Question about Panasonic NI-W410TS Steam Iron for 220/240 Volts Use
How to open thetop cover to cheak problem
Cant remore to cheak the problem how to remre the top cover panasonic electric steam iron model ni w410ts
5 Suggested Answers
oscarn
  • 110 Answers
SOURCE: My panasonic NI-R73NR iron went off and is not coming back on.
Check fuse in plug, check wire in plug for loose connection. Turn the thermostat a little higher to 'freeup' the contact mechanism. Check continuity with a ohm meter on the irom conacts, check lamp on iron
Posted on Sep 21, 2007
jmgldsmth
  • 2005 Answers
SOURCE: Panasonic Iron won't heat
most iron cases can not be seperated from the iron plate but, if you can take off the bottom plate you will see a heating element and attached to that a small cylinder it has a point on one side and a flat end on the other it is called a thermal fuse and radioshack sells them
they are made in different versions so take the fuse in to get the right one clip it back in and your iron should work again
Posted on Apr 24, 2009
  • 13 Answers
SOURCE: Panasonic Iron NI-R73NR will not heat up
Either a bad thermostat or a bad heating element or an open connection somewhere in the power cord. My advice, toss it!
Posted on Aug 27, 2009
heatman101
  • 43501 Answers
SOURCE: Panasonic NIA56NR NI-A56NR Iron shut off and wont
Here is a tip that will help you to troubleshoot your iron and figure out what is wrong with it.
Electric Iron not Heating Up or not Working Right
http://www.fixya.com/support/r5300202-electric_iron_not_heating_up_or_not
heatman101
Posted on Jul 14, 2010
Panasonic steam iron NI-L70SR repair
hope this helps you: http://www.theironingroom.com/help-my-iron-is-leaking-water/
May 24, 2017 | Panasonic Irons
How do i increase the iron heating temperature (thermostat) in Panasonic Electric Iron NI-22AWJ
Check the voltage at your power point, irons draw a lot of power. most irons have a temp setting switch cool med hot . If this a new iron return for service.
Feb 18, 2015 | Panasonic Irons
I have black burn on the soleplate of my iron that nothing seems to get it off. any suggestions
Here is a tip that will help you with cleaning the sole plate of your iron...
Cleaning a Steam Iron Soleplate
heatman101
Dec 17, 2010 | Panasonic NI-C78SR Iron
Panasonic NIA56NR NI-A56NR Iron shut off and wont turn back on
heatman101
Oct 04, 2009 | Panasonic NIA56NR NI-A56NR Iron
NI-A57SR steam Iron suddenly not functioning
I had the same problem, when I took it apart, I noticed the theromstat points needed sanding. Just a reminder, make sure to write down the order of wire leads before disconnecting. By the way to test if the heating element is working connect white lead to the second connection from the left and black lead to the far right. Place your iron flat down on a wet cloth ( so that you won't burn your surface). You can also use an electrical tester. If heating element does not work though, it is time to buy a new iron.
Dec 31, 2008 | Panasonic NI-A57SR Iron with Auto Shut-off
Iron is out of order
an appliance repair center could probably fix it but you have to consider the cost against a new iron
mostly it is more costly to repair than to fix
Oct 19, 2017 | Panasonic NI-A57SR Iron with Auto Shut-off
How can I prevent my iron from leaving white residue on clothes?
white residue is caused by lime in your tap water.perfectly safe to drink,but when boiled [as in making steam] the lime is left behind. over timeit builds up in the 'tank' buy a gallon of distilled water from the grocerery-about $1 mix water with white vinegar,50/50 and 'steam it out' once or twice to remove deposits in the resevior.steam it out again w/pure distilled water.try it out on your husbands clothes before you iron your delicates again!!
Dec 22, 2008 | Panasonic NI-R73NR Iron
Water drips out of steam holes
I suspect that by placing it on its heel rest the water from the tank is not allowed to enter into the steam chamber and when you go into ironing mode there is a rush of water that is cooling down the sole plate to below steaming temperature. Try keeping it in the horizontal position on a heat proof pad and press the steam button just before going into ironing mode.
Sep 08, 2007 | Panasonic NI-H10NS Iron
Panasonic NI-W410TS Steam Iron for 220/240 Volts Use Logo
63 people viewed this question
Top Panasonic Irons Experts
Oscar Netto
Oscar Netto
Jim Goldsmith
Jim Goldsmith
Bill Boyd
Are you a Panasonic Iron Expert? Answer questions, earn points and help others
