Question about Kitchen Ranges
F9 error on ge Electric Range jsp42s0k4ss - Kitchen Ranges
Dipu007
  • 2110 Answers
SOURCE: F9 on Maytag range MGS5770ADB
Try unplugging the oven from the electrical power. May release the lock, which is held in place by a tiny micro switch. If not and while the electric is still off or the oven is unplugged, use a bright light flashlight to look through the slot where the lock is in the oven, not in the door.
You may be able to use a thin blade screwdriver to move the lock to the release position. Check the angle of the lever. A slightly bent lever handle also can cause this type of condition.
If all else fails, remove the access panel on the front of the oven to access the locking device and release it. May have to disconnect the wires to the lock which will allow door to function but not during any self cleaning modes.
Posted on Dec 23, 2008
fixyourboard
  • 310 Answers
SOURCE: I have an electric range, model # J SP42SOK4SS.
This means the controller is sensing a stuck key, which may be due to an actual stuck key or a problem with the controller. There is a way to diagnose which is the cause if you are comfortable tearing into the unit, or a repair tech can quickly diagnose for you. If you need a controller, you might consider having us rebuild it for you.
Regards,
Bruce
www.fixyourboard.com
Posted on Oct 10, 2009
localwonder
  • 6784 Answers
SOURCE: range displays error code f9-5
HI. This indicates that there are serious issues that concern the operational value of the main control abord(ERC/Clock).
This will require you to replace the ERC, asap.
ERC_(Electronic Range Control Board)
F9-5_Hardware conflict(watchdog)
Posted on Nov 08, 2009
EllaWatson25
  • 725 Answers
SOURCE: Getting Error Code f9-5 and f9-6 on MER6770
This is a bad electronic clock assembly and it is very simple to repair. You can save a lot of money by making this repair yourself, too!
Just contact us at:
http://www.fixya.com/repair/d499389-accurate_appliance_repair_service from 7 AM until 7 PM CST and we will get the correct part, as well part removal/installation instructions to you .
We look forward to working with you. Thanks, Ella
Posted on Jan 18, 2010
  • 403 Answers
SOURCE: What does "F9" on keypad signify on a GE JGBP35
Problem with door circuit. You may have a pinched wire between control board and door lock switch. Unplug range. Gain access to the control panel and unplug all connectors. let it sit for a minute. plug all connectors back in. examine wires going to the door lock, ensure that they are not pinched. check operation of the door lock. If problem persist, you may have to replace door lock.
Posted on Feb 08, 2011
F9 error
the F9 error code means that you have a problem with the door latch assembly in your range. The specific technical information on this failure in your model of Frigidaire range is shown in the image below. If you can clear the F9 by using the troubleshooting steps shown below then your range may resume normal operations. If the CLEAR key does not eliminate the F9 then you will need to try unplugging the range for 30 seconds. If the F9 returns when you plug the range back in, then you will need to replace the door latch. Here is that part to order.
To continue to troubleshoot this problem yourself, then you will need to unplug the range and check the wiring between the door latch assembly and the electronic oven control board. Remove the back panels to access these components. NOTE: Internal metal edges and the sides of the back panels can be sharp.
Feb 13, 2013 | Frigidaire PLEF398AC Electric Kitchen...
F9 error code on ge jsp47 oven
F9 Problem with door lock circuit. Check all wiring connections. If all look good replace the door lock. Here is the part to order.
Feb 13, 2013 | GE JSP47 Electric Kitchen Range
While upper oven cooking the door will lock and f9 appears. what would cause this?
Hi
Thanks for using FixYa. F9 error in your oven/range indicates an issue with the door locks assembly and/or the door latch. To start with check the door lock circuit, you can also try to jump start it to see if it's working. If it's not working then the Electronic Range control has gone bad and should be replaced, if it is working then the door lock circuit should be replaced. Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Sep 16, 2010 | GE Profile JT952 Electric Double Oven
F9 error message during self cleaning cycle
Hello,F9 error means there is a problem with the lock switch.Check the wiring to the door lock switch (the wire harness may be connected wrongly).Check for stuck lock switch.
Thanks
May 31, 2010 | GE Monogram ZET3058SHSS Stainless Steel...
Range displays error code f9-5
Nov 08, 2009 | Maytag MER6772 Gemini Electric Kitchen...
Frigidaire Mod.FEF369CGTE, F1 and now getting F9 please help
Hi n5my ,
F1 =  Electronic oven control failure
Sol. Replace electronic oven control (also called EOC or clock).
The "F9" error code means the EOC (electronic oven control) has found the lock motor switches to be out of sequence or shorted.
Test switches and if there is nothing wrong then replace the EOC.
both of the error indicates the problem in EOC.
Regards
R.K.
Oct 16, 2009 | GE Spectra JBP78 Electric Kitchen Range
Electric range is over 15 years. F-1 on comes on and will not
Frigidaire mod FEF369CGTE range F1 came on and now the showing F9
My GE Oven JTP 14 displays an F9 error and shuts off.
F9 error - Lock switch error.
Resolution - Check wiring to door lock switch (the wire harness may be connected wrong). Check for stuck lock switch.
Hope i helped you.
Thanks.
Sep 02, 2009 | GE Profile JTP18 Electric Single Oven
Error code f9 on self cleaning range.
I get a f9 message when I turn my oven onto clean and then it shuts off and goes to clock...what's the problem
Oct 01, 2008 | Frigidaire PLEF398AC Electric Kitchen...
Kitchen Ranges Logo
21 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
paulcarew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
