Question about Craftsman YT 4000 42" Briggs Stratton 24 hp Gas Powered Riding Lawn Tract
MY 24HP CRAFTSMAN TRACTOR IS LOSING POWER AND OVERHEATING
As I was mowing I began to notice that my tractor losing power and couldn't make it up the slightest hill. Today it seems to have gotten worse and smells as if it is overheating.
    Habit-Forming:
  • 34 Answers
Hi, With the good information you provided, inability to climb and an odor, I think your transmission drive belt is slipping on the pulley causing it to emit a "burning rubber" odor. With the belt slipping, the tractor will not transfer power from the engine to the transmission properly and cause the symptoms you are experiencing. You will need to remove the mowing deck and verify the worn belt and install an OEM replacement. You may wish to have this repair done at your local small engine repair shop. The belt will likely cost about 50.00 and about an hours labor to remove the deck and remove/replace the belt. If I can help any further, feel free to respond or message me and I will help any way I can. Have a good day!
Posted on Mar 16, 2016
    Problem Solver:
  • 20 Answers
Gas oil and filters ...remove gas replace w fresh regular 87 octane then change spark plug simply walking in any auto store with plug in hend will be best if you dont know which to buy then check oil make sure to wipe dip stick and check oil after that finnaly replace the air filter your not far from burnning you engine you are most likely to be out of oil the fresh gas and oil are the most important but filter and plug will help things run smother check your oil and filters regularly if you use every day once a week oil check once a week or bi-weekly once a month and befor use after storage
Posted on Apr 14, 2014
SOURCE: TRACTOR BLEW WHITE SMOKE, AND STARTS TO SPUTTER
Start with making sure your oil lever is not over full. If it is it may be getting into the crankcase breather hose that goes to the carburetor hence the white smoke. Sometimes also you can blow a gasket in the breather system and it will do the same. Check for oil leaks in the breather system. Hope this helps. donnyb60
Posted on Mar 21, 2009
  • 246 Answers
SOURCE: craftsman 20.5 hp. auto trans.lawn tractor loss of drive power
Hello:
>>You can View a Breakdown/IPL of
this Engine at this Site Addy,
http://www.outdoordistributors.com/
and Select the H. Then Select Hydro-
Gear. Then Select Don't have Part
Numbers. Then Enter the Model
Numbers 319-0650. Then Select your
Model and Download the File for
Online Viewing.
From your Description it Sounds like the Internal Pump is Worn and is Loosing Pressure as the Unit Heats Up and the Components Expand from the Heat.
>>To View a Breakdown of this Unit Go to this Site Addy, http://www.searspartsdirect.com/partsdirect/index.action?sid=PSHx20080114x00001 and Enter the Model Numbers and Click Search. From this Page you can View Diagrams and Parts Lists for you Equipment Using the "View Sub Components" Section Near the Bottom Left.
Please, Do Not Hesitate, If you Hit a Snag or this Does Not Correct the Problem, I am Here if You Require More Assistance.
Hope this Helps. Let me Know What Happens, Please. May the All Mighty Bless You and Yours. Be Safe and Be Happy. Thanks.
Good Luck
Respectfully
jbridger (John)
Posted on May 11, 2009
  • 32 Answers
SOURCE: Craftsman lawn tractor mower,
The belt is probably slipping because it is not tight enough. look by the belt, inside there is a little spring, you may half to tighten it.
Posted on Jun 13, 2009
wadembly
  • 462 Answers
SOURCE: Craftsman LT 2000, model # 917.272234. When I am
what is happening tom is the blades are cutting more than the deck can discharge (spit out) try changing the mowing deck to a higher setting & try that if that works then that is the problem also try cleaning out the top & botton of deck there could be alot of old grass caught under there causing some of it aslo if i can further help e-mail me wade at wadembly@aol.com
Posted on Jun 28, 2009
wadembly
  • 462 Answers
SOURCE: Craftsman Lawn Tractor/ hard start/ whitish smoke
does it turn over slow or fast if it turns slowly thats the problem so it could be battery or starter they have to have a good amount of rpms to burn fuel right when starting if not it floods out the engine with gas hope this helps thanks wade
Posted on Jul 05, 2009
Husqvarna 24hp 54"yard tractor
Hi. Begin by checking your blades, if they are dull they must be sharpened or that alone will bog down the engine. Also time for a new air filter. Happy mowing. J.
Aug 01, 2010 | Husqvarna 24HP 54" Yard Tractor ()
White smoke coming out of mower
It sounds as though you are losing power (electrical power); see if charging the battery fully allows it to run longer or if charging the battery helps.
Jul 15, 2010 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
New Craftsman 20hp Briggs & Stratton 42" riding mower, Model 917.289104. Loses power, dies while mowing. Will not start unless sits 20-30 minutes. Problem began second time I owed with it. ...
first make sure the air intake screen on top of engine is not clogged with debris if thats not a concern you could have a faulty ignition coil etc your engine should have a two year warranty and can be serviced at no charge to you at your local briggs service dealer make sure and check your manual for the fine print though. Briggs makes a great engine and very rarely have I ever seen a problem allthough if you were to have an engine issue it will accur during the first few hours of opperation good luck
Jan 23, 2010 | Craftsman 20 hp 42 in. Deck Yard Tractor
I have a Craftsman lawn tractor model 917.287071 20 hp with very little use. It has been running great until now. After mowing today it began to sputter and load up and finally died. I allowed it to cool,...
no that solenoid is a anti dieseling valve, when you shut off the key, it closes the main jet to shut off fuel immediatly to the engine. sounds like you have an ign problem. im guessing its a twin, you need to get a spark tester... check each cylinder for a strong rythemic purple spark. if not present, replace the coil, of looks good try a set of new plugs. only other thing is a hole in a piston but in that case it wouldnt build enough compression to light out of the carburator. good luck!
Sep 03, 2009 | Craftsman 20 hp 42 in. Deck Lawn Tractor -...
Craftsman YT 4000 42" Briggs Stratton 24 hp Gas Powered Riding Lawn Tract Logo
207 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Dean Gruber
Roland W VanLue
Roland W VanLue
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
