Question about HP Color LaserJet CM6040f MFP Q3939A Printer
Laserjet cm6040f I replaced the fuser kit and still getting replace fuser kit message
I installed a new fuser kit and I still receiving a replace fuser kit message
leroyal
  • 2120 Answers
SOURCE: HP Laserjet Printer 4700 Fuser Error
Try unplugging the printer for 30 mins. You may still have a defective fuser.
Posted on Mar 12, 2009
SOURCE: hp 4650 n - New Fuser Kit
Under the menu>Configure Device>Resets>Reset Supplies>New Fuser Kit
Posted on May 05, 2009
  • 99 Answers
SOURCE: Seems to jam in fuser, fuser has been replaced
if it always jams at the same place (fuser area) try another fuser or check the BLACK PLASTIC ASSY. THAT is mounted in the left door and takes the paper right after it comes out of the fuser ;part is called (PAPER DIVERTER) And sometimes one of the FLAPS That routes the paper is broken,hence causing paper jam.
Posted on Aug 01, 2009
  • 39 Answers
SOURCE: Replaced black ink cartridge and printer keeps asking to replace
The message that persists in saying to "replace black cartridge" could be due to a defective cartridge chip. The chip maintains counts and tells the printer when a new cartridge is installed. If you cartridge is remanufactured, they may have neglected to install a new chip.
Regarding the new fuser not working, I'll have to get back to you on that.
Posted on Feb 19, 2010
  • 1684 Answers
SOURCE: I just replaced the fuser
The 50.2 error is a warm up error meaning the fuser is not coming up to temperature correctly. This can be caused if the fuser is not fully seated in the connector. To check this just power off the printer, remove and re-insert the fuser into the printer. Test it out, if it still has this error then the fuser heating element or temp sensor is bad. Is the fuser a new HP or rebuilt fuser? Some of the rebuilt ones may have quality issues.
I hope this helps, if so please rate my solution.
BuddyMc
Posted on Sep 06, 2011
Printer keep says replace fuser kit
These is a part on the fuser called a fusable link that blows the first power up cycle and resets the replace fuser message. It sounds like the fuser you installed is a remanufactured unit that was not professionally rebuilt. Contact the place of purchase and get a replacement. The message can only be reset with the fusable link on the fuser.
Feb 13, 2012 | HP LaserJet 4700 Printer
I keep getting a "replace fuser kit" message on my
If you replaced with new fuser even getting same error, then check,
>Check the fuser connector (J5001). If
it is broken or damaged, replace it.
>. Check the connector (J1025) on the
DC controller PCB.
>. Replace the DC controller PCB.
Oct 07, 2011 | HP LaserJet 4700 Printer
I have a HP LaserJet 6040 with this error message 59.30
59.30 means that the fuser motor experienced a start up error.
If power cycling the printer won't clear the error you probably need a tech to troubleshoot and/or replace the motor.
Sep 16, 2011 | HP Color LaserJet CM6040f MFP Q3939A...
I have hp colour laserjet cm6040f mfp, that displays error 50.A fuser error. pls your help is so much important
You will need to order a fuser and replace it or call a service tech who can. The problem is that the electronics on the fuser have actually burned out, so that is why the whole fuser needs to be replaced.
Aug 29, 2011 | HP Color LaserJet CM6040f MFP Q3939A...
The hp colour laserjet cm6040mfp is displaying error 50.0 fuser error. pls i need ur assistance on it.
> FUSER ERROR
The FUSER is the part of any dry-ink laser-printer. It heats up, and melts the dry-ink onto the paper.
So, an ERROR indicates that the fuser is NOT reaching its "working" temperature.
Replace the FUSER, or take the printer to a qualified technician for remediation.
Aug 26, 2011 | HP Color LaserJet CM6040f MFP Q3939A...
HP laserjet 3600 error message 50.9 Fuser Error
Thank you for the inquiry.
Yes you will probably have to replace the fuser. If this is a new printer still under warranty and the page count has not reached the service life of the fuser, contact HP for warranty replacement. Once the new fuser in installed you will need to restore the service count.
nav?h_pagetype=z-001&h_lang=en&h_cc=us&h_client=z-a-r1002-1&h_product=501046
Fuser Kit Part Number: (Sometimes Called a Maintenance Kit)
RM1-2665 This fuser is compatible with the following printers: HP Color LaserJet 2700, 3000, 3000N, 3000DN, 3000DTN, 3600, 3600N, 3600DN,
Link to Installation pictures and instructions:
http://printertechs.com/tech/mkinst/3000/mk-3000-2fuser.php
Restoring the maintenance count after installing new fuser.
This printer tracks the number of pages printed on the fuser, and a reminder message will appear when the fuser reaches a certain page count. The message will instruct you to replace your fuser. Whenever you install a new fuser, you should reset the fuser page count so the warning message will not appear prematurely.
To reset the fuser count :
1. Press MENU to enter the MENUS.
2. Press Down arrow to highlight Configure Device.
3. Press Checkmark to select Configure Device.
4. Press Down arrow to highlight RESETS.
5. Press Checkmark to select RESETS.
6. Press Down arrow to highlight RESET SUPPLIES.
7. Press Checkmark to select RESET SUPPLIES.
8. Press Down arrow to highlight NEW FUSER KIT.
9. Press Down arrow to select NEW FUSER KIT.
10. Press Down arrow to highlight YES.
11. Press Checkmark to select YES.
The fuser count will be reset and then the printer is ready to use.
Thank you for being a FixYa Valued Customer.
Hope this helps helps. Please keep us updated and remember to rate this answer.
TF
Jan 19, 2011 | HP LaserJet 3600 Printer
Oct 15, 2009 | HP LaserJet 4600dn Color Printer
Hp 4650 n - New Fuser Kit
Oct 28, 2008 | HP LaserJet 4650n Printer
HP Color LaserJet CM6040f MFP Q3939A Printer Logo
81 people viewed this question
Seeker5211
Seeker5211
