Why is my epson ex3220 is flickering green?
Why is my epson ex3220 flickering green? I did a factory reset and I still have issues. I have only owned it for a little over 3 weeks.
LCD TV picture issue at start up.
Fault at its main digital board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts.
In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary.
Before going further; try a hard reset first. If it does not help you, replace the main digital board. There are two methods to reset TVs. The first is simple to do; a Hard Reset. The other is somewhat skilled; is a Factory Reset (System Reset). To make it a hard reset, just unplug the TV from AC mains wall socket, and re-plug it back after 15 minutes or so. If you do this by overnight is better. This procedure will make it a hard reset. If you want to make it a system reset [Factory Reset]; you have to enter its service mode option, and select the factory reset option. If you wish to get some details; visit the site linked here.
Jul 05, 2016 | Samsung Televison & Video
My son forgot his password tryed the code several times now it wants me to put email and password and he dosnt remember that eaither
If he has the device linked to a Google account that he also used on another device you may be able to fix the issue using the other device (or computer). If this is an option, and you can access the linked account, you can either go to 'Settings' + 'My Devices' or reset forgotten password for email. If he's backup in cloud you could do the factory reset without fear of losing all of his data. Reply for further assistance. Please click the green tag below if this helped you to resolve the issue.
Thanks & Good luck!!!
May 31, 2015 | Tablets & eReaders
Epson projector green screen
Try a different cable. Sometimes the pins go bad on VGA cables. Also try factory reset.
Aug 11, 2014 | Epson Office Equipment & Supplies
Monitor intermittent power problems. Horizontal green flickering lines
You have to check the ESR in tha caps in power supply with esr meter.
If you dont have one just replace all capacitors in the power section(there are severals of them)This is the simptom of low esr in the capacitors.
Return the monitor in factory settings.
Jan 28, 2014 | Dell Computers & Internet
Dashboard lights flickering 2014 Honda Pilot - 3 weeks old
Go back to installer & have him inter grate the system better ? sounds like factory alarm responding not absorbing.
Dec 23, 2013 | 2000 Honda Civic
Factory reset
this question is best answered by the epson site
http://www.epson.com/
Aug 16, 2013 | Epson Stylus Photo 1280 InkJet Printer
No picture, No sound
It sounds that the IIC Bus circuit shorts bey some faulty components connected to it. The troubleshooting work to this section circuit is very skilled one. If you are not familiar with electronics, do not attempt to repair. Whether you suffer fatal electrical shock! Instead, contact the nearest service center.
Feb 11, 2013 | Digital Lifestyle FA1B32Z 32 in. LCD...
My Bose SA-3 Amp is connected up right as it was working for months,now the green light is flickering different patterns and the remote wont work with it. It flickers fast,then slow, then in standby m
Unplug your Bose system for 5 minutes to reset the processor ic, now plug back in, if no change! contact Bose, this is a product that is only repaired on site at the factory and they have the parts.
Apr 23, 2012 | Bose Lifestyle SA-3 2-Channel Amplifier
I own a KP-57HW40 set that has a color and shut off issue. Started as a green tinge problem to the screen after watching for a few hours. Started becoming more and more frequent a couple months ago....
IF YOU HAVE A RA 6 CHASSI THE TUBES RUN HOT ANOID CATHOD SHORT IF YOU TAP ON THE NECK OF THE TUBES AND GOES TO SOLID COLOR THEN SHUTS OFF YOU HAVE TO REPLACE THAT TUBE ALL 3 TUBES WILL HAVE THIS PROBLEM
Feb 09, 2010 | Sony KP-57HW40 57" Rear Projection...
62 people viewed this question
k24674
jasbo
jasbo
