Question about GE GFE29HSDSS
Not cool enough
Compressor runing all fans runing ff temp wont go below 41 fr teme wont go below 26 has been on 12hrs,
5 Suggested Answers
  • 87 Answers
SOURCE: refrigerator doesnt get cold enough
If you remove the back panel on the inside of the cabinet then you would be able to check the evaporator coil (cold bit) and see if it is frozen up. If it is then defrost the system and see if you have any improvement. All the things you have pointed out over the compressor is normal, they do run incredibly hot. If you have got the freezer on a very cold setting I would suggest bringing both setpoints to a mid range setting. Check the temp in the fridge by measuring liquid temp as air temp is prone to fluctuate more. If you still have a concern I would suggest contacting a fridge guy to assist you. Hope this is of some if not limited help.
Posted on Sep 11, 2007
  • 306 Answers
SOURCE: ge side by side tpx24biyaww freezer not cold enough.
You have to find out why the compressor shuts down at 28 degress rather than going on to zero?
You probably need a voltmeter to see what shuts down at 28. The thermostat may be faulty.
What is stopping the compressor from continued opertion until zero freezer degrees is reached?
Go figger!
Posted on May 01, 2009
Sea Breeze
  • 4654 Answers
SOURCE: freezer and fridge not real cold no ice
Inside the fresh food compartment there is a defrost timer behind the control panel. There will be a small hole that you can place a screwdriver through and turn clockwise s;lowly until you hear the refrigerator stop. It should remain stopped for about 30 minutes. If not you will need to again turn it again slowly until it starts. If this happen the timer will need replaced. The part number for the timer is WRX9X489 This is correct providing the model you have is the model listed above your post.
Go to the link below and enter your model number in search feature. this takes you to many just like yours, they are same just little differences. Let me know, Thanks, Sea Breeze
http://servicepartstec.blogspot.com/
Posted on May 28, 2009
aasc
  • 1606 Answers
SOURCE: freezer not cooling, fan blowing, fridge also not
If there is no frost , on the inside rear freezer wall ,
http://www.scribd.com/doc/13371507/Ge-Motherboard-Concession-Letter .
If there is frost , reply back with complete model number .
Posted on Nov 08, 2009
What can I do? Freezer is not cooling, inside light is on. control panel is off, Temp shows blinking OF and FF
Might need a freon top up. If the compressor is functioning there may be in sufficient freon . This can be topped up. A repairman/technician can diagnose this fairly quickly
Jun 05, 2015 | Frigidaire Freezers
Subzero 611 freezer not cooling
Could be but before that check if settings are working. Set the freezer settings to coolest and see if cools. If ok, set to desired temp.
Dec 30, 2013 | Refrigerators
Rooftop RV Air Conditioner: temp outside 90 or above. compressor kicks off ....
It sounds like maybe an overload for the compressor is tripping and resetting once the compressor cools. Possibly due to a low charge.
May 03, 2010 | Heating & Cooling
I changed the air compressor and the dashboard control panel last year and it has done ok. Now the temp. fan and the compressor fan won't kick in and the air compressor won't kick in also. Checked all...
You say temp fan?If you mean the cooling fans,then the ac is out of freon most likely,the freon has to be in the system,and enough to kick the compressor on,therefore turning the cooling fan on.
Apr 06, 2010 | 1996 Chevrolet Monte Carlo
Air conditioner not blowing cold air anymore
hi! there,
if no cold blowing,evaporator is not working,have you ever heard compressor is running,check this out,no compression of course you dont have cool on evaporator.if the compressor is running check the oprating current,if still have enough freon charge,if not running check thermostat reset setting on the coldest,ifn still not run check overload relay on panel control reset lever to put back compressor to run,check condensing fan if working,if not check also over load protection,this should be done by ac tech nician.have a nice day,dont gorget to rate me, thank's
Apr 18, 2009 | Fujitsu 24R1 Air Conditioner
2002 Sedone Air Conditioner not coooling enough
if you have had it checked give me the readings of the high and low pressures with the engine running and i can tell you if you have a fan problem ....but it must very accurate info.....vagman54@btinternet.com
Oct 23, 2008 | 2002 Kia Sedona
Compressor is extremely hot
Compressor will be hot to the touch. You stated the fan was replaced and then said the fan is not cooling. If you replaced the fan and it is now operating, reinstall the panel you removed to install the fan motor. That panel determines proper air circulation to cool the system.
Jun 14, 2008 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Frigerator not cooling not cooling at all
make and model # was there frost on the evap.?
Sep 12, 2007 | Daewoo FR-147RV
Refrigerator doesnt get cold enough
Sep 11, 2007 | GE Â 17.9 Cu. Ft. Top-Freezer...
GE GFE29HSDSS Logo
103 people viewed this question
Top Refrigerators Experts
Sal DeAngelo
Charles T Nevin
Charles T Nevin
Andrew Taylor
Andrew Taylor
