Question about Frigidaire ATF6000ES Front Load Washer
Replaced viable but no water filling just clicking noises
We have replaced to He valve and the main computer but was Ter is not filling
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 101 Answers
DISCONNECT THE ELECTRICITY , DISMANTLE THE INLET WATER HOSE CHECK THE WATER COME OUT, CHECK THE VALVE STRAINER ,CHECK THE VOLT ON THE VALVE IF THERE IS , REPLACE THE VALVE
Posted on Apr 02, 2014
My Calypso washer at the start I hear water filling tub. Then it stops filling and hear a moderate humming noise. I replaced water pump but still doing the same. Please help. Thanks
The problem is not the pump. IT appears that the water control valve is bad or the voltage that controls it is changing and then the valve stops working.
Dec 24, 2014 | Whirlpool Calypso GVW9959K Top Load Washer
Duet whirpool front loader is filling with water on its own
The washer fill valve is defective and will need to be replaced. The fill valve is right under the main top at the back the fill hoses attach to the valve.
Oct 07, 2014 | Whirlpool Duet GHW9150P Front Load Washer
Ive replaced 3 toilet fill valve with 440a Fluid master fill valves height is good water level good.After a while it sounds like there is leak by from all toilet.Flappers have been replaced. What coul
check the overflow pipe in the cistern tank as some fill valves do not stop completely but allow input of water after the noise has stopped. This allows the water level to rise up and the water to flow out into the toilet bowl. Reduce the water level height by adjusting the cut off level and when the water rises past the new level the increase pressure on the valve will shut it off.
Sep 16, 2014 | Fluidmaster 400A Toilet Tank Repair Fill...
I have replaced the valve and the main computer but the water still won't fill up. All u hear is clicking noises and the u can see the basket turning
Hello Jessie,
I see that you have been having trouble getting your Frigidaire washer, model# GLTF294OFS1, to fill with water, even after changing out the valve and the main computer. I would suggest contacting your local authorized technician from this point. They will be able to assist and possibly find out exactly why your washer will not fill with water.
-Best Regards-
WP
Apr 02, 2014 | Frigidaire Washing Machines
The water pipes have been freezing up for the past two nights, got them thawed out, and started a load of laundry set on cold. Washer started normal, it made a small click noise as allways, and the water...
Have you taken the hose off of the back of the washer and checked to see if you are getting water to that point. Also check the inlet screen on the fill valve to see if it is clean.. You may need to replace the fill valve. There may be a screen in the inlet of the hose at the shut off valves.....So check both ends of the washer hose..... I would check the hoses first before I would replace the fill valve....Hope this helps
Feb 12, 2011 | Maytag Washing Machines
Downstairs toilet won't stop filling, upstairs toilet won't fill
for the upstairs if the valve is fully on there is not much you can do other than replace water service to the house or heaven forbid repipe.Valves usually don't restrict fill volume.But you can take the supply loose from the tank and stick it in a bucket turn the valve on and check the flow.this should narrow it down.Down stairs repair or replace flush valve
Aug 04, 2009 | Home
Loud whistling noise when filling with cold water
First make sure your shut off valves for both hot and cold are fully opened. if so, the the screens inside the machine water valve where the houses attach need to be replaced. That would also be a good time to replace your original water fill hoses..
Jun 05, 2009 | Washing Machines
No water from the dispenser
You need to replace the dual solenoid one side is for the water the other is for the ice.
Jan 18, 2009 | Amana SXD524VW Side by Side Refrigerator
Frigidaire ATF6000ES Front Load Washer Logo
26 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Jason Harris
Jason Harris
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
