Question about Water Heaters
Flashing green light on worcester bosch boiler no heating
Wieless thermostat, no display
  • 13 Answers
SOURCE: Bosch boiler System
it means that the boiler wants to be serviced, the boiler will still work fine. Once the boiler has been servcied, there are a succession of buttons, that need to be pressed, to tell the boiler that it nhas been serviced. then 365days after it will do it again. Its there to prompt you, to get the boiler serviced
Posted on Mar 03, 2009
  • 659 Answers
SOURCE: lost manual
I couldn't find your model number but here is the website where you will be able to find it if they have it available online. You can also find contact info as well.
http://www.worcester-bosch.co.uk/homeowner/literature/product-guides-and-brochures
Posted on Apr 01, 2009
SOURCE: My boiler is not working, not heat, no hot water,
your condensation pipe may be frozen get a hairdryer on it or a hot kettle that should sort it thats the whit pipe on the left usualy plastic
Posted on Jan 09, 2010
SOURCE: Worcester Bosch Highflow 400 Boiler - no hot water or heating
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0cm 5.4pt 0cm 5.4pt; mso-para-margin:0cm; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Hi, this is Worcester, Bosch Group
Although we don't currently offer live technical support online, our Technical Support department will be able to help. Their number is 0844 892 3366 - they're open 6 days a week and on average answer calls within 20 second. If you want to know more about our Technical Support department visit our website
http://www.worcester-bosch.co.uk/homeowner/customer-service/customer-technical-support
We look forward to helping you
Posted on May 17, 2010
  • 10 Answers
SOURCE: my worcester bosch 24i junior pressure keeps
When water is heated it expands. To deal with this all boilers are fitted with a small expansion vessel which is like a reservoir which holds the excess water.
This expansion vessel is like a balloon in a metal pot. When the water goes in the metal pot the baloon squashes a bit to make room for the extra volume of water. When it cools the balloon pushes the water back into the heating system.
What has happened is your expansion vessel no longer works. When the water heats up there is nowhere for it to go so the pressure jumps up to 4 bar. The Worcester boiler lets high pressure water escape (most boiler allow this to go through the safety valve at say 3.5 bar).
When the water cools the pressure drops very low as the volume of water contracts.
The problem is your expansion vessel - normally a little red painted metal cylinder inside the boiler.
Posted on Dec 22, 2010
How to fix my Worcester green star ri boiler?
The gurgling sound sounds like you have gotten air into the system. Try purging the air out at the bleeder valves. Also check and make sure that your water inlet is working.
May 29, 2016 | Water Water Heaters
How do you work the heating on a Worcester bosch 35cdi boiler
search for worcester bosch 35 cdi manual choose Greenstar CDI & download the pdf instructions
Dec 31, 2014 | Bosch Water Heaters
Hi I have a 24i worcester boiler I have drained the heating to do some work but I need the hot water to still work.I spoke to Bosch and they said I need to put a loop in.I am not a plumber but can get
Hi Steve, I am not a plumber but have done a lot of DIY on my own heating system with Worcester Bosch combi boiler! I believe that you can have the hot water on without the heating system filled, just turn all the settings as for summer use and the thermostat right down so the heating is forced to stay off!
Nov 07, 2014 | Water Heaters
Worcester Boiler Greenstar 15Ri - The blue neon light is flashing - what does this mean?
http://www.worcester-bosch.co.uk/homeowner/literature/gas-boiler-literature/greenstar-15ri-literature. Hope this helps :)
Sep 19, 2014 | Water Heaters
Thanks for that mike, it is a worcester bosch combi 24cdi heating and water can stay on for an hour then everything goes off and the red light flashes. it will come straight back on when reset, but then...
Check the pressure reading, should be about 1 bar when system is cold. Various models in the range of 24cdi. If you do not have a manual, go to,
http://www.centralheating.co.uk/Boiler-Manuals/worcester-bosch-boiler-manuals/worcester-bosch-discontinued-boiler-manuals.
Get the manual for your unit, to wards the end of install manual it has a fault finder, Also has a basic 1 in the user manual. Number of flashes how fast the light flashes which one flashing can all mean different, So get the manual and check, Some parts are easy to fix, as long as you do not touch the gas side the rest is plumbing. Come back if needed.
Mar 05, 2013 | Water Heaters
May 13, 2010 | Bosch Water Heaters
Water Heaters Logo
16 people viewed this question
Top Water Heaters Experts
Paul Carew
Gil Shultz
Are you a Water Heater Expert? Answer questions, earn points and help others
