Question about Sitarg DEV Minecraft Manual
My minecraft character keeps saying click every time i click the mouse
Every time open a door the guy says open and close. every time I click something the guy says click. I just want him to stop.
How to copy and paste VSO Convert X license key
  • Highlight the text with your mouse by clicking the left button and holding down the click until you have highlighted all the characters, then release the left mouse button.
  • Click on the right button of the mouse and in the drop down menu select "Copy".
  • This will keep the key in the clipboard,
  • Open the software where you need to insert the key and place your mouse 's cursor in the box.
  • Press the right button of the mouse and in the menu select "Paste". Now press the activate button.
example here:
How to register VSO products
Sep 30, 2014 | Computers & Internet
Tip
How to change your skin on minecraft mac
Double click on trackpad and press Get Info, go to Name & Extension, then change the skin you want to char.png, then go to Finder, Your Home(like ex: jpledger), Library, Application Support, minecraft, texturepacks, go in to your texture pack, press mobs file, then drag the skin called char.png in to the file, there is your skin! Woppss, almost forgot to tell you, you have to keep Minecraft closed the whole time you are doing this!
on Oct 31, 2013 | Computers & Internet
Download skins for minecraft
1st, make sure minecraft isn't open
2. log in on the website
3. find a good skin
5. click upload or change my skin
6. open minecraft
7. Wal ah!
Dec 12, 2013 | Android Apps
My key board and mouse are typing wrong letters and mouse is selecting and opening every folders when clicking to open. laptop brand Fujitsu Seimens
Please check with external usb keyboard and mouse.
If external is working fine.. then there is probelm
with mouse clicking multiple times when you click one time.
For keyborad, you are not given any more information regarding what is the character displaying when which key is pressed. Try to check with numlock, and other functional keys.
if external also not working, check with local laptop repair center.
Please rate me if solution solved.
Jun 09, 2011 | Computers & Internet
LX7 Cordless Optical Mouse troubleshooting
Hi there.
Go to the control panel, in control panel you will see mouse, click on that and you will be able to set reaction times speed click times and all the mouse settings.
Good luck and thanks for using FixYa!!
May 28, 2009 | Logitech LX7 Cordless Optical Mouse
Emachines Keyboard Model No. KB0511
Here you go:
Enter
The computer brings the cursor to the beginning of the next line. This key can also be pressed
to open a program after you have HILIGHTED* it. It will execute a command.
Shift ▲ Hold the shift key down and press the letter key you want to make a CAPITAL letter.
This key is also used to type the charters at the
top of some keys. Eg: Shift + 1 = ! or Shift + 2 = @
Caps Lock
Makes all letters CAPITAL letters. When the Caps Lock key is pushed, a light will
show up on the upper right corner of your keyboard
next to the capital “A”. When caps lock is turned on it remains on until you press the Caps Lock key
again. When you press the Shift key when
Caps Lock is on, a lower case letter will be produced.
Space This key places one space every time it is pressed. (The long, unlabeled key at the
bottom center of your keyboard).
←Backspace Deletes the character to the left of the cursor each time you press it. (If you hold it
down it will continue to delete so be careful).
Delete Deletes the character to the right of the cursor each time you press it.
Home Brings you to the beginning of the line the cursor is on.
End Brings you to the end of the line the cursor is on.
Esc Located in the upper right corner of your keyboard. Cancels an incomplete command;
it will also close an open menu.
Moves the cursor to the left one space each time it is pushed; does not delete the
character.
Moves the cursor up one line each time it is pushed; does not delete the character.
Moves the cursor to the right one space each time it is pushed; does not delete the
character.
Moves the cursor down one line each time it is pushed; does not delete the character.
Insert Deletes the character to the right of the cursor and replaces it with whatever is typed on
the keyboard.
↔Tab Moves the cursor to the tab marks and between columns.
Shift + print screen Prints what is on your computer screen.
Highlight (to select) To make the item stand out. To choose or select it.
? *When an icon is highlighted (left click the mouse button one time while the cursor is pointing at
the icon), the program has been chosen and the name of the icon will change color. When this has
happened, you may press the Enter key to open the program.
? *To highlight a character or characters, move the cursor, using your mouse or the arrow keys, to
the left of the item you wish to select. Press the left mouse button and hold it down while you
move the mouse to the right. Let go of the left mouse button and your item(s) should be
highlighted. Then you can choose what you want to do to the selected item(s) e.g. bold, underline,
delete, italicize, etc.
“Drag and drop” Move the cursor to the item, click the left mouse button and hold it down.
Move the mouse, while holding down the left
mouse button, to the location you want to move the item. Let go of the left
mouse button.
Cursor - The arrow on your screen. The mouse is used to move the cursor.
Let me know if this helped
Jan 02, 2009 | E-Machines eMachines Desktop PC
Game Saints Row 2 keeps freezing at certain points in the game
It seems like a 360 problem, exchange for another one, maybe it could be a disc problem though. If a game is REALLLY damaged it can cause the same problems
Dec 30, 2008 | Microsoft Xbox 360 Console
Uninstalled SP3 to get mouse to work.
Right click on my computer, click properties, click on Automatic Updates and select Turn Off Automatic Updates.
Open Control Panel, open Security Center. Then click on Change the way Security Center alerts me, Uncheck all three check boxes.
And now see if your problem cures
Nov 25, 2008 | Microsoft Windows XP Professional With...
Hp 4215-v officejet printer.. scanner functions not installed
For those folks who have Windows 7...
Click start from menu (bottom left of window pane),
Click "Devices and Printers",
Click on the HP printer listed,
Click "scan a document or picture"...
CALL IT DONE!!!! Gotta LOVE Windows 7...EASY!
Feb 12, 2008 | HP Officejet 4215v All-in-One Printer
Sitarg DEV Minecraft Manual Logo
69 people viewed this question
Top Sitarg DEV Apps Experts
Are you a Sitarg DEV App Expert? Answer questions, earn points and help others
