Question about Hardware & Accessories
Apt timer how to set timer
  • 5,245 Answers
Lasko ceremic heater hot cord and melting
Yes it could be the outlet or the more likely wiring to it. If your apt has a maintenance preson have that person take a look if not call an electrician.
Dec 03, 2013 | Lasko 760000 Cyclonic Ceramic Heater, 750...
Tip
Ailurus in Ubuntu
Ailurus is an Ubuntu enhancement application.
It can install/remove software which is outside official repository,
Helps to add/remove third party repositories and can change system settings.
Moreover, it help you study Linux skills.
Add Ailurus in Ubuntu:
(1.A)
Applications> Accessories> Terminal
When you open this copy it (when you ask for your password, type):
sudo add-apt-repository ppa:ailurus
Update the source list (Terminal):
sudo apt-get update
Install Ailurus (Terminal):
sudo apt-get install ailurus
(1.B) Run Ailurus
Applications-> System Tools> Ailurus
(1.C)
Ailurus was originally named as “Ubun-student“, and “Ubuntu easy setuper“.)
on Jan 19, 2010 | Computers & Internet
My APT timer for my heating is not turning "as a clock"
Is this new installation?
If timer dial is not rotating, then timer is not wired correctly, voltage is wrong, or timer motor has stopped functioning.
If small motor used to rotate dial has gone bad, then replace timer.
http://waterheatertimer.org/How-to-set-timers.html
Add a comment with more information for possible follow-up
Mar 24, 2013 | Hardware & Accessories
I have the imm24 timer and would like a better quality timer which one will work
Imm24 timer is 230V 3500amp flush-mount hard-wire 24-hour mechanical-dial immersion heater timer
Following page shows imm24 timer and other brands of immersion timers
http://cpc.farnell.com/1/1/51662-immersion-heater-controller-box-imm24-apt.html
Prices are in Euros and Pounds, so I don't know distribution range of product.
Add a comment for more free help.
Also take advantage of fixya phone service.
For a price, expert speaks with you over phone while you work on timer or any do-it-yourself project.
Fixya is always less expensive than a service call.
Feb 03, 2011 | Hardware & Accessories
Good Morning - this is not a problem - only a question: how is the clock reset? I am renting an apt. and there is no owner's manual with the oven. There was a power outtage (happens pretty often) and,...
From page 9 of the user manual
This is a 12-hour clock and does not show a.m. or p.m.
To Set:
Before setting, make sure the oven and Timer are off.
1. Press CLOCK.
2. Press the TEMP/TIME "up" or "down" arrow pad to set the
time of day.
3. Press START/ENTER or CLOCK.
Oct 27, 2010 | Whirlpool RF364 Electric Kitchen Range
How install vlc in ubuntu
Graphical way
Open Synaptic (System -> Administration -> Synaptic Package Manager). In Settings -> Repositories, make sure you have an universe repository activated.
Search for vlc and install it. You should install vlc-plugin-pulse/ and mozilla-plugin-vlc as well.
If you are interested in streaming or transcoding, you should additionnally install libavcodec-extra-52 from amultiverse repository.
Command line way
You need to check that a universe mirror is listed in your /etc/apt/sources.list file.
% sudo apt-get update % sudo apt-get install vlc vlc-plugin-pulse mozilla-plugin-vlc
Oct 02, 2010 | Computers & Internet
Model WED5300SQ0 not heating and timer not working
Well with moving it around and all it could have any number of things happened. If it wont tumble, no lights, no heat or anything check that the plug has 240volts to it. then check the wiring going into the dryer may have broke wires or anything like that. but I would check the plug first if it has no power what so ever. If you check the plug and it doesn't have power check the breaker to see if it is tripped.
Sep 03, 2009 | Whirlpool LER5636P Electric Dryer
Can find drivers for intel 945 vga in ubuntu
Sir please add the following lines to your /etc/apt/sources.list:
deb http://ppa.launchpad.net/siretart/ppa/ubuntu jaunty main
deb-src http://ppa.launchpad.net/siretart/ppa/ubuntu jaunty mainImport the appropriate GPG key:
sudo apt-key adv --recv-keys --keyserver keyserver.ubuntu.com 0xce90d8983e731f79Install the driver:
sudo apt-get update
sudo apt-get install xserver-xorg-video-intel-2.4Now you should be set. Restart X by running "sudo /etc/init.d/gdm restart" in a terminal and see if the graphics performance from intrepid is restored.
thanx and i hope this helps
Please rate this solution
Jul 17, 2009 | ValuSoft Ubuntu Linux for PC, Mac, Linux
Soleus Heat/Air/Dehumidfer Unit
I have had a soleus wall unit since 2005.
It is a wall unit in my apt...I have never had to use the heating part...but use the cooler part alot.
I can not figure out if that lil raindropis for adding moisture to a room...or is it to remove moisture from the room?
My apt always has to much humidity, so I do use that setting quite often, but can't tell any difference in the humidity gage.
Who knows anything about using one of these.
Sep 02, 2007 | Soleus KY-34 Portable Air Conditioner
Hardware & Accessories Logo
Top Hardware & Accessories Experts
Gene Haynes
Hippy_dd
Are you a Hardware and Accessory Expert? Answer questions, earn points and help others
