Question about Home
How do you set a different tune to chime the clock has a a-b-c mode
Only one melody chimes for the a-b-c mode
SOURCE: Salton Chiming Wall Clock is chiming inconsistently
yes .
check volume setting.
if you have a manuval volume control try to clean inside of volumecontrol.if ok fine
or
if not ok Replace volume control with same type( new one.).
Posted on Nov 20, 2008
SOURCE: Whitting and Westminster Jean luis Electronic clock
I found my own solution through trial and error. I set the dials to 12 00 and then move the dials to show just over 5 minuites to 12 ( 1155) the alarm melody start and chimes for a number ( in may case it was one.) then i moved the dial back to 1200 and then reset it again to 1155 or just over. Each time the alarm chimes an increasing number
I had the clock chime settings on the back of the clock to the middle setting (chimes on 24 hours)
I carried out this until the chime was right for the time i was working ( in my case it was 1730) so when it reached 5 chines I then set proper time and left it. The next chime was correct
Posted on Jan 12, 2009
SOURCE: Seiko Westminster Chime Clock; Model No. QF0020 (or QF002G)
There is a small potentiometer that the volume know is on, probably replacing the pot will fix the problem. Radio Shack has these.
Posted on Jan 20, 2009
SOURCE: seiko mantle clock (switchable chimes)
See this site
http://www.theclockdepot.com/seiko_westminster_clock_instructions.html
Posted on Apr 22, 2009
  • 15 Answers
SOURCE: I NEED THE INSTRUCTIONS FOR SETTING THE CHIMES/TIME ON MY WESTMIN
Manually turn the minute hand forward until the 16 westminster chimes sound and then the hour strikes. Then remove the minute hand (it will go on in four positions) and put it back on at the 12 o'clock position. The chimes should now be back into sync.
Fred
Posted on May 10, 2010
My Howard Miller battery operated mantel clock model 612-588, movement 354078F doesn't chime. My wife thinks she might have changed a setting or switch accidentally. How do I re-set it?
There is a switch from 'chimes off' and two variants. There is also a night clime cut off or volume reduction.
. CHIME MELODY
Use the switch with the symbols
OFF, WEST, and MELODY2
to select the chime melody according to the following settings:
O
FF = Silent
WEST = Westminster melody and full hour strike
MELODY2 = Ave Maria melody and full hour strike (Beethoven's Ode to Joy on select models)
. VOLUME CONTROL
The volume of the chime can be modified by turning the Volume Control knob.
5. AUTOMATIC NIGHTTIME CHIME SHUT-OFF
The movement has automatic nighttime volume shut-off or volume reduction options for a period of eight (8) hours after the switch is moved to the shut-off or volume reductions positions. This feature will automatically repeat at the same time every 24 hours. Use the switch with the symbols to select chime silencing according to the following settings:
Chime silent for eight (8) hours
Reduced volume for eight (8) hours
Full chime volume
Here is the manual
http://bigbenclocks.com/img/products/manual/quartzmanual.pdf
Nov 07, 2017 | SHE Home
How do I make my clock chime the correct number of times?
whenever the battery is weak the chime changes....whenever you change battery the clock chimes to the last time it chimed so...try setting your clock to next hour of chime n then move the hands of clock to next hour n your clock will chime accordingly.....
in this way waiting for chime to finish ...set to clock to present time ....waiting for it to chime every time the minute hand passes 12
Dec 09, 2015 | Home
How do I fix the westminster chimes on my grandfather clock
Grandfather Clocks Manual - theclockdepot
www.theclockdepot.com/grandfather_clocks_manual.html
Howard Miller Grandfather Clock Manual by The Clock Depot offering discountGrandfather Clocks. ... The movement controls the hour strike, time keeping, andchime. ..... the hour without the Westminster melody if the other Westminster melody lever is turned to Silent. .... My Grandfather Clock has Stopped, Can I Fix It?
Owner's Manual - Master Clock Repair
www.masterclockrepair.com/ownersmanual.html
Note: The following information will apply to almost all grandfather clocks made after ...(See my article on Clock Myths) It is best if the chains are not pulled so far that the top of .... Some play the Westminster chime only and cannot be changed.
Nov 23, 2015 | RIDGEWAY GRANDFATHER CLOCKS Ridgeway...
Why will my clockl no longer play song or move
When was the last time it was serviced? The movement probably needs a good cleaning and/or oiling
UsedClockParts.com
Sep 02, 2014 | Seiko Melodies in Motion Clock
How do I set the Chimes on the Ergo Westminster Clock
The controls on the back of the Ergo brand Wall Chime Clock are different than that of the Seiko. I'm not sure who makes the movement - probably Chinese or Asian. Anyway, always take the pendulum off the hook before moving the clock about as it can damage the mechanism. On the back, there is a dial for adjusting the time setting of the clock hands, which is awkward to use, but does work, easiest to leave it alone and use the minute hand, NEVER the hour hand. There is a dial for volume. There is a switch for type of chime - Westminster or Wittington. There is the night-time shut off or volume reduction. Some models have a switch for chiming every quarter hour. My advice is make sure you have fresh batteries, and set the switches on the back for the settings you want. Hang the clock, grasp the pendulum arm and re-hang the pendulum, making sure it's hooked in properly. Now, whatever the hands say the time is, ignore it for now, and gently move the minute hand backwards, slowly, to about 5 minutes before the top of the hour, then forwards to a couple of minutes past the top of the hour. This will cause the chimes to start. Let the melody play, then listen for how many "clangs" you get. That will tell you what the clock thinks the time is. For example, if it "dongs" 5 times, and you've set it to run silent at night, the clock thinks it's 5 p.m. If it's actually only 3:15 p.m., then gently run the minute hand backwards til the hands indicate about 10 minutes behind the correct time (it'll take you several minutes to complete the process) then gently move the minute hand back to about 5 minutes before the top of the hour, then forward to a few minutes past, and the chime will start to play the melody. If you let it, it will play out the full melody, then it will "clang" one more time than your previous test. Each time you move the minute hand back to 5 minutes before the hour, it advances the chimes by one hour. Here's a tip - you don't have to let the melody and "clangs" play fully, each time, once you know how it works. If you have it set to run silent at night (pre-programmed to silence after 10 p.m. to 6 p.m.), keep moving the minute hand back to 5 minutes before the hour, keeping track of how many times you've done it until you reach 10 p.m., or not, until you get to the point where you move the minute hand back and there's silence. At that point, the auto-silence mechanism is active, and the clock thinks it 11 p.m. So, from that point, keep repeating the process of gently moving the minute hand back and forth, from about 5 minutes to the hour, to a few minutes past, keeping track of how many times you've done it. After 8 sequences, you hear it start to chime again, at 6 a.m. So, at that point, go through the back-up and advancing of the minute hand sequence 9 more times, and on the 9th time, let the melody play, and let in "clang" to determine that you're indeed at 3 p.m., which you should be. Then simply gently advance the minute hand to the correct time, 3:10, 3:12, whatever, and you're done. You'll know for certain soon enough.
Apr 02, 2012 | Watches
Strausbourg Manor Wall Clock chime adjustment
It is normal for the average wall clock. Of course, this can be adjusted, but without watch/clockmaking knowledge it is impossible, because first you need to find out which part of the movement is causing early chiming - and there are plenty of them.
Super fine adjustment can be found only in top of the range clocks. Hundreds of hours of craftsmenship are spent to adjust and fine tune them. That's why they cost a fortune.
If you can not live with that early chiming, you have to bring your clock down to the watch/clock repair shop and ask for help. Be ready to pay quite a money, as this job takes the skill and a lot of time.
Rate me, please.
Jul 29, 2009 | Seiko Mantel Clock
Need setting instructions for clock movement
Howard Miller offers this feature: This is how it works.
Automatic Night-Time Silencing Option
Grandfather Clocks will offer a night time shutoff option. There are 3 options on this lever.
1) "Night On" - This will keep the chime striking 24 hours
2) "Night Off" - This position will turn off the chiming between 10:15PM and 7:00AM
3) "Strike" - This position will allow the movement to strike the hour without the Westminster melody if the other Westminster melody lever is turned to Silent.
Hope this helps.
R/David
Apr 05, 2009 | Oregon Scientific Lwb0997110113004...
Jan 09, 2009 | Seiko Mantel Clock
Dont know how to turn on hourly chime timex atlantis 100
Set chime and Alarm on or off
Press MODE to select ALARM
Press START/SPLIT to change (clock sign and chime sign will appear and disappear as you keep on pressing).
Press MODE again and you are all set.
Dec 28, 2008 | Timex Atlantis 100 77517 Wrist Watch
yes .
or
Nov 10, 2008 | SkyScan 86709 Atomic Wall Clock
Home Logo
22 people viewed this question
Top Home Experts
Donni Steen
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
