Question about Duracraft Dura-Craft Dollhouse Kit SAN FRANCISCAN Duracraft
Missing sheet #22 have 2 of #23 but no #22 how can i get it
I am missing sheet #22. I have 2 sheets of #23 but no #22. Can you tell me how I can get it?
    Renaissance:
    An user who is expert in 3 categories / brands.
  • 1,554 Answers
Posted on Apr 02, 2014
Testimonial: "No. I'm not missing the instructions. It's the #22 sheet for the house. I think it has 5 windows on it and something for the floor. It's part of the house."
Sheets I bought are not the size on the package
Someone probably switched them in the store. I now a local store had to post signs telling people to not open sets because people kept mixing queen sheets in a twin bag to get an illicit discount. Take them back and explain to customer service what happened. Likely not the first time.h
Jul 05, 2015 | BrylaneHome 400 Tc Hemstitched 4 Pc. Sheet...
Skiping nails
Usually caused by weak feeder spring, however if new spring does not fix problem then check or replace orings on the feed piston (3 orings) , replace the driver oring and make sure that the driver sheet seal is not broken. The sheet is located at the very bottom of the inside of the cylinder area. If good, the driver will not pull out of the gun from the top of cylinder. To see the condition of the sheet, gently pull up on the driver just enough to look down the cylinder past the bumper. If the sheet is missing a piece, air leaks past the driver and does not push the driver all the way back up to top of cylinder causing miss-fire. Good luck
Sep 09, 2013 | Hitachi NV45AB2S Coil Roofing Nailer
Miss feeds when print multilpe pages
The paper feed solenoid is sticking, it can be seen thru a hole in the back with the door opened. Not easy to get to, but I have been able to bend the stop tab slightly and run just fine.
Sep 02, 2009 | Konica Minolta magicolor 2300DL Laser...
Problem in color printing
I suggest making sure you installed them correctly, you can take them out and put them back in, it will ask you if you just replaced the cartridges one by one "select yes" if they are new, then try to print out a test sheet (which you do this through one of the options in your "menu" on the machine itself, it should be in your manual or you can look online in the Brother 240-MFC troubleshooting tips for printing, this just happened to me a few days ago and I got the answer there. So, when you print out the test sheet it will probably have colors missing and you say "NO' that it is NOT GOOD, and then it will do another cleaning and then print out another test sheet and hopefully it will work then, otherwise tell it NO again and have it do another cleaning, sometimes it does take a few times. This happened to me the other day when I replaced a black ink cartridge and I could not get ANYTHING TO PRINT, it kept coming out BLANK PAGES, so I went to the troubleshooting tips on the website and this was the advice I was given, it took THREE CLEANINGS and three test sheets before the black boxes printed out fully on the test sheet with none missing and ONLY THEN was I able to print successfully, GOOD LUCK TO YOU.
Jun 16, 2009 | Brother MFC 240C All-In-One InkJet Printer
Printer will only print in purple/pink,enstalled new colour cartridge configured as required,still no change. help thank you
Print out a calibration sheet, either from the menu, or press photo and cancel at the same time. Your calibration sheet is probably missing a color. You should have black, blue, yellow, and magenta(pink). If you're missing any of these colors, your printhead is clogged. Try doing a printhead cleaning. Print another calibration sheet, if the color is still missing, you need a new printhead. Call Kodak.
Sep 30, 2008 | Kodak EASYSHARE 5300 All-In-One InkJet...
Excel question
You can import data from one sheet to another. If you want to bring a total from Sheet 1 to Sheet 2, then in Sheet 2 enter [=sheetname!cell] (without the brackets of course. You will now have the data from Sheet 1 in a cell in Sheet 2 and you can do anything you want with it. One note: if the sheet name has a space in it (Sheet Name) you have to enclose the name in single quotes; that tells it that the whole thing is the name. For example, Monthly Sales, A10 is the total for last month; to put it in this month for a running total, you would enter in Sheet 2 ['Monthly Sales'!A10] (without the brackets again). Now you can have a running total between the two sheets.
Aug 19, 2008 | Excel (SS8SATAS5128400R)
Hp 2200 laser printer tray 1 paper delivery from top
Are these printers designed to handle Legal sheets?
Did you tell the Printers Software that you will be sending Legal size sheets to this printer?
Apr 10, 2008 | HP LaserJet 2200dn Printer
Duracraft Dura-Craft Dollhouse Kit SAN FRANCISCAN Duracraft Logo
140 people viewed this question
Top Duracraft Toys Experts
ray gallant
Are you a Duracraft Toy Expert? Answer questions, earn points and help others
