apply .
  7. Click the Home tab to access device and network information, or click the Networking tab to access more network information or to modify network information.
  8. Make any configuration changes.
  9. Close the Embedded Web Server.
Good Luck!
Oct 24, 2008 | HP Photosmart C5180 All-In-One InkJet...
HPCLJ2550 goes offline
check for the latest firmware software at www.hp.com and its may be problem with network card its come embedded with main board
Jul 25, 2008 | HP LaserJet 2550L Printer
15 people viewed this question
Seeker5211
Seeker5211
