Question about KitchenAid KSRS25IL Side by Side Refrigerator
Pur faucet mount water filter runs too slow
After changing the faucet mount pur water filter the water just trickles out instead of a strong stream.
3 Suggested Answers
peyton32034
  • 410 Answers
SOURCE: water dispenser is just a trickle
the biggest culprit for slow water dispensing aside from the filter is the water supply its self. check to make sure the water line isnt kinked behind the refrig, if thats ok then disconnect the water line from the refrig and run water into a bucket and observe your water flow. good water pressure would basicly fill a 2 gallon bucket in less than a minute. much less than that can cause problems. hope that helps peyton
Posted on Jan 29, 2009
  • 3 Answers
SOURCE: water is dispening to slow
check for proper flow and pressure on water supply line
Posted on Feb 23, 2009
How do you fix the light in a Pur faucet filter
It could be mineralized, try soaking it in vinegar or scale remover.
Mar 03, 2017 | Refrigerators
Why is my Pur faucet filter so slow? It was not before
You either need to clean the the screen filters prior to as they may be blocked. The filter cartridge itself my need to be changed as you don't say how old it is.
Aug 29, 2013 | PUR 3-Stage Vertical Faucet Mount Gray...
PUR Faucet Mount Water Filter indicator light does not work
Take it loose from the faucet and flip the lever down on the filter in the on position. Take the cap off and remove the filter. Blow hard through it. You should hear a whirling noise of a gear, like a windmill. If not, I use a water dental pic to pulsate into it and clean it out. This is what makes the light work and when flow goes down, the light changes color. It's all mechanical. No battery. Just free up the gear so it turns freely to work the light. If standing in front of a mirror, you can actually see the light come on. PUR doesn't tell you this because they want you to purchase another one.
Dec 17, 2011 | Buck Plumbing
Small stream of water on kitchen faucet
The ruber seat inside the forcet needs replacing or it is getting stuck turn off your main water suply and remove the top half of the tap & inspect if ruber is hard,flatend,cracked or perished replace if not give the insides a good clean and reasemble.. hope this helps :)
Oct 21, 2011 | Plumbing
Which glue to reattach chromed plastic to plastic?
Use old fashioned model cement. Not the child safe type. The old type will melt the styrene to the styrene. The new stuff only fills the gap but never really makes a good bond.
Mar 10, 2009 | PUR (FM-9500) Air Purifier
Whirlpool washer approximately 2 1/2 year old
The screen at the cold water inlet is clogged. Cut off the cold water line and unscrew the line to the washer at the washer. Use a flathead screwdriver and pry out the metal screen that is visible Wash it out in a sink and re-install it. Re-attach the water line,turn it on and your'e good to go. If not you will need a new water inlet valve. These are the only things that can cause your problem unless there is a problem with your cold water supply pressure. Good Luck!!!!!
barneyluc
Oct 03, 2008 | Washing Machines
Can't remove the filter from my Pur Flavor Options faucet mount water filter
When mine gets stuck I stick the handle of a fork or spoon into the hole where the water comes out and use that to unscrew it. Works like a charm every time.
Aug 04, 2008 | PUR (FM-9500) Air Purifier
KitchenAid KSRS25IL Side by Side Refrigerator Logo
427 people viewed this question
Top KitchenAid Refrigerators Experts
John Tripp
John Tripp
mike cooper
Todd Arndt
Todd Arndt
Are you a KitchenAid Refrigerator Expert? Answer questions, earn points and help others
