Eeprom Electrohome 27e510
Deflection vert horizont
    Top Expert:
  • Televison & ... Master
  • 74,473 Answers
If you wish to get some details; check the site linked here. Viewing it in "Mosaic" will make surf easy. Surf the site with patience. Pull up older posts.
Posted on Apr 02, 2014
Retarce line
Diagonal retrace lines at the top are usually the result of bad electrolytic capacitors in the vertical deflection circuit most vert. deflection circuits derive operating B+ from a horizontal flyback transformer winding rectified & filtered usually around 24 volts the electrolytic capacitor on this supply loses capacity or may totally go open causing the retrace lines,sometimes other electro. caps in the vert circuit can cause this too, depending on the age of the tv you may find multiple substandard electrolytic caps it's best to test all for capacity & esr. Without knowing more details about your tv brand,model and/or chassis i can't help further.
Apr 14, 2014 | Sansui Televison & Video
Electrohome 27e510
Search online for any of the several purveyors of replacement OEM remotes.
Dec 26, 2013 | Televison & Video
Horizontal ine in CRT tv
Failure of the horzontal linerity coil, possible dry soldering on the board of the components- resistors and capcitors- in the horizontal coil circuit . Also failure of the deflection coil- YOKE- in the crt. So check the coils and the circuit around this section as the rest of circuit seems OK.
Apr 06, 2011 | Televison & Video
No horizontal. vert line in center of screen.
you have no vertical deflection. try tapping on the vertical section of tv. possible loose connection on circuit board. soldering the vertical output is a very common problem
Nov 11, 2009 | RCA Televison & Video
Won,t turn on.
FOUR Blinks---No Vert. Deflection (V STOP), Screen goes to a single horizontal line then the video signal muted. check the vertical deflection IC and circuit
Nov 05, 2008 | Sony KP-46WT510 46" Rear Projection HDTV
Picture in narrow line on 35" Tube set
The problem you are describing is called loss of verticle deflection. You will find this will require diagnosis and there is no simple answer to this repair. Most likely there will be either bad electrolytic caps or bad vert. output IC in the vert. circuit.
Mar 29, 2008 | Mitsubishi WD-52525 52" Rear Projection...
Vert deflection problem
You are correct about having a dry or leaky capacitor that is causing those lines to show on the top of the screen.
Check the caps with low capacitance like 1uf, 10uf, 47uf, etc.
No quicker fix for this one until you change the capacitors.
Hope this helps.
Mar 14, 2008 | Philips 32PT6441/37 32" TV
Horizontal Line
you have a vert sweep problem. Probably the vertical output Ic the B+ going to the vert out IC or in rare cases the deflection yolk could be bad but not likly.
Apr 23, 2006 | Panasonic CT-27G23 27" TV
Thin horizontal line
Defective components in vertical deflection and output circuit inclusive of vertical output device, coupling capacitors, and yoke connectors. Passive devices such as electrolytic capacitors, coils, and resistors to/from power supply circuits. If your tele is more than 10 years old dump it and get a newer product. $100 USD is a fair price to diagnose and attempt service, depending on age and configuration. Older products may not have replacment parts available at any repair cost. There may be a pot for adjusting the vertical size. If so, it may be dirty. If you can find it, try adjusting it which could clean it. BE CAREFUL -voltages are very high.
Mar 20, 2006 | Sharp 27H-S60 TV
Televison & Video Logo
37 people viewed this question
Top Televison & Video Experts
Electro Med Services...
