Question about Canon Office Equipment & Supplies
My printer won't scan
It won't scan or copy
  • doubee Apr 03, 2014
    Hi Teresa Sarah Nunno, I want to help you with your problem, but I need more information from you. Can you please add details in the comment box?
    I need the Make and model, and please tell me if your printer will make a copy, both off the glass and through the document feeder.
The top left "hinge" won't seat, therefore the top feed can't be used to fax, scan or copy.
It's possible that the hinge of the scanner cover broke. If that's the case, you won't be able to scan from the ADF (Auto Document Feeder). If the printer is still under warranty, please call our technical support team to have the printer replaced.
Aug 10, 2012 | Lexmark Pinnacle Pro901 Inkjet Wireless...
Won't scan, light doesn't come on
Make sure the printer can copy (without computer). If you can make copies, the problem may be the computer or the USB cable. If the printer does not copy also. The problem is in the scanner or in the flat cable.
Apr 10, 2012 | Canon Office Equipment & Supplies
Hp 380 allinone won't print or copy but will print something i scanned in
it is better dont purchase HP series.. its all waste... they are simply selleing by advt. No customer service. Useless....
Dec 14, 2011 | HP DeskJet F380 All-In-One Printer
Hp photosmart premium wifi failure
@ Other computers might be beyond the range of wi fi limits, run the CD in other computers ask to detect.. if not detected suspect out range.Check obstructions of walls, beams, magnetic fields.
@ If printer is not scanning check whether copy happening or not, if copy is happening uninstall the drivers and reload it once again, if copy not happening check scanner unit warming up or not.
Nov 24, 2011 | HP Photosmart C6180 All-In-One InkJet...
My lexmark x7170 all in one won't copy or scan starts to but stops
It could be a scanner hardware problem. Try to unplug the printer from the power source to reset it. Wait at least 10 seconds and then re-plug the printer back into the power. If problem continues, please don't hesitate to contact Lexmark Technical Support Center for additional assistance.
Jun 29, 2011 | Lexmark X7170 All-In-One Scan/Copy/Fax and...
My Lexmark all in one won't scan the entire document. No matter what size setting I put it on (I get the 'most' scanned on Automatic, but it is still less than half the page.)
Do you get the same result when making a copy using the Copy button on your printer operator panel? Try to remove the power adapter from the printer.
Wait at least 10 seconds before replugging the power adapter. This will give enough time for the printer to reset itself. When the printer turns on, reinsert the cartridges. Load some paper and try to make a copy or scan again.
May 05, 2011 | Lexmark JetPrinter X1185 All-In-One InkJet
How do I copy documents?
Unfortunately you won't be able to copy directly from this machine since it's only a printer. If you have access to a scanner you can use it to scan your document, save it to your machine, and then print it on this device. Otherwise you'll need to purchase a Multi-Function machine that includes a Scan/Copy feature.
May 05, 2011 | HP Hewlett Packard LaserJet 1018 Printer
My brother mfc 210c won,t scan or copy
I just called Brothers product support and found out that these machines WILL NOT scan or copy or do anything until the ink cartridges have been replaced. So there is no other solution.
Nov 26, 2007 | Brother MFC-5840CN All-In-One InkJet...
12 people viewed this question
old marine
old marine
