Question about Frigidaire Washing Machines
I have replaced the valve and the main computer but the water still won't fill up. All u hear is clicking noises and the u can see the basket turning
The model I have is gltf294ofs1
  • Official Brand Answer
  • 4,342 Answers
Hello Jessie,
I see that you have been having trouble getting your Frigidaire washer, model# GLTF294OFS1, to fill with water, even after changing out the valve and the main computer. I would suggest contacting your local authorized technician from this point. They will be able to assist and possibly find out exactly why your washer will not fill with water.
-Best Regards-
WP
Posted on Apr 04, 2014
Kenmore 11025102310 washer isnt working. I press the start button, and the sensing button lights up for just a second and there is a couple of minutes of a grinding type of noise but then nothing.
SENSING Page 5
When the START/PAUSE/Unlock Lid is pressed, the washer will first perform a self-test on the lid lock mechanism. You will hear a click, the basket will make a slight turn, and the lid will unlock briefly before locking again. Once the lid has locked the second time, the washer will use short, slow spins to estimate the load size. These sensing spins may take 2 to 3 minutes before water is added to the load and you may hear the hum of these spins. If the sensing light is on, then washer is working properly. You will hear the motor turn the basket in short pulses to thoroughly wet the load. The washer will then move the load briefly, pause to allow water to soak in to the load, and resume adding water. This process may repeat until the correct amount of water has been added for the load. You may also hear water flowing through the dispenser, adding detergent to the load.
NOTE: Avoid opening the lid during sensing. The sensing process will start over when the washer is restarted. The sensing light may also come on during the Soak and Wash portions of the cycle. This is normal.
If there's no water, then Page 13
Washer won't run or fill, washer stops working, or wash light remains on (indicating that the washer was unable to fill appropriately)
Check for proper water supply.
Both hoses must be attached and have water flowing to
inlet valve.
Both hot and cold water faucets must be turned on.
Check that inlet valve screens have not become clogged.
Check for any kinks in inlet hoses, which can restrict water flow.
Or you have an inlet valve that is not working
Apr 29, 2016 | Kenmore Washing Machines
Replaced viable but no water filling just clicking noises
DISCONNECT THE ELECTRICITY , DISMANTLE THE INLET WATER HOSE CHECK THE WATER COME OUT, CHECK THE VALVE STRAINER ,CHECK THE VOLT ON THE VALVE IF THERE IS , REPLACE THE VALVE
Apr 02, 2014 | Frigidaire ATF6000ES Front Load Washer
Whirlpool lsb6000pq2 washing machine won't fill with water
Humming could be a blockage on the fill solonoid valve remove water fill hose and clean the filter at the valve it pulls out or use an old toothbrush
Jun 26, 2012 | Washing Machines
MY GE front loader washer won't fill with water or spin. I hear a hum when I turn it on and it sounds as if it's about to start a cycle but nothing happens.
It sounds as if your water valve is either clogged or the solenoid is stuck and not letting any water in. Here is a checklist of things you should do to help isolate the problem:
1) check to make sure the water is on
2) turn the water off and remove the water lines and verify that both the lines and the screens on the valve are clear of debris, calcium, etc.
3) take the top off the machine where you can actually see the valve, turn the machine on and see if the vavle is the humming noise that you are hearing. If so and no water is coming out then the valve is bad.
May 19, 2012 | GE Washing Machines
Just moved front load beaumark washer into a new house, and it won't fill with water. the display lights up and you can here washer trying to fill (humming noice). All display lights come on and it...
It sounds like your water inlet valve is either not getting a signal to let water in from your control board or the water inlet valve is defective. Since you are hearing a humming noise, I would say that the water inlet valve is defective or has been damaged in transit.
Jun 18, 2011 | Frigidaire ATF6000ES Front Load Washer
NOT FILLING THE WATER
Is there a faint buzzing or humming noise coming from the water-inlet valve? (The water-inlet valve is the device on the washing machine that the fill hoses are attached to.) If you can't hear anything, the water-inlet valve may not be getting any power. If you can hear some noise and there's water present, you may need to completely replace the water-inlet valve.
Dec 14, 2010 | GE WPGT9360EPL Top Load Washer
Dishwasher makes squeeling noise when filling with water
if the dishwasher is only filling when u hear the noise it could be a bad water valve or if you are lucky it could be the screen in your water valve is dirty, however if it is filling and washing at the same time and you hear a noise like sqeeling it could be your motor, before u replace the motor. check the water valve or screen on valve may be dirty
Sep 16, 2009 | Frigidaire 24 in. GLD2350RC Energy...
I can hearing brewing noise, but no water filling the carafe
IF UNIT IT`S MORE THAN 4-5YRS BUY A NEW MODEL, U SAVE SOME MONEY FOR THE NEXT 5YRS
Aug 19, 2009 | Coffee Makers & Espresso Machines
My pool pump won't prime
If the pump is above the pool water level the it is unlikly that the tank will fill completely with valves open (which is ok).Most pumps are self priming and will pick up a prime with water level below suction inlet on strainer. Try starting on main drain again and slowly open skimmer line. Did you remove water from skimmer line and winterize(if in cold weather climate)during closing?.I know this sounds stupid, but make sure water level in pool is well into skimmer. If air situation remains after scspriggs' and these thoughts then prepare for a pressure test on skimmer line to determine location of leakage.
Apr 21, 2009 | Hayward 3/4hp Super Pump Inground Pool...
Wptg9350c profile harmony washer- hot water slowly fills washer
That is not normal. Usually this happens because of a faulty inlet valve or because of a faulty control/timer board. The inlet valve is tested first and eventually replaced.
If the valve is ok , then proceed in testing the timer board.
Apr 17, 2009 | GE Profile Harmony WPGT9360E 4.0 Cu. Ft....
Washing Machines Logo
95 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
