Question about Canon Power Shot SX210 IS Digital Photo Camera Kit - Black
I dropped my digital camera and the lens is crooked now
Lens error
  • 9 Answers
SOURCE: Canon PowerShot SD600 Digital Camera
Manually rotating sensor rotor inside camera and cleaning gear fixed the Canon "lens error" for me.
I placed instructions with photo's here: http://www.avh.dds.nl/Fix-Canon-SD600-Lens-Error/
Posted on Mar 08, 2008
  • 373 Answers
SOURCE: Lens wont close.
did you try and take the battery out and outting them back in
might be worth a try
Posted on Feb 08, 2009
  • 22 Answers
SOURCE: Camera Dropped in water, lens error [sx100]
buy a new lens because water stays in lens
Posted on Jun 14, 2009
SOURCE: lens error
yes, this happened to me, what you have to do is "snap" the lens back in place, if it is bent anyway. if it is not bent and it says lens error, does it the lens come in and out? if not then it is bent if so then there is a hardware error in the switch and you will have to send it to a profesionall. :) hope i could be some help :)
Posted on Jun 17, 2009
ginko
  • 19396 Answers
SOURCE: Lens error, restart camera
Lens error is usually caused by mechanical faults concerning lens assembly. The lens cannot extend or retract fully, the error is detected and lens error is returned.
Sometimes this can be fixed playing with the lens during extraction or retraction to help the lens asset getting back to normal.
More often the camera lens must be disassembled and re-assembled by a technician to fix the problem.
Posted on Jul 05, 2009
Crooked camera lens
Camera got dropped, lens got pushed in on one side? If you can straighten it yourself by pulling it out straight on that side, it might work perfectly afterwards.
Feb 11, 2012 | Canon PowerShot A95 Digital Camera
NO OPEN THE LEN WHAT CAN I DO, THE CAMERA IS FALLEN AND THEN ONLY STAR UP AND APPEAR THE MESSAGE *LENS ERROR 16
Lens error 16 means the lens has popped out of its tracks internally. This happens if the lens is out when the camera is dropped. Most require a new lens. If the lens is crooked, it is possible to straighten it sometimes. See the picture.d40ff78.jpg
Attempting to straighten the lens can break it but rarely makes things worse.
If the lens is jammed in, not much can be done without a technician.
Mar 22, 2010 | Kodak EasyShare C763 Digital Camera
Camera dropped, lens won't retract or expand
You can buy a new A590 for under $110 these days, so the professional repair option may be out. Lens errors are fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended ...
Here's some things that you can do to try to correct it. They only seem to work for less than 50% of the lens errors, but if the camera is out of warranty, they're worth a try:
http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
Jan 24, 2009 | Canon PowerShot A590 IS Digital Camera
Kodak Easy Share C330 lens error 14 and lens error 22
This is probably THE most common failure among digital cameras. There's a halfway chance of fixing it yourself, described here: http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
Oct 08, 2008 | Kodak EasyShare C743 Digital Camera
I dropped my camera and the lens is crooked now and when i turn my camera on it sayslens error:126,1,0,-9
Usually a "lens error" is only going to be fixed by sending it into repairs or an authorized service center. I would contact the repairs department of your cameras manuacturer and they can tell you where to send it.
Sep 12, 2008 | Cameras
Error 18 Lens retraction problem
The lens mech has been damaged (likely by being dropped or bumped). If it is not VISIBLY crooked or twisted, odds are that you have a broken gear or other internal. The only fix is a new lens assembly, which tends to be rather expensive ($80-$200), just for the part.
Please rate this solution.
Aug 30, 2008 | Canon PowerShot S2 IS Digital Camera
Jammed lens
Hey latyrant,
If the lens visibly looks crooked then the lens is probably broken and needs to be repaired by an authorized service technician. One thing you could try is placing the camera on a flat surface with the lens pointed up and holding the shutter button in, while doing this turn the camera on. Sometimes this will force the camera to try and focus before the camera can register the lens problem and sometimes it will force the lens back into alignment. If this doesn't work you could bring it to a Geek Squad® precinct in a Best Buy™ store and they could send it out to get looked at by a technician. I will say that the cost of digital camera repairs often exceed the value of the product. I hope this helps!
Sincerely,
Allan
Go Ahead. Use Us.
Jun 24, 2008 | Cameras
Dropped camera. lens open and crooked
Sorry to say you have broken the lens, replacement of the lens is the only practical repair and if you cant swap one yourself from a dead camera it would be beyond economical repair.
If you are adventurous you could buy a faulty one of ebay and swap the lens or if the faulty one has a broken screen or mode dial swap yours over to the faulty one..
there are a couple of "tricks" do getting this camera open drop me a line if you decide to proceed...
best of luck
Apr 11, 2008 | Kodak EasyShare DX6490 Digital Camera
Dropped camera and don't know if it is fixable
Generally speaking, there is nothing you can do to correct the problem other than to send the camera to the appropriate factory service center for correction of the error. Following the repair cost you should decide, whether it worth it.
Aug 03, 2007 | Canon PowerShot S410 / IXUS 430 Digital...
Canon Power Shot SX210 IS Digital Photo Camera Kit - Black Logo
23 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
