Question about Carrier Heating & Cooling
Infinity control zoning disabled
Zoning disabled on screen
C?mo puedo deshativar alarma de un infiniti g35 2004
For the non-Spanish speaking:
How I can disable alarm infiniti g35 2004
Apr 10, 2015 | Infiniti Cars & Trucks
Zone control not working
These are both power open and closed. Yellow and green should be constant on the leds. C&D is your 24 volts for the controls. If you got power going in but nothing coming out of the board it is bad. If you got 24 going to the damper but damper not responding obviously it's bad. Usually communication is DC voltage, likely 12 or 13 DC at A&B. Good Luck!!
May 13, 2017 | Heating & Cooling
Security light flashing, car won't start for infiniti
Whenever this warning light or any other stays on in the dash it is indicating that the systems control module (or the system sensor in the case of lights like low oil pressure, door open indicators etc.) has detected a fault, it then disables the system (this applies to ABS,TCS, TCM, SRS and BCM faults and others) as long as the light is on. You must now have the dealer hook up a special electronic diagnostic tool and "scan" the system for the fault code that is stored for the problem(s)
Legend of Abbreviations. ABS Antilock brake system.TCS Traction control system, TCM Transmission control module, SRS Supplemental restraint system, BCM Body control module
Oct 18, 2012 | Infiniti M35 Cars & Trucks
Message volume fixed
Zone 2 Setup on the RX-V773 using the ZONE2/PRESENCE Extra Speakers The RX-V773 extra speaker terminals can power one set of speakers for Zone 2 or Presence speakers. If the extra speaker terminals are utilized then the RX-V773 cannot be set for Bi Amp (Surround Back/BI-AMP terminals). Setting the Extra Speaker Terminals Note: The RX-V773 remote control will be used to access the On Screen Menu of receiver. 1. Press the On Screen button on the remote control to enter the On Screen Menu. 2. The On Screen display should be displayed on the TV/Monitor. 3. Press the Arrow Down button on the remote until Setup comes up in the screen. 4. Press the Enter Button on the remote control. 5. The Setup Menu will come up across the TV/Monitor screen. 6. Use the Arrow Left & Right buttons on the remote to navigate to Speaker. 7. Press the Arrow Down button on the remote to select Manual Setup. 8. Press the Enter Button on the remote control to enter Speaker Manual Setup menu. 9. Speaker Manual Setup menu with Power Amp Assign highlighted will come up. 10. Press the Enter Button on the remote control to enter Power Amp Assign menu. 11. Speaker Manual Setup, Power Amp Assign menu will come up with Basic highlighted. 12. Press the Arrow Down button on the remote to select 7ch+1ZONE. 13. Press the Enter button on the remote to select 7ch+1ZONE. 14. Press the On Screen button to exit the on screen menu. To control Zone 2 using the RX-V773 remote, the switch at the upper left side (above the BD/DVD Scene button) of the remote must be set to Zone 2. To see the operations on the front of the Yamaha receiver you must press the Zone Control button on the front of the receiver. Note: Only analog signals can be sent to Zone 2. If you want to output the sound from Zone 2, connect an external component to USB Thumb drive, USB iPhone/iPod, Network, AV 5-6 or Audio 1-2 by analog connection. For AM/FM radio the antennas must be attached.
Aug 19, 2012 | Yamaha RX-V773
Cruise control light comes on but speed will not set
You need to scan your onboard computer network for possible fault codes. Many engine, transmission, or antilock brake/traction control malfunctions will cause the cruise control to be disabled.
Apr 23, 2012 | Infiniti Cars & Trucks
Carrier infinity a/c thermostat screens are blank - no power
There is a fuse in the control panel, and depending how they wired it may be a inline fuse. also there is a fuse in the airhandler also they both should be a 5 amp auto fuse.
Jul 18, 2010 | Heating & Cooling
My windows will not roll up only the driver side & the power
Maybe check for a child-safety function that disables the door panel buttons.
Mar 30, 2010 | 2004 Infiniti QX56
My infiniti g35 sedan 2004 wants to stall after starting. The rpm drops almost to the point of stalling. It only happens after sitting overnight or after work. After I give it some gas, its fine. the car...
Your idle air control valve sounds like it is failing. This is basically a solenoid that actuates at idle to allow air for proper combustion and maintain idle.
Feb 13, 2010 | 2005 Infiniti G35
Xp pro sp3 setup problem for optional windows components
It looks like you have a copy of Zone Alarm on your PC and Windows XP Pro SP3 is not liking it. One thing that you can try is to disable Zone Alarm by right clicking on the icon that it creates on the lower right hand corner of the screen and see if you can find a "disable" or "shutdown" option. After doing so, then try to install again. Another thing that you can try is to completely remove Zone Alarm, try to install SP3 again, and if it installs, re-install Zone Alarm. However, I think the easiest path is to disable Zone Alarm temporarily. Let me know if this helps you or not.
-Serge
Mar 30, 2009 | Microsoft Windows XP Professional SP3 Full...
Replace battery on 2004 infinity coupe
go to an auto zone and the sales people will do this for you at no cost.
Feb 07, 2009 | 2004 Infiniti FX35
Heating & Cooling Logo
Top Carrier Heating & Cooling Experts
Dan Webster
Dan Webster
Donni Steen
Bill Long
Are you a Carrier Heating and Cooling Expert? Answer questions, earn points and help others
