Question about Canon Office Equipment & Supplies
Canon mg6320 error code 5011
It tells me to cancel printing and turn off the printer, I check and there is nothing in the que turn it on - same issue
kittycat2002
  • 39 Answers
SOURCE: printer will not cancel print
try turning printer off then back on
Posted on Jun 30, 2008
Roop1980
  • 228 Answers
SOURCE: Error 1203
The error 1203 error message on the operator panel could indicate a problem with one of the ink cartridges. Please follow the steps given below:
1. Please make sure the All-In-One is powered on.
2. Pull the control panel towards you, and then open the cartridge access door. The print cartridge carrier moves and stops at the loading position.
3. Pull the old cartridges towards you, and then lift them out.
4. With the cartridges out of the printer, shut the access door and the control panel.
5. Power the printer OFF and then back ON.
6. Please check the operator panel to see if the same error has returned or if a new message has appeared.
7. If the message displayed is 1203, there is something wrong with the printer hardware.
If the message now displaying is Cartridge Missing, do the following:
1. Reinstall the cartridges into the printer.
2. Insert the color cartridge in the left carrier. Insert the black cartridge in the right carrier.
3. Push back firmly on the cartridges until they snap securely into place.
4. Close the cartridge access door, and then close the control panel.
5. If the 1203 message is still present on the operator panel, you need to insert one cartridge at a time to determine which cartridge is producing the failure.
6. With one cartridge in the carrier, close the access door and control panel.
7. Please check the operator panel. If the 1203 error is displayed, this cartridge is the defective item. If the Cartridge Missing message is displayed, the second cartridge is producing the failure.
8. Please replace the defective cartridge.
Posted on May 23, 2009
komguy
  • 2306 Answers
SOURCE: Canon MP480- 5011 - Printer Error Has Occurred After Scan/Prt
You need to carefully clean the encoder strip. It's the clear strip behind the carriage that runs all the way from right to left. A damp Q-tip should remove any grease or fingerprints.
Posted on Jul 16, 2009
komguy
  • 2306 Answers
SOURCE: says service error 5100 on my canon mp160 printer.
5100 is a carriage error, make sure there is no paper stopping the carriage from moving right to left, and then clean the encoder strip, behind the carriage, carefully with a damp Q-tip. Usually grease gets on the strip and gives you that error.
Posted on Jul 27, 2009
sushant079
  • 89 Answers
SOURCE: Canon MP490 printer error code 5011
You need to carefully clean the encoder strip. It's the clear strip behind the carriage that runs all the way from right to left. A damp Q-tip should remove any grease or fingerprints. that should solve it!!
Posted on Mar 22, 2011
I receive an Error Code 6901 on my MX725 printer, what can I do?
It usually means that it needs to be cleaned.
Take out the cartridges and look to see if there is build up.
That normally causes the error.
Apr 17, 2015 | Canon PIXMA Office Equipment & Supplies
How to solve canon printer mp280 error code 5011 ?
Was afraid this was the error that led me to toss a printer before. But after a quick search, found the following suggested fix for a potential registry problem. Problem with Windows Canon Mp280 Error 5011
Hope that does it.
Mar 02, 2015 | Canon MP280 All-In-One InkJet Printer
How do i fix error 5011?
The error message indicates that the print head may be stuck. Here are some answers I found for you:
Canon Printer Error 5011
Fix your printer
Dec 31, 2014 | Canon PIXMA MG4120
I want to print some thing and when I try to print it ,is appearin on my laptop error number 5011 . What did it mean ?
It indicates that the scanner bulb may not be heating up fast enough for the printer to work properly.
I found this fix on another forum. Sounds like it's worth a try:
With the printer off, press and hold power+cancel simultaneously,
Release cancel but keep power button pressed,
Press cancel button 4 times,
Release both.
I don't know what this does exactly, but it seems to reset something and make a fresh start, the printer will take longer to resume the power on sequence.
Nov 30, 2014 | Cannon Office Equipment & Supplies
Cannot get brand new printer to work.
This information is from a Canon, I don't see an error 5011. Only the following info. below.
"****" is displayed in the alphanumeric character and depends on the error occurred.
  • 5100/5110 is displayed:
    Cancel printing, and turn off the machine. Then clear the paper jam or foreign object that is preventing the Print Head Holder from moving, and turn on the machine again.
    Important
    • Be careful not to touch the components inside the machine. The machine may not print out properly if you touch it.
    • If the problem is not resolved, contact the service center.
  • In other cases:
    Turn off the machine, and unplug the power cord of the machine from the power supply.
    Plug the machine back in and turn the machine back on.
Nov 15, 2013 | Canon PIXMA MX860 OFFICE AIO-2.5IN LCD...
I can't print in my Canon Pixma IP1980... service error 5201. cancel printing and turn the printer off and then on again. if doesn't clear the error, see the printer manual for more detail. how can i fix...
service error 5201. cancel printing and turn the printer off and then on again. if doesn't clear the error, see the printer manual for more detail. how can i fix this?
Dec 08, 2010 | Canon Office Equipment & Supplies
Jul 16, 2009 | Canon Pixma MP480 All-In-One InkJet...
Won't stop printing
You need to delete doc from print server and from the print que.in the printer driver, then turn on printer and cancel job.
Dec 22, 2007 | Brother MFC-8840DN (Bundle) All-In-One...
115 people viewed this question
old marine
old marine
