Question about Radio Communications
Wire astatic D-104 mic to dynascan cobra cam 88
How to wire d 104 mic to cobra cam88 tube type radio
RCtech
  • 55 Answers
SOURCE: astatic noise canceling microphone to 4 pin cobra 29 ltd classic
According to the astatic wiring hand book it is not used. I would leave it terminated but long enough that if you find your having noise when you receive you could still ground it. I'm pretty sure you don't need it.
Goodluck
Rob
Posted on Dec 07, 2008
tparsenault
  • 170 Answers
SOURCE: Diesel #8-32 echo power mics
cobra 4 pin is pin1= shield, pin2= mic audio (usually the shield is wrapped around the mic audio wire).pin 3= transmit or push to talk usually red or white whichever isnt wrapped with the shield, and pin4 = receive or speaker complete
5 pin cobra=1-Audio 2- Shield 3-Receive 4-Switching Wire 5-Transmit, you can jump pins 4 and two
Posted on Dec 28, 2008
SOURCE: CB MIcrophone RewireJob. A Diesel Model 360-100 to cobra's
does it have a sheld wire?
Posted on Jan 14, 2009
SOURCE: Mic wiring diagram
Want to wire cobra mic to a uniden washington radio
Posted on Mar 27, 2009
  • 773 Answers
SOURCE: Cobra 1000 GTL by Dynascan
This is a complicated modification. I have never done it to a 1000 GTL, but its done basically the same in all radio's.
I don't recommend doing it, especially since I am not 100% sure on how exactly to do it. I have never been in a 1000 gtl. If I had one in front of me I could tell you for sure how to do it.
If the reason for Variable power is a linear, just a swing kit in for the dead key you need, most likely 2 watts, and leave it.
Here is how to do a variable power mod. this is assuming the swing mod is done the same to this as a cobra 25/29 or uniden 68/76 etc.
If you would like to try it, here it is.
You get a TIP31 transistor, Radioshack has them.
Where you put the swing mod in the radio, which is a cap and a resistor, you put the TIP31 and cap. A 47uf cap works fine.
With the resistor facing you, and the tab in the back away, solder the cap to the transistor. the leg with the black stripe goes on the right most leg. then the other goes to the center leg of the transistor.
Solder a wire on the left most leg, long enough to reach the front of the radio. Now solder the 2 legs that don't have the wire on it, in the place where you would put the swing kit, with the black stripe on the cap facing the back of the radio usually.
Remove the wires from the RF gain and solder them together.
Now solder the wire from the transistor to the center tab.
Remove VR6 and solder a wire from the top tag of the RF gain to the top connection of VR6 that you removed.
Then connect a wire from the bottom tag to a ground point. The side of a tuning can works fine.
Take a piece of shrink tube and put it over the TIP31 so it does not ground against the heat sink, that would be bad.
This is done basically the same in all cb radio's.
Posted on May 03, 2009
Wire a sliver eagle to a cobra 2000
1 is white 2 is blue 3 is Black 4 shield 5 is Red
Sep 30, 2014 | Astatic D-104 Mic Microphone With Stand...
Howe to wire a 4 pin coard on a astatic d 104
must know the pin out of the transceiver your wiring it too.
like cobras 1.ground 2.audio 3. TX 4. RX... then wire accordingly.
use a ohm meter to find the correct wires on you mic switch.
then you know how to wire any mic to any transceiver.
Sep 02, 2014 | Radio Communications
Pin mic wiring
1- Audio
2- Shield
3- Relay-for RX
4- Transmit
Oct 05, 2013 | Cobra 29 LTD CB Radio
5 pin astatic corba cb mic
take the mic plug connector an check the wireing that broke off and just rewire it the same way
Jul 27, 2013 | Cobra Radio Communications
How to wire a Golden Eagle Astatic D-104 Mic to a RCA Cb Co-Pilot 14T303 4 pin connector
i have a gold eagle mark 4 i like two put a 776 mike back on it but i do not know the w coed .thank you .
Jan 27, 2013 | Magnum DeltaForce CB Radio
D-104 wiring to a cobra cb
Find your radio on this page and then look at the wiring diagrams
Oct 11, 2012 | Astatic D104 T - Ug8 Crystal Microphone...
I have an astatic 4 pin d104m6b amplified
Hello there
Nice mic i have 3 of these
here is infornation that you can use to get the diagram i like the first link a lot better though it is in full color Ok just look belowtis post and it will be there ok? I hope that this is very helpful for you
Best regards Michael
Repairing the D
These Astatic D-104 microphones are all vintage. ... Doing so will reveal the
simple wiring and the wiring diagram, pasted to the plate on the inside. ... http://www.k3hkr.com/D104_repair.html - 4k - Similar pages I am needing the wiring description for the astatic d104 - FixYa Oct 24, 2009 ... HELLO THERE The silver eagle d104 is wired just the same as the knight ...
astatic echomax 2000 unilli eagle wiring · wiring diagrams for ... http://www.fixya.com/support/t3271236-am_needing_wiring_desc... - 125k - Similar pages
Nov 17, 2009 | Cobra 25 LTD 40-Channels Base CB Radio
What is different about Galaxy 4-pin mic wiring? My Astatic desk mics work great on my two Galaxy radios but won't allow recieve audio on my other various radios that are also wired for "standard" 4-pin.
i have a cobra mic i am trying to wire to a 4 pin galaxy saturn. What wires do i use and where do they go. i gava blue, red, white, black and ground (copper colored). i cant find any help anywhere HELP!!!!
Sep 05, 2009 | Cobra Radio Communications
Radio Communications Logo
106 people viewed this question
Top Radio Communications Experts
eradiostore
eradiostore
Are you a Radio Communication Expert? Answer questions, earn points and help others
