Question about Konica Minolta Office Equipment & Supplies
Minolta Copier I have a Minolta Di450 and I am getting the error ''Malfunction Detected'' Call your service Tech Error code C-13. Can you tell me what is wrong? Thanks
  • Konica Minolta Master
  • 6,712 Answers
The malfunction code is for a Polygon Motor malfunction. The motor that shoots the laser beam across the drum
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
Posted on Jul 25, 2009
KONICA MINOLTA 1050e code SC23-13
Air separation motor (M10) rotation abnormality. Since an error is detected when the M10 turn ON, turn it OFF. An error is still detected when turn it ON again.
Air separation motor (M10) Air motor encoder sensor (PS30) Resetting of the intermediate toner hopper section
Nov 22, 2017 | Konica Minolta Office Equipment & Supplies
Error Code c0045
Bop. Error Code c0045. Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
http://www.officeimagingsystems.com/id169.html
Konica Minolta Di450 Error Codes
http://www.biz.konicaminolta.com/download/users-guide/c554e_c454e_c364e_c284e_c224e/en/contents/id16-_101076518.html
Aug 25, 2016 | Konica Minolta Minolta Di450 Di470 Di550...
Error code 23-13 konica minolta 1050
Toner conveyance abnormality SC23-13. Air separation motor (M10) rotation abnormality. Since an error is detected when M10 turns ON, turn it OFF. An error is still detected when turn it ON again.Air separation motor (M10) Air motor encoder sensor
(PS30) Resetting of the intermediate toner hopper section. Have a tech come out to check out.
Jan 25, 2016 | Konica Minolta Office Equipment & Supplies
Erace the c-of24 on di450
The code refers to a sensor that looks at the drum - it might be dirty or something else is going on check this Fixya-link: Minolta DI450 error code C0F24
Jan 17, 2015 | Konica Minolta Minolta Di450 Di470 Di550...
Di550 error code
1. Run "Hard Disk Format" selected in the following sequence: Tech. Rep.
Mode  Function  Image Memory.
2. If the same malfunction persists, change Hard Disk Drive.
3. If the malfunction is detected a third time, change Memory Board.
service mode :meter count, stop 00 stop 01
Jan 22, 2014 | Konica Minolta Office Equipment & Supplies
I have an error code on the Konica Minolta Bizhub c250 of c-2651 can someone tell me what is wrong?
Cyan image unit need to be replaced using third party if so replace with OEM
Jan 06, 2014 | Konica Minolta bizhub 250 All-In-One Laser...
Minolta DI450 error code C-0920
1st paper draw lift motor is jammed or burn out or the control board is bad. Check for paper behind the draw, also remove any paper from left side of draw.
Dec 26, 2013 | Konica Minolta Minolta Di450 Di470 Di550...
How to fix C-0500 error for BIZHUB C350 konica minolta printer
Open the front door with the machine on, get down on the floor and look up on the right side of open area there is a slanted section in that slated section is a small hole you will not see it standing! With a small screwdrive gentle push the small switch located in side the hole that will reset the code if it comes back DO NOT RESET the copier is telling you something is wrong with the FUSER UNIT the HOT part continued reset might catch the machine on fire and that would ruin a perfectly good day. Have a qualified Tech look at it from Konica Minolta.Check this web site out for a rough idea of cost to replace the fuser.
Precision Roller Printer Toner Cartridges Parts and Supplies Office...
Jan 31, 2012 | Minolta Office Equipment & Supplies
Minolta dialta Di450 Error message C-143E
The Document Feeder has only 1 Malfunction code for any problem with it.
If opening and closing the front cover (while it is turned on) resets it and you can use the machine, dont worry about it.
The unit was prone to this false malfunction code.
If it returns very often, then get an engineer to have a look at it.
Jun 09, 2009 | Konica Minolta DiALTA Di200 Copier
Hi there!!! My printer displays error message: malfunction detected call representative - c3751. Kind regards
hi this is a high temp code, you need to replace the fixing unit then get a service tech to reset the machine
si
Jun 05, 2009 | Konica Minolta bizhub C250 All-In-One...
264 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Adorjani Laszlo
carpediemweb
Level 1 Expert
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
