Korg triton le
My Triton proX won't turn on. It started a year ago when it took two tries to turn it on. Then three. A year later it has gone dark. Power chord works with other devices and outlet is positively working. Screen flickers on for a quick instant if you smack the area on the face above the A/C port. But for many reasons, this is not something I want to do. I checked the port and there is nothing visible to indicate malfunction. Same with the power chord. I even dabbed the port with a swab of alcohol to make sure it wasn't dust or debris. Any suggestions?
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 79 Answers
Sounds like the power connector has failed or has a cold solder joint.
If you are in LA I can help you. 661-775-oh six oh 9
Posted on Apr 24, 2014
chie-chie
  • 98 Answers
SOURCE: Denon AVR 3806 - No Power
open unit replace fuse....im sure u have blown fuse..
rate me fixed ok
Posted on Feb 14, 2008
petraman7
  • 1175 Answers
SOURCE: It shuts off right after I turn it on.
Hi....
It's usually a component failure in the power amp section.
There are good tech shops in Cailfornia
Posted on Mar 24, 2009
SOURCE: Yamaha HTR-6130 Receiver will not stay on! Shuts
The Sleep Timer must be sert to OFF.
Posted on Sep 17, 2009
SOURCE: got a wharfedale NE-3272 DAB/CD Micro system,had
I had a similar problem with my wharfedale NE-3272 DAB/CD. Argos replaced it. Now the new one switches itself off when I switch to cd. I think it's one of those that look the part but are really just poorly made tat.
Posted on Nov 16, 2009
dduncan774
  • 760 Answers
SOURCE: Denon AVR-1908 won't power on
Are you getting a standby light at all? Is it flashing? Do you here a click when you plug the unit in? If the answer is no to all of these then you blew a fuse. If you do have soome sort of standby light, then your set is in protect mode. More than likely for a blown channel. If no lights, but you ar egetting a click, you could have a bad transformer. Use a DVM and see if it is open or not. Good luck
Posted on Aug 23, 2012
Korg triton le
Initialization: Hold Enter and 0 while turning it on
Preload: Global mode, F8, Select “Preload”
ROM Check: Given on power up.
Apr 09, 2017 | Audio Players & Recorders
I need the mother board for korg triton Le i need help where i can find it and how much. thanks
There should be service center near your house.OR better u give us your location and about cost there is range in every in product it depend on u what suites u better
Jan 07, 2011 | Korg Legacy Collection
Korg Triton Le keyboard not working
Hello! My Triton LE did that yesterday at rehearsal room. It came on twice (by turning it off and on every time the error message appeared), I could play the auditions and demos but when i hit the keys i heard nothing.
Soon after I went home (still with sweat on my forehead and my heart pumping like a pneumatic drill) I connected it and everything was working like nothing ever happened!
So guys, everybody who has the same problem: Don´t panic! I think for me, the power plug at the rehearsal room had a problem. Who thinks of that? Nobody... So check your keyboard on another power plug...If you can, try it in a friends house. Or check your house plugs.
I assume if the Keyboard doesn´t get enough power, the error message appears. Hope that Helps!
Apr 23, 2009 | Korg TR76 76 Key Synthesizer Workstation
A ''static'' sound coming from ALL outputs of Korg Triton
try cleaning ALL the contacts involved with Caig DeOxit (D5, S5. F6, G5, etc.) products*, they work very well. e.g.; cables, inputs, outputs, and (if you're confident) all the contact points "under the hood". this static you speak of sounds like less than stellar contact points and can addressed at home if you've the motivation to DIY.
* amazon.com/D5S6-Contact-Cleaner-F5S-H6-FaderLube/dp/B00HNV7WI2?SubscriptionId=AKIAILSHYYTFIVPWUY6Q&tag=duckduckgo-d-20&linkCode=xm2&camp=2025&creative=165953&creativeASIN=B00HNV7WI2
Mar 31, 2017 | Music
Triton Le
when you are setting your midi track on the mpc are you changing to 2A-Device02 for the 2nd track? 3A-Device02 would be the 3rd track and so on. Let me know if that helps. you should make a new track for each instrument you record from the triton to the mpc, helps when dumping.
Feb 18, 2009 | Korg Legacy Collection
Sticky keys on Korg extreme
I just changed the key on my Korg Triton Studio 61. It took some time, but it wasn't that hard. You'd better have a power screw driver. I had to take out at least 30 screws.
Do this at your own risk. Don't blame me if you mess up your keyboard. I'm telling you. If you're not that handy, don't try it. Pay attention to detail and be careful.
The Steps that I took
1) Turn your keyboard face down. Make sure you put it on something soft so that you don't scratch the face of your keyboard or damage your knobs or the pitchbender.
2) Remove all the screws on the bottom panel and remove the panel.
3) you have to take the entire keybed out. Lots of screws! I had to remove the "assignable - midi input/output board" to get it out. MAKE SURE THAT YOU DISCONNECT ANY CABLES THAT CONNECT THE KEYBED TO THE REST OF THE KEYBOARD. I had to disconnect the keybed at three different places. These connector cables are NOT strong and if you pull too hard, you WILL break them.
3) Once you get the keybed out, you have to remove the plastic binder that goes at the back of the keybed. It holds the keys in place.
Then Snap the old key out. snap the new key in. Before you unpack your new key, make sure the old one is really broken. I had a key that wasn't broken. It had just come unsnapped. I snapped it back in and it was fine.
Put it all back together again.
I had a broken key before. i got it repaired and it cost me $150. This time I fixed it myself and it cost me $7.50
Mar 02, 2008 | Korg Legacy Collection
 Grubhead
Grubhead
