Question about Toysmith POTATO GUN
My toysmith potato gun isnt shooting
It is all greased up it just wont shoot i bought it like 1 hour ago it was fine at first then just stopped working
I just bought a Powershot pro electric staple and nail gun. I loaded the 5/8 in brads it says to and it will not shoot the nails out.
check for a safety device that has to be in position before it operates
it could be an on/off switch in the handle other than the trigger
failing that take it back for warranty or refund
Oct 27, 2015 | Tools & Hardware - Others
1985 20 hp is stif hard to move left or right
pretty common problem - you need to get some MARINE grease for your grease gun and shoot the pivot grease nipples- some models had a special nipple that needed a gun from the marina- (so you could not put auto grease there)
Move it back and forth as you shoot the grease. I have used a torch to warm up the bits to get the grease to flow.
Also- if the motor is new to you- they have a friction of some sort on them to keep them going straight when you let go- you might want to loosen that befor trying to fix a problem that isn't there.
Dec 06, 2012 | Boating
I bought a new mossberg 590 a1 shot gun a month ago, I love the gun but its having a couple of problems, the first problem is that when shooting every once in a while i get sprayed in the face with exuast...
Personally, with that many problems, I'd call Mossberg and get a return authorization. None of these things should be happening, especially with a new gun.
Feb 17, 2011 | Mossberg Sport & Outdoor - Others
After about an hour of play with the pulse r76 it will stop shooting and only make a distinctive click. I charge the battery, use my friends battery who has the same gun but the gun still wont shoot. Then...
If you charge the battery for more than five hours or over night, you'll burn out the battery. When your done playing with the gun dont put it on the charger immediatly as this will overheat the battery. Wait about an hour for the bettery to cool and then put it on the charger. It should work fine after that.
Feb 04, 2011 | Crosman (4032)
My alpha black paintball gun is shooting 1 to 5 then stopping.
Sounds like it needs to be oiled. A couple of drops in the small hole where your bottle screws on.
Replace bottle and dry fire to see if you got it. Cleaning is just as important. Internals need to be cleaned
and lubed often. I know it's late but hope it helps someone.
Jun 11, 2010 | Paintball Tippmann U.S Army Alpha Tactical...
Bought a used rem. model 700 30/06 that has a simmons prohunter 3-9 x 40 prodiamond model 899738. how do i make adjustments for sightning it in properly.
Shoot 1 round from bench rest put gun in gun vise and adjust top and side screw under round cap till cross is dead on the hole you shot with first shot and gun should be sighted in fine adjustment can be made if needed
Oct 18, 2009 | Optics
My daisy buck 400 shot repeater bb gun wont shoot
bazthespazz i would like that file you said, just bought the daisy buck 400 and got jammed arround the first 20 shots nd i want to repair it but its hard to remove the piece of the trigger
Jul 30, 2009 | Toys
My nail gun will shoot one nail then stop. Any
I had the same problem with my Stanley stape gun. Had to replace all the seals and piston. Works find now! Check-out internet ...search for a rebuild kit for your model of gun. Get the complete rebuilding kit ....take about 1/2 hour to rebuild.
Jun 11, 2009 | Stanley Tools & Hardware - Others
Gun wont recoil to spit a nail out
the sring on feeder paw broken or missing
Mar 20, 2009 | Hitachi Tools & Hardware - Others
Toysmith POTATO GUN Logo
459 people viewed this question
Top Toysmith Toys Experts
richie46
Are you a Toysmith Toy Expert? Answer questions, earn points and help others
