Question about Gateway NV7915u Notebook
Laptop turns off
This problem is erratic, some times happens a lot, and some times only a few times, but it seems to be when playing video, fan is working.
  • 161 Answers
It could be over heating. Try vacuuming the vents of the fan. There are vents air is sucked into the fan and exhaust vents that the fan blows the air over coils that heat the air. The coils get dirty. The next step for overheating is taking apart the notebook and applying new thermal paste. Taking apart a laptop is very involved.
Posted on Apr 02, 2014
Testimonial: "Thanks irad, I will try some air cleaning, thanks againg."
Erratic mouse on toshiba laptop
The mouse maybe faulty, I suggest you use an USB optical mouse and plug it into the USB port on the laptop.
There is one fan in a laptop, it is located near the ventilation grill. You should feel the warm air existing the vent.
Feb 26, 2012 | Toshiba Computers & Internet
Hello, I had a few problems back about a year ago with my HP Pavilion dv2000 laptop, after a few weeks of looking for solutions I finally gave up looking and trying stuff. I see that there is more...
Hi, welcome to FixYa!
I also had this problem in my Toshiba A215. Does your HP Pavilion Dv2000 use AMD processor (and chipset) too? If that so, indeed this problem is caused by AMD southbridge chipset which often failed to load up all power before the BIOS is ready, that's why we get black screen not even BIOS is shown up. I noticed this some time happened when I restarted (or shut down) my laptop with 1 or more usb devices was still plugged into my laptop.
Second problem is definitely caused by the heat of the laptop. Yes, the heat can cause some problem the wireless device inside. This is often happened to with my Toshiba A215, especially when I had play game for a long time then suddenly my wireless (Realtek 8187B) was gone in my Device manager. Reinstalling driver didn't fix this, even restarting laptop also. All I can do is wait until the laptop become a lot cooler then it is working again.
I hope this information will be helpful. Thank you for using FixYa!
Mar 07, 2011 | Computers & Internet
G60-120US high temp problem
Laptop's temp should NEVER be higher than 60-70 C. Otherwise, windows or the CPU will shut it down (my laptop never goes over 75 C, even when running games for a short time)
A few tips:
1) Laptops are a really bad choice for games. They are not designed for that and they will overheat, some of them a lot, depending on the manufacturer.
2) Check if you BIOS has an option to turn "automatic fan control" OFF. This will keep the fan running at HIGH all the time, helping somewhat with the heat (most laptops do not have this control in the BIOS)
3) Clean up the fan. Turn the laptop off, disconenct the AC charger, remove the bottom cover and blow compressed air from a compressed air can. Be sure to remove all the dust and lint. Check that the fan moves easily. Replace the cover, plug the AC charger on and try again.
4) REMOVE SPEED FAN and install CPUID's Hardware Monitor from here:
http://www.cpuid.com/hwmonitor.php
It's much better and it gives you the temps of CPU, HD and video card and also speed of fan(s)
Mar 27, 2010 | HP G60-120US Laptop
Ok I have a problem when i turn my dishwasher on.
Hi.
Check that machine is getting filled sufficiently. Check the water level sensor and switch.
Check that the inlet valve is working.
Ensure that the hose to the impeller pump is not blocked.
Ensure that the sprayer assembly is OK.
If all that is OK, and the problem is starting erratically , then it is often a faulty control board.
Dec 02, 2009 | GE Nautilus 24" Built-in Dishwasher
Laggy display after a few minutes play
lot of the game now a days require a pretty big video card. A 5200 is outdated and i know u cant upgrade your laptop. The best solution to this is increase the amount of RAM in your laptop to the max. When you run games lower the video settings to low or medium. Another thing that can help is running msconfig in the RUN box and turning off lot of apps that run in background
May 19, 2009 | Nvidia Geforce FX 5200 Graphic Card
Laptop screen turns white
You can put your laptop on top of a icepack, cause your Graphics card is probably getting to hot. Thats why your screen turns white(probably only when gaming).
It is likely one of your fans is broken
Feb 24, 2009 | Compaq Presario X6000 Notebook
Transport erratic - machine cuts out on PLAY/REW/REC
A machine reset (unplugging- (x1 wk)) temporarily seemed to fix; some probls returned after 24 hrs.
Technician series text suggest probl may be Tape Load reel (gears, worn belts), tape slack sensor,
mode switch, etc. In other words, machine needs overhaul due to lack of maintenance. [ But where to get necess parts???!! ]
Audio & picture still perform well. Suspect snow dropouts due to tape age (at least late 1980s) & oxides.
/K_M
Nov 18, 2008 | GE VG4267 VHS VCR
Nothing but a blue screen...ugh!
buy a cleaning cassette and play three times it will work well.
Oct 12, 2008 | JVC COMPACT VHS-C CAMCORDER
Laptop Overheating
i have read lot of same type of problems,with acer,if it is under warranty send it before end, there is fee of 449.00 for out of warranty notebooks. my 5100's have problems,very unhappy! with acer good-luck!
Jun 21, 2008 | Acer Aspire 5100 Notebook
NP9890 shut down
If it is an overheating problem try turning the laptop off, turning it over and placing a vacum on the fan grill on the bottom. Many laptops get a dirt buildup internally and this will sometimes suck out the dirt.
Jul 29, 2007 | Sager NP9890 Notebook
Gateway NV7915u Notebook Logo
60 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Matthew Spark
Matthew Spark
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
