Casio mtd 1010
SOURCE: Casio GW300 (2608) battery replacement
Hey all. The charge provided by the solar cells on the watch only really extend the life of the battery. The total run time of a battery depends on how the watch is used... backlight requirements etc. The battery will be depleted and need to be replaced.
Here is a site that has good instructions on how to change the battery in your G-Shock watch.
http://forums.watchuseek.com/showthread.php?t=20217
If you want to ensure you still have a the same water resistance rating, I do suggest that you take it to a watch guy to have it replaced for you. They clean switch contacts also and you keep water resistance rating. Good Luck and vote this as a "FixYa". Cheers
regards
Graeme
SOURCE: Casio watch
Press MODE until you reach H-S (e.g. A 11:00 with seconds on top)
Press and hold ADJUST for 3 seconds until H-S blinks
Press and hold SEARCH for every movement; you may wanna press LIGHT so the hands will move freely. Press ADJUST again to when desired time was reached
SOURCE: lost maual to amw-700 casio watch
advance the mode 6 times to H S mode and push left upper button till the digital time flashing, then push rigth doun or up buttons to advance, please read manuals
SOURCE: I just replace the battery
Hi, I just encountered the same problem today as I was changing the battery and I found the solution. First make sure when you are changing the battery that the watch stem is pulled out; then after the battery has been replaced, and before you put the gasket and back on you will need to "reset" or "hotwire" the battery ....you are going to likely need a magnifying glass to find a tiny ac symbol on the back of the watch (without the back cover replaced)...just next to the ac symbol is a tiny hole. Take a piece of wire, or in my case I used an unfolded paper clip, and put one end of the wire in the hole and the other end on the back of the battery (the +/positive side should be facing up). Leave the wire in contact with the ac/battery for 5 seconds, then remove. Next replace the rubber gasket, then the back and the screws. Lastly, push in the watch stem. Your watch should now work. I found out through considerable research that almost all digital watches will need that "hotwiring" step performed after the battery is replaced.
dcraigpa
SOURCE: battery replacement
You can do it yourself. Unscrew watch caseback and undo the contact on top of battery. Read the writings on battery and buy exactly the same one. Do not mind manufacturers (Casio, Maxell, e.t.c.), just make sure the numbers are the same.
Some watch casebacks can be opened only if the watch band is removed, so, remove it if needed, just don't forget to memorize where every part and screw was fitted. Memorize how the battery is fitted and do not put the new one the other way around as this can damage your watch.
Actually there is nothing difficult - only you have to put everything back exactly the same way as it was. If your watch will be left without battery for more than 3 minutes, you will need to reset your watch after replacing a new battery, but it's easy if you've got users manual.
Good luck.
Do not forget to rate, please.
Choose a quiet, well-lit room where you can replace the battery in your Casio Pathfinder watch. Prepare a table, desk or other clean, flat surface where you can perform your watch repair. Put down a soft cloth or piece of craft felt to protect the face of your Casio Pathfinder watch from being scratched during the battery installation process.
Set your Casio Pathfinder watch face-down on the soft cloth or craft felt. Use an optical-sized Philips screwdriver to remove the four screws that secure the watch back to the body of the watch. Set the screws aside, but don't lift the watch back.
Slide the watch back off of the body of the watch very slowly. There are three important springs held underneath the watch back; it is essential to remove the watch back slowly to avoid losing them.
Lift the three springs out of your Casio Pathfinder watch using a small pair of metal tweezers. Take note of the length and placement of the springs as you remove them. Set the springs aside with the other disassembled watch components.
Take the black rubber protective disk out of your Casio Pathfinder to reveal an identically-shaped white plastic disk. Remove the white plastic disk and set it and the black rubber disk aside. Use your metal tweezers, if necessary, to lift out the rubber and plastic disks.
Release the battery strap that holds the battery in place in your Casio Pathfinder watch by pushing the battery strap latch to the left. Remove the old battery from your Casio Pathfinder using a pair of small plastic tweezers.
Pick up your replacement watch battery with the small plastic tweezers and insert it into the battery compartment of your Casio Pathfinder watch. Replace the battery strap and push it gently with the tip of your plastic tweezers to snap the latch in place.
Touch the "-" and "AC" terminals on your Casio Pathfinder watch with the tips of your metal tweezers for at least two seconds. This helps ensure that your watch will work properly once reassembled.
Put your Casio Pathfinder back together to complete the new battery installation. Start by replacing the white plastic disk, followed by the protective black rubber disk. Use your small metal tweezers to replace the small watch springs in their correct locations. Replace the back cover of your Casio Pathfinder, insert the four screws and tighten them with your optical-sized Philips screwdriver.
