Question about Sears Refrigerators
Ice dispenser not workong
Do not dispence
tech master
  • 120 Answers
SOURCE: Ice will not dispense GE model GSL25IFRF BS
well if you trouble shoot the board at the back to see if you are getting voltage if you are then use a jumper on that conenctor and see if the auger motor runs or remove auger motor and check voltage there while pressing the lever for ice usually 100% of the time that board controls everyhting water and ice
Posted on Nov 18, 2008
  • 85 Answers
SOURCE: ice cube maker only dispences crushed ice no cubes
remove ice bin look at small square opening reach in with your finger and pull down on vertical rod if it doesn't come down you'll have to remove complete auger asm from freezer (remove 2 1/4 screws and unplug electrical connection lift asm up and pull forward ) set out at lest 24 hours for asm to defrost and dry out then reinstall auger asm
Posted on Dec 21, 2008
  • 219 Answers
SOURCE: I have a GE Profile side by side. The icemaker & water dispenser
check where the line connects at the bottom of frezzer door
Posted on Mar 24, 2009
rylee_smith
  • 8619 Answers
SOURCE: Will not dispence ice, crushed or solid cubes, will dispence h2o
Hi
If the ice maker has completely stopped producing ice Check to see whether the ice maker has been turned off. Here's how to check. Look for a wire along the right side of the ice maker that looks a bit like a coat hanger. If this wire is in the raised position, the ice maker is turned off. On some units you simply lower the wire to the down position to turn the ice maker on. On others, you lower a small red plastic lever to lower the wire. If the wire is in the proper position check the freezer temperature, it should be between 0-8 degrees Fahranheit. If it is warmer than 10-12 degrees, the ice maker may not produce any ice. Check your door seals and thermostat, repair/replace as necessary.
and if the ice maker is producing ice poorly When an ice maker is producing ice poorly--when it produces just a few cubes or none, or when the cubes are too small--it's usually because of a clogged water line or a defective water inlet valve.
First, check the water line attached to the back of the refrigerator for good water flow. To do that, first turn off the water supply valve. Then remove the water line from the back of the refrigerator. Next, place the water line into a bucket and momentarily turn the water valve back on to test the flow. If the flow is poor, you need to repair, clean, or replace the tubing or the shut-off valve that supplies the water. If the flow is good, you may have to replace the water inlet valve.
Please do rate the solution as "FixYa" and revert for further assistance.
Thanks
Rylee
Posted on Apr 09, 2009
SOURCE: ge, tfx26kpda ww, ice maker only dispences crushed ice
At least yours is making ice. Mine wount even make ice. While toubleshooting my prob, I notice a metal rod on the bottom of the ice tray. This rod opens and shuts a plastic "trap door" in the tray. The position of that door determines whether the ice is crushed or whole. If the trap door is open the ice falls through the dispenser freely. If the door this closed the ice is force thorugh metal teeth where it is crushed then dispensed. Open the freezer door and take the ice tray out. You should see a hole at the back of the freezer that the metal rod goes through. In that hole there is a plastic square that moves up and down. If the set your dispenser to crushed ice, leave the door open, push in the door switch at the bottom, and press the dispenser. The plastic square does nothing while the motor is turning. That allows the door to stay closed and forces the ice through the metal teeth. If you set the dispenser to whole ice and do the same thing the plastic square is suppose to lift up forcing the door open and letting the whole ice drop freely. The plastic square probably does nothing even if you set it to whole ice. That mean the trap door never opens focing the ice to always get crushed.
Unfortunately, I have no solution because mine works and I had no need to investigate further. I hopes this helps you figure out the problem though
Good Luck.
Posted on Jul 13, 2009
Ice dispencer does not dispence ice.
it's plugged
When was the last time it dispensed? if some time has passed there may be ice built up in it/ Look up into the dispenser from the outside to see if you see a blockage.,. also you may need to remove & replace the tray which holds the ice.,. and to also check to be sure you hear a nose that it is working,. all is provided it is making ice ok to begin with..
Best regards
Ck
Mar 07, 2011 | Amana Refrigerators
How do i access the ice dispencer door in the door? The door is stuck open and freezes up the dispencer.
1. Disconnect the unit from the electrical
supply and wait for 3 to 4 hrs to get ice melted.
2. Pull out and unclip the drip tray on the ice
and water dispenser compartment.
3. Remove the screws from the ice and water
dispenser compartment front panel and
turn it over. The selector switch pack and
dispenser switches are now accessible for
testing.
Jan 29, 2011 | Whirlpool 25.6 cu. ft. Side-by-Side...
Ice will not dispence thru door.
Without knowing the brand and model # I can offer the most common solution.
On most "pass the ice through the door" models there is a flapper door where the ice dispenses. The spring which holds this door closed when you are not dispensing ice becomes weak allowing the flap to stay open jsut a bit. This open space will create an ice dam in teh dispenser thus not allowing the ice to dispense. The repair is generally made by replacing the flap assembly.
All the best.
Nov 21, 2010 | Refrigerators
GC3SHEx300 ice dispencer does not dispense cube or crush ice. Water comes out, lights work. it is not deactivated.
Sep 06, 2010 | Whirlpool 21.8 cu. ft. Side-By-Side...
Ice dispenser gives crushed ice only, no ice cubes
The dispencer my be plugged, take it out and let it thaw for a day and then clean and replace it.
Aug 16, 2009 | Refrigerators
No water supply to water dispencer
I had this problem with an old amana and my water filter neded replacing. Filter was enough for ice but not for water dispenser.
Mar 27, 2009 | Amana 22.6 cu. ft. Side-By-Side...
Sid by side ice dsspencer and water dispencer(all the indicator light suddently are shut off) not working
you could have a problem with your dispenser module. a burnt pcb that could lead to all of your problems. switches not working, lights not working, dispenser not working, etc.
check your dispenser module and if you find a burnt part or a burnt PCB, then replace it.
tnx 4 using fixya,
drcool
Oct 14, 2008 | Frigidaire FRS3R5EMB Side by Side...
Door dispenser stopped dispensing, starting making a constant clicking and now the entire fride isn't working
We had the same problem. Our frigerator is 1.5 year old. Everytime we try to dispence water or ice the dispencer clicks and the whole thing turns of. We had a GE repairman come by: the electronic board needs to be replaced: total cost $350. (cost of the board only: $150. We are considering disconnecting the dispencer by unplugging the board (according to the repain man the ice maker wil still work)or buy a new refrigurator (for sure NO GE!!!!!!)
Aug 01, 2007 | GE (PSS26MSRSS) Side by Side Refrigerator
Refrigerators Logo
61 people viewed this question
Top Sears Refrigerators Experts
Mike Carew
richie46
Are you a Sears Refrigerator Expert? Answer questions, earn points and help others
