Question about Briggs & Stratton Garden
I lost my spark plug for my Troy bilt pressure washer 0202093 what kind do I need to buy?
Lost spark plug
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 165 Answers
Dosent really matter as long as its the same size and length ( start with short one and make sure enchine moves smoothly when pulling cord (avoid piston hitting spark plug. you can measure with a pencil when piston is top dead centre
Posted on May 15, 2014
  • 4090 Answers
SOURCE: pressure washer not working
sketchy info here....
Remove the hose and gun to see if water is flowing....
if it is that means there is no blockage in the hose or gun. When its connected if it runs at the same rate as without the hose and you have set it into pressure clean mode, then the pressure valve and seal have collapsed. Estimated repair cost is $200 and about $100 of that is labor. It is not a DIY unless you know your way around and have the right tools. Having it repaired professionally gives you 3 months warranty as well. Do it yourself and you could end up losing some of the small screws and other nylon components that tend to drop out and get lost when you open it up!
Please rate our help to keep the FREE service online++++Thanks for using FIXYA
Posted on Sep 13, 2009
Testimonial: "Very quick reply,very informative,very helpful. Thank you."
  • 174 Answers
SOURCE: Soap will not siphon on my Troy Bilt pressure
Are you using the soap on low pressure. This is the only way it will work
Posted on Sep 20, 2009
  • 61 Answers
SOURCE: troy bilt pressure washer will not build or reach high pressure
check the non-return valves in the pump block. if these are damaged or dirty you pressure will be greatly reduced. they are located behind the 3 lage brass hexagonal caps.
I hope this helps
SOURCE: oil for a troy bilt 2550 psi pressure washer pump
What fluid and how much is required in the Troy-Bilt 2550 power washer pump?
Posted on Apr 18, 2010
SOURCE: troy-bilt 2200 psi pressure washer
I have a Troybilt Model 2200 PSI Pressure Washer in which I have used only 2 times in the past 2 1/2 years. Went to use it this past weekend and the pump in not working. Water shoots out of the side. I bought this brand and model as I thought Troybilt was suppose to be so good. Went back to where it was purchased and had no success but to say I could buy another pump or take it in to be repaired. I believe that this power washer should be replaced at no charge. 2 uses does not constitute a few hundreds of dollars.
Have you to heard anything concerning pump problems on this particular model? Thanks for any advice. .
Posted on Jun 08, 2010
I have a troy-bilt model 020296 power washer. what type of replacement spark plug does it take?
Tom, NGK BRP6ES ,Champion RN9YC,Torch F6RTC are replacement sparkplugs for Honda GCV 160 pressure washer engine. This info should be in your pressure washer engine manual. Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
http://www.bsppwebtools.com/data/manuals/020296_0esAw.pdf
Troy Bilt 020296 Pressure Washer Relacement Parts
Spark plug cross reference
Jul 02, 2016 | Troy-Bilt Garden
What is spark plug gap on unidentified pressure washer?
Find My Engine Spark Plug & Gap ' Briggs & Stratton
www.briggsandstratton.com/.../identifying-the-correct-s...
Briggs & StrattonLearn how & where to find the right spark plug and a gap chart to guide you through ...are commonly used for walk behind lawn mowers and pressure washers.
Spark Plug Gap - Troy-Bilt
Nov 24, 2015 | Garden
Ball valve spring pressure washer detergent line
Not sure what type pump you have but you can buy a chem. injector rebuild kit at Pressure washer parts catalog quick links Pressure Washers High Pressure...
If you need to replace the spring then replace the entire kit. Ball, spring and oring. Most pumps that come on the newer TRoy bilts are AR RMW pumps. the parts diagram can be found here at http://www.arnorthamerica.com/manuals/rmw-om%201006.pdf
The parts for a AR chem. injector are
480480 O-Ring
1250280 Ball
1560520 Spring
Good luck
Jul 22, 2014 | Troy-Bilt 020528 Gas Pressure Washer
Power washer wont pump
Call us when you can be at the washer so we can trouble shoot it with you over the phone.
http://www.ppe-pressure-washer-parts.com/troy-bilt-020416-1-pressure-washer-parts
Mar 20, 2014 | Troy-Bilt TROY-BUILT 91215 - TROY-BUILT...
How do I change oil in my Troy Bilt Model 020245 pressure washer
if its a vertical engine it;s underneath the base of motor look for a plug with a square slot in it i usually use a 3/8 " extension
Aug 21, 2013 | Troy-Bilt Troy - Bilt 020245 Pressure...
Change oil in Troy Bilt 020245 pressure washer pump
underneath base of motor look for a plug wuth a square slot,i normally use a 3/8" extension with ratchet.
Aug 20, 2013 | Troy-Bilt Troy - Bilt 020245 Pressure...
Change oil in Troy Bilt 020245 pump
if it,s a vertical motor it's at the base of motor look for a plug with a square slot.
Won't Start. Need manual (lost it). Where is the spark plug located so I can change it
You can get your manual here. You will need Adobe Reader installed on your computer to do so.
You will also need the serial number off of your machine to get the download from MTD/Troy Bilt.
You should find the spark plug at the end of a thick black wire. You may have to remove a cover to see it clearly.
http://manuals.mtdproducts.com/mtd/Public.do?BrandCode=10001
Dec 06, 2010 | Troy-Bilt 31cc 2-Cycle Gas Powered...
Oil for a troy bilt 2550 psi pressure washer pump
May 17, 2009 | Briggs & Stratton Garden
Garden Logo
137 people viewed this question
Top Briggs & Stratton Garden Experts
Phil Walker
Phil Walker
John Trevino
donald boissonneault
Are you a Briggs & Stratton Garden Expert? Answer questions, earn points and help others
