Question about HP L1706 17" LCD Monitor
HP L1706 17" LCD Monitor problem
HP L1706 17" LCD Monitor different colors were displaying on the screen
4 Suggested Answers
  • 88 Answers
SOURCE: Hp l1906 LCD MONITOR SCREEN WONT DISPLAY. power
It is possible that the video card in cpu is bad, try hooking up another monitor to the cpu (computer) if you have one that will let you know if it is the monitor or the computer video card, Could be as simple as the driver is missing.
Posted on Feb 01, 2010
budmrtn
  • 11361 Answers
SOURCE: I have an HP LCD
Try this:
http://www.fixya.com/support/r4460477-hp_vs_15_17_19_f_1705_1905_lock
Basic LCD monitor and TV troubleshooting guide:
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
Failed TV and Monitors: http://s807.photobucket.com/albums/yy352/budm/
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Or www.digikey.com just make sure to use caps with low ESR, 105c, high ripple current, long life rating such as PANASONIC FM or FC series.
Posted on Dec 24, 2010
budmrtn
  • 11361 Answers
SOURCE: my monitor stays on but gives a greenish color.its
Does it do the same when using it with another PC?
Posted on Mar 24, 2011
No HD pic on Samsung HP-R5250
If your LCD TV or monitor has stopped working, or is displaying one of the following symptoms, then it's a candidate for some new capacitors
- Flickering screen
- Screen image disappears after several seconds
- Dim screen
- Slow start
- Power LED on, but no picture
- Unusual colors and/or lines
The primary cause of LCD TV and monitor failure is caused by faulty capacitors. You can examine the capacitors in your LCD TV or monitor and actually see if they are bad.
If they appear bulged on top, then they need to be replaced.
New capacitors will solve a host of problems in LCD monitors and TV's and will extend the life of your monitor or TV by several years.
Take it to a repair shop.
Apr 08, 2014 | Samsung HP-R5052 50 in. Plasma HDTV
White screen on hp w2007 LCD monitor.
Troubleshoot an HP LCD Monitor
HP makes a number of liquid crystal display, or LCD, monitors.
LCD monitors create an image by passing light through a liquid crystal solution that either blocks the light or allows it to pass through to a color filter.
LCD monitors are ideal for use with a computer as they present an excellent still image and cannot suffer pixel burn-in like other flat-screen display technologies.
Even quality monitors run into the occasional problem and need some basic troubleshooting before sending them in for service.
Check the power cord to make sure that it is plugged in securely to both the monitor and the outlet. If you are using a surge protector, remove it and plug the power cord directly into an outlet that you know is working.
Detach and reattach both ends of the cable running from your computer to your monitor.
If your HP LCD monitor has more than one connector, use the other one to make sure that the connector isn't the issue.
Remove any switch or extension cable that may be present between the computer and the monitor.
Restart your computer. A fresh start will correct many software issues.
Check the documentation of your video card to make sure that it supports HDCP, or High Bandwidth Digital Content Protection, since the screen may be blank when you are trying to watch high-definition content through a video card that doesn't support it.
Some older HP LCD monitors also do not support HDCP, so check your monitor documentation as well.
Go to your video card manufacturer's website and install the latest drivers for your video card. Instructions for installing the drivers will vary by manufacturer, but they should be listed with the driver software.
Change your resolution to a preset video mode to make sure that you aren't trying to operate the monitor in an unsupported resolution.
Different models of HP LCD monitors support different preset video modes.
All of the preset video modes for your monitor are listed in your monitor's manual.
Resolutions of 1024 x 768 and lower are supported by almost all HP LCD monitors.
Press the "Auto/Select" button on the front of the HP LCD monitor to correct any images that are dark or blurry.
If this does not correct the image, press the "Menu" button on the front of the monitor to bring up the on-screen display menu, where you can use the "+" and "-" buttons to scroll through the options and "Enter" to select the option that you want to change.
Adjust the brightness and contrast as needed by selecting them and using the "+" and "-" keys. Press the "Menu" button to exit the menu.
Press the "Menu" button to enter the menu, scroll to "Image Control" and press "Enter."
From here you can choose the "Auto-Adjustment" option and the HP LCD monitor will automatically adjust the horizontal and vertical positioning to center the screen.
The ability to adjust these settings is available only if you are using VGA inputs.
Contact your retailer or manufacturer for any additional troubleshooting steps for your particular model of HP LCD monitor.
If your monitor still has issues, you may need to send it in to be serviced.
HP Support
http://welcome.hp.com/country/us/en/support.html
Fix a White Screen on an LCD Monitor
When an LCD screen has turned completely white, there are three normal causes: the screen is defective, the video cable is not connected correctly, or the graphics card on the motherboard of the computer is faulty.
You will need to troubleshoot these possibilities to determine which problem you have.
If you are not experienced in working on computer equipment, you should not attempt to disassemble your LCD screen because you could easily damage it.
Seek professional assistance unless you have experience working on computer hardware.
Disconnect the white LCD screen from the computer by unscrewing the blue monitor cable. Connect the working LCD screen to your computer by attaching its blue monitor cable to the same slot.
If your computer display does not show on the functioning LCD screen, try rebooting your computer.
If it still does not display, the problem is with your computer's graphic card on the motherboard. Seek professional repair assistance.
If your computer display shows normally on the working LCD screen, proceed to Step 2.
Unplug the LCD monitor with the white screen.
Disassemble the rear panel of the monitor with the small screwdriver.
Carefully separate the screws into piles so that you can keep track of how to reassemble the monitor.
Locate the internal video cable, a gray cable with a plug on the end that connects to the main components of the screen.
See the References section for photos of the video cable for assistance.
http://www.laptoprepair101.com/laptop/2008/04/13/laptop-lcd-screen-turned-white/
Unplug the cable, checking for any debris or blockage.
Reconnect the cable firmly.
Reassemble the LCD screen. Plug it in and connect it to your computer.
If the screen is still white, you have a defective LCD screen.
You will need to replace it or take it to a professional repair service for assistance.
Without this test you'll have to guess because as I mentioned before this could either bad motherboard or bad LCD screen.
You'll have to disconnect the video cable from the LCD screen (connector 2) and the inverter board (connectors 3 and 1).
After that you connect another working screen and test video.
For this purpose I'm using one of my test LCD screens.
My test screen is cracked and because of that you see a wide white band in the center but it still works fine for this test.
The original screen is white but my test screen works normal (except the crack of course) and I can see the image.
After this test I can tell that the problem must be related to the screen.
After I assembled everything back together and connected the original LCD, it's still white.
CONCLUSION. In my case this problem is related to the LCD screen and it has to be replaced.
Aug 04, 2013 | HP W2007 20.1 Widescreen Monitor
Black screen with lights on
Try to plug a CRT or LCD monitor to your vga adapter (color blue) at the back below of your screen. If there is a display with external crt or lcd monitor that means your lcd monitor have a problem. In that case you need to replace your lcd monitor.
Please rate me.
Nov 19, 2010 | HP Computers & Internet
My HP L1710 MONITOR displays half blurred screen.
Put a solid color on the entire screen and use the Auto adjustment button.
Nov 04, 2010 | HP L1710 LCD Monitor
Dell E153FP monitor won't display any video from system (Dell GX260). My e173FP monitor works fine. E153FP powers up, runs Self Test Feature Test fine, menus all seem OK. Tried Factory Reset... still no...
You probably have tried this, but make sure monitor is set to correct display... i.e., Analog or Digital
Also, try starting in safe mode and verify Monitor is able to handle the display settings resolution
Apr 10, 2017 | Dell E153FP 15" LCD Monitor
Laptop monitor comes on bright whitish color
may be the LCD display of the laptopisgone or ur VGA adapter has some issues
Jul 26, 2009 | HP Compaq Presario C700T Notebook
My HP monitor (f50) has malfunctioned
Try these 2 steps if they don't work get back to me :)
Step 1. Connect the video cable and turn on the computer. What happens?
  • If the monitor screen remains blank (no startup screens or onscreen display messages), the monitor must be connected to another computer using a different cable to determine if the monitor is bad. Skip to the Step to connect the monitor to another computer.
  • If the monitor is capable of displaying boot screens but is unable to display Windows, use the following steps to set the computer to a compatible resolution:
    NOTE: Find the native display resolution for your monitor in the User Manual or in the product specifications for the monitor model. If you are unable to find the native display resolution for your monitor model, temporarily use 1024x768 for troubleshooting purposes.
    1. Turn on the computer and press the F8 key repeatedly when the first startup screen appears.
    2. If you are using Windows Vista, select Enable low resolution video (640 x 480) , press Enter , and wait until Windows opens. To set display settings that match the monitor, use the steps in the HP support document, Changing Display Settings, Background Image, and Screen Saver in Windows Vista . If you are using Windows XP, select Enable VGA Mode , press Enter , and wait until Windows opens. Continue using these steps to set display resolution. If you are using Windows 98 or ME, select Safe Mode and perform the following steps to enter into a standard VGA mode:
      1. Once Windows opens to the desktop in Safe Mode, click Start , and Run .
      2. In the Open field type msconfig and press Enter . The MS Configuration Utility window appears.
      3. Click the Advanced button, and select VGA 640 x 480 x 16 if it is available.
      4. Click OK and restart the computer.
      5. After Windows opens, click Start , and then click Run .
      6. In the Open field type msconfig and press Enter .
      7. Click the Advanced button, and remove the checkmark next to VGA 640 x 480 x 16 .
      8. Click OK . Do NOT restart the computer.
    3. After Windows opens, right-click on an open area of the desktop and select Properties (Windows XP, 98/Me) or Personalize (Windows Vista).
    4. In Windows Vista, Scroll down and click Display Properties . In Windows XP, 98, or Me, click the Settings tab.
    5. In Windows Vista, select the native display resolution size using the Resolution slider. Set Colors to Highest (32 bit) . In Windows XP, select the native display resolution size using the Screen resolution slider. Set Color Quality to Highest (32 bit) . In Windows 98 or Me, select the native display resolution size using the Screen Area slider. Set Colors to True Color .
    6. Click Apply after you have made your adjustment. The screen should blank out temporarily and come back.
    7. If you are satisfied with the new display settings, click Yes on the Monitor Settings windows. If you are not satisfied or if the screen just goes black, wait: Windows sets the screen back to the way it was before. Try another setting until you find a display configuration that is compatible with the monitor and meets your needs.
      NOTE: If the native resolution is not available, download and install updated video driver software for your computer. Updating the video driver software can add more resolutions (graphics modes).
    8. Restart the computer. The monitor should now display a full screen image in high quality. You are done.
Step 2: Connect to another monitor
Using a different cable, connect the monitor to another computer that has video. Turn on the monitor and the newly connected computer. What happens?
  • If the monitor works, the video hardware on the original computer is likely to be the source of the problems. You can try connecting the original computer to another monitor that works to update its video drivers.
  • If the monitor remains blank, repair or replace the monitor.
Dec 27, 2008 | HP Pavilion F50 17" Flat Panel LCD Monitor
Hp pavilion f1523 lcd monitor
You are not alone with this problem. Some lines (like mine) run vertically rather than horizontally. The solution - sue HP. These screens have a known fault ie the Nvidia graphics chip is known to be the culprit. The company knows all about this issue but expect us to pay to put it right - sue them, you can do it online for around £35 (UK).
Oct 02, 2008 | HP Pavilion zd8000 Notebook
HP F1703 - lines running down screen - all different colors
As a general rule, the problem you are having is the panel failing.
A replacement panel would far exceed the cost of a new screen.
Best bet is to sell it off on eBay as a faulty unit and put the money towards another monitor.
You would be surprised at what people will pay for a faulty LCD so they can try and fix it.
Sorry for the bad news, but it may save your sanity trying to get it fixed.
Apr 07, 2008 | HP Pavilion F1703 17" LCD Monitor
HP L1706 17" LCD Monitor Logo
46 people viewed this question
Top HP Computers & Internet Experts
Tony
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
