Question about HP DesignJet 500 InkJet Printer
Blank paper when i try to print, the comes empty
4 Suggested Answers
Benimur
  • 6966 Answers
SOURCE: empty ms word printout
Hi, You can try: 1. go to Start, Printer and Faxes, right click on your 3745, click on Properties, Printing Preference; 2. Check to see if you have any Advanced tab or button; 3. Check if you can set the printer to text only; 4. Check if you can set the printer to use black ink only. 5. In MS Word, verify through the use of Print Preview that your document is as you would want to be printed; 6. In some instances you may have to set manually text color in MS Word. While your document is open, click Ctrl + A to select all, then choose font color to "Black". Alternately, in your MS Word, you can click on "Format", "Font", "Font Color" set to "Black" rather than "Automatic" and set this as the "Default" setting. Hope this be of some help/idea. Post back how things turned up or should you need further information. Good luck and kind regards.
Posted on Sep 29, 2007
  • 27 Answers
SOURCE: printing problem
download the drivers and install it
Posted on May 31, 2008
Muggs01
  • 72 Answers
SOURCE: HP Laserjet 2200 Keeps Spewing Out Blank Paper
sounds like it has a solinoid that is stuck open.
Posted on Jan 16, 2009
Nothing at all printing or copying, just blank pages
hi and welcome to fixya
Your printers ink Carthage is empty ! making noise of printing and blank pages is because of the empty cartage bring a new cartage and then printer will print the pages
Dec 07, 2012 | Epson Stylus Photo RX520/RX530
Reading no paper paper tray is full
Instructions
  1. Check the display for an error message. If the display reads "Clearing paper from printer," the engine has detected a jam and is attempting to eject the jammed pages automatically. These pages will often be blank.
  2. Check the display for "Performing PRINT/STOP TEST" or "Performing SERVICE TEST." Either of these messages indicates that the printer is going through a test procedure that may eject blank pages.
  3. Reduce the amount of paper in the input tray if the printer is feeding multiple blank sheets at a time. The printer will pull extra pages through if the input tray is overfilled.
  4. Replace the paper in the input tray with the correct size if needed. If the 4600 printer detects the paper as an incorrect size for the print job, it may eject the paper without printing anything on it.
  5. Replace the ink cartridges if certain colors are blank on the page. Replace the black cartridge if printing a black text document that is coming out blank. The printer may attempt to print even if the ink level is low or empty, but will unable to print anything on the page, causing it to come out blank.
  6. Remove the sealing tape from newly installed cartridges. The tape covers the print heads and should be removed before installing the cartridges. If the tape is left on, it will prevent ink from getting on the pages as they print.
  7. Press the "Check mark" button on the control panel to enter the printer menu. Run a diagnostic so the printer can attempt to determine the cause of the blank pages printing. Press the up or down arrow to select "Diagnostics." Press the "Check mark" button. Press the "Down" arrow to highlight "PQ Troubleshooting." Press the "Check mark" button. The printer runs a diagnostic and returns to a ready state when done.
Jan 08, 2011 | HP LaserJet 4600 Printer
A Lexmark E250dn in my school does not print. There is a new ink cartridge in it and it "talks" to the computer but does not show what was sent to print. The motors runs paper through it, but the paper...
This likely to be a faulty cartridge.
There are a number of things that can result in blank pages, but if the cartridge has just been changed (and the old one was fine apart from being 'empty'), you should be talking to your supplier.
Apr 23, 2010 | Lexmark E250dn Laser Printer
My Canon Pixma MP610 printer will not print. It
Possible causes: Empty cartridges or new cartridges with cover strip still on the contacts, plugged printhead, wipe with warm water on paper towel to see if all colors are there, also physicallyclean the black cartridge. Try to print. If not working, use the printhead clean and or prime in the printer's maintenance tab.
Mar 09, 2010 | Office Equipment & Supplies
Canon i965 prints blank pages
Yes those printheads do go bad, they burn out just like a light bulb. If you emptied cartridges then the purge/cleaning assembly is working properly, and the only other option is the expensive printhead.
Aug 20, 2009 | Office Equipment & Supplies
Printing but blank pages coming out .
Take the ink cartridge out of the printer. On the bottom of the cartridge, there's a copper/gold surface with bumps and holes. Take a napkin or peice of paper and rub it on this surface. This serves two purposes - if there's any dried ink or blockage, it will help clean it, and it's a test to see if there's any ink left in the cartridge. On a normal ink cartridge, rubbing paper on the bottom would cause some ink to smear onto the paper. If nothing wet comes out, the ink cartridge is dried out or empty. You'll need to replace it.
May 19, 2009 | ASUS Intel 810E Chipset CUWE-RM...
Producing blank pages
repeated nozzle cleaning (6 times) which almost emptied the cartridges but it is now printing
Jan 03, 2009 | Epson Stylus CX3200 All-In-One InkJet...
HP Laserjet 1500 Color, Print out Blank
Hi devi960:
Pages print, but all
colors do not print or
the pages are
completely blank.
One of the print cartridges might be
low or empty.
Run an engine test and see if all four colors print. If
not all colors print, replace one or more of the print cartridges. If the
engine test is successful, replace the formatter.
If the printed pages are completely
blank, the file might have blank
pages.
Check the file to make sure that it does not contain blank pages.
A print cartridge might be low or
empty.
Check the printer control panel for a Supplies Status message,
print a Supplies Status page, or use the embedded Web server
(HP color LaserJet 2500 series printers only) to see the levels
remaining in the print cartridges. Replace any print cartridges that
are low or empty. Messages are not created for non-HP print
cartridges.
If you are using non-HP print
cartridges, one or more print
cartridges are low or empty. The
control panel lights do not indicate
low or empty for non-HP print
cartridges.
Replace one or more of the print cartridges.
Font DIMM might be selected but the
font DIMM is not physically installed in
the printer. (This issue applies only to
printers using an Asian-language font
DIMM.)
In the settings for this printer, clear the Font DIMM check box on
the Configure tab if no font DIMM is installed in the printer. Select
the Font DIMM check box only if the font DIMM is physically
installed in the printer. If you think that the font DIMM is installed,
make sure that it is installed correctly.
The paper curls when
exiting the top output
bin.
The paper needs to print to the
straight-through paper path.
Open the rear output door to print to the straight-through paper
path. Remove each sheet as it exits the printer.
The stack was slightly curled when it
was placed in the tray.
Turn the stack over in the tray.
The paper does not meet
specifications.
See the user guide for information about print-media specifications.
If you are printing on light media, the
Type setting might not be correct.
Select Light in the Type is field in the printer driver.
Nov 13, 2008 | HP LaserJet 1500L Printer
Lexmark 1270
Could be your INK cartrage'is empty.or just cloged clean .it
hope that help you
Oct 28, 2008 | Office Equipment & Supplies
HP DesignJet 500 InkJet Printer Logo
12 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
