Question about Samsung LN32B550 32 in. LCD HDTV
Volume goes max and will not lower.
My TV will not turn on with the remote. I have to turn it on by the button on the TV itself. When I do the volume will go max and will not adjust. It seems like a button is being constantly pushed on a remote. The light near the IR on TV is always blinking. I've tried different remotes and blocking the IR on the TV and problem still persists. If I enter the menu or source screen, the TV will go crazy and go through settings and change them. IT seems like a button is stuck.
  • 4 Answers
Hello
Please remove the batteries from the remote and check whether it is possible to use the local keypad on the TV? If the volume increases, it may be a problem in the local keyboard.
Posted on Apr 10, 2014
SOURCE: source picture changing by itself
It's interesting I unplugged everything and it sat for a few days. I plugged everything back in and it works like normal again. It's been fine for about 4 or 5 days now. I will try what you suggested if it messes up again. But just to be clear, did you mean to try to press the buttons on the TV repeatedly? or the remote buttons?
Thanks for the advice
Posted on Mar 18, 2008
SFroese
  • 141 Answers
SOURCE: Menu Trouble
perhaps the volume down button on the TV is stuck. It could be either physically stuck, or the electronic logic could be messed up. Just to rule out a problem with the remote, take the batteries out of it and then adjust the volume at the TV and see what happens.
Posted on Sep 07, 2008
  • 6 Answers
SOURCE: Cable Set-Top Box remot won't change sound vol. Only TV Rem. does
They volume indicator you are seeing is meant to show the volume of content if it were to be recorded on the cable's dvr. This indicator has no effect on the volume of content as it is being watched. This feature allows recording of sound at a set volume even while the tv is off. It sounds as though you'll just have to use the volume buttons on your tv's remote, though you might want to try seeing if there is alternative set-up for those cable volume buttons.
Posted on Jan 05, 2009
roety
  • 585 Answers
SOURCE: my dad just bought a samsung lcd tv and if you
Hi my name is Roety,
I can help you with your issue ,
First check in the menu that the speakers are switched on, next check the TV in all inputs.
If using an HDMI input the audio may switch off.
Try running an antenna or cable to the Tv direct to determine if its an HDMI or basic setting issue
If I have helped you with your issue
If you have more questions you can still respond
I will reply asap
Thanks
Posted on Jan 29, 2010
djromann
  • 158 Answers
SOURCE: I have a 32 inch Samsung LCD TV. For some
Warning! Pull out the cord first!!! Open the TV take the tester and check over the mini board with the buttons, there might be the Vol- button in shortcut, or get some water. If its short, must replace, if there are water/ liquid/ oxyds traces, take a toothbrush, put a little of alcohol, and gently clean the place, after that dry it with a hairdryer.
Posted on May 18, 2011
40 samsung lcd tv problems
remove batteries from remote control and adjust volume to desired level. If the volume stays the same then there is a problem with the remote. If the volume lowers again then the problem is with the TV. the volume button on the TV or on the remote may be malfunctioning. Hopefully it will be on the remote. If it is the remote, take it apart and clean it with damp cloth. after allowing it to dry, re-assemble and try it out.
Sep 12, 2013 | Televison & Video
Volume pegs to max. Turns itself on. Goes to menu. Intermittent
This is becoz your Internal Remote control response program chip needs to be replaced! You need it to get repaired at nearest service station. Or it may be due to Your keys pressed continously from remote control. Check both the causes! then decide. It will help you!
Dec 23, 2007 | RCA F38310 38" TV
Volume goes all the way up by itself
1. The volume up button on the remote may be stuck down- try wiggling the button to get it out. If it isn't the remote if the local volume control is in fact two buttons perhaps that one is stuck in or damaged.
2. The dvd sounds like it needs a new laser unit- a worn laser unit may play up like this.
It might be time for a new one as replacement can be sometimes more than the cost of a new one nowdays!
Jan 17, 2010 | LG LFD7150 Shelf System
When i turn the tv. on, the volume line appears all the way to zero. if i turn the volume up, it goes up but when i release the up button the volume goes down all by itself.
It sounds like one of the volume down buttons is stuck in the activate position. The same as if you were holding the down volume button continuously. It could be either the volume down button on the TV or the remote. I would try remove the batteries of the remote then adjust the volume by the TV buttons.
If the volume doesn't go back down then the remote is the problem. In order to fix the remote you may need to take it apart. This is normally easy to do just locate any screws that may be holding the remote together. If you don't see any screws then you will need to pry the two sections apart. Separate the circuit board and rubber buttons and clean them both with some rubbing alcohol and reassemble it. If it still has the volume issue you may need to replace it.
If the problem persists with the remote deactivated then it's the volume button located on the TV. That is a little more difficult. You can try wiggling the button or some canned air (used to clean computer keyboards) to blow it clean. However it may need to be disassembled to gain access to the switches for proper cleaning.
Hope this helps.
Oct 19, 2009 | Toshiba 32A33 32" TV
Volume goes up to 100 by itself
make sure there are no buttons sticking on the remote. open the remote and clean the buttons...
Apr 26, 2009 | Insignia LCDTV26 26 in. Television
Samsung remote volume control returns to max sound on its own
dear, you have to check your +button whether it is holp the egde of your remote, open your remote and clean, and also check a button on tv for +volume button. there is a pulse condition sensed by the volume control stage. if you can manage do it, or take it to a technician.
Feb 26, 2009 | Samsung Remote Control
The volume to the tv goes to max when you turn it on?
that hapened because your remonte contral has the + button pressed just release the volum + at your remonte and all will be ok
or try to hide your remonte control and get down sound from front panel of your tv
Dec 11, 2008 | Televison & Video
How do I unlock the volume control?
Zenith Electronics Corporation is a long-time leader in electronic enterainment products.
Aug 24, 2008 | Zenith C27A24T 27" TV
Problem with the volume
Two things can cause the problem your set has,one is the volume up button in the front of the set is pushed in too far and it has the momentary switch active all the time or the cleaning solution you use to clean the face of the tube has dripped down thru the lower edge of the frame into the switches creating a short and making again the switch active all the time.If the cleaning solution went down to the switches they will need to be replaced.If you are familiar with tv service you can remove the back cover and check that the button is not pushed in or it has corrosion built into.If you are not too familiar with tv service be safe and take the set for repair,if they come to your home it will be more expensive. Let Us know if you need more information.
Oct 25, 2006 | RCA 27V530T 27" TV
Samsung LN32B550 32 in. LCD HDTV Logo
238 people viewed this question
Henry  Thomas
Henry Thomas
