Question about Canon Pixma MX452
My printer says there is a printer support problem and won't copy
It won't copy
  • doubee Apr 03, 2014
    Hi Teresa Sarah Nunno, I want to help you with your problem, but I need more information from you. Can you please add details in the comment box?
    Please give me the exact message in the display of the printer.
Changed cartridge and now won't print a document
Verify the data cable or the PC printer setting,perform the test page,if you make a copy not problem the cartridge change.
Feb 25, 2013 | Canon Pixma MX410 All-In-One Printer
The copies has a ck or ch message and won't copy.
please check that all the door switches have been made and the front cover closes properly. Also ensure that your toner box unit is properly inserted.
Jan 07, 2013 | Sharp DM 2010 Laser Printer
The top left "hinge" won't seat, therefore the top feed can't be used to fax, scan or copy.
It's possible that the hinge of the scanner cover broke. If that's the case, you won't be able to scan from the ADF (Auto Document Feeder). If the printer is still under warranty, please call our technical support team to have the printer replaced.
Aug 10, 2012 | Lexmark Pinnacle Pro901 Inkjet Wireless...
Won't scan, light doesn't come on
Make sure the printer can copy (without computer). If you can make copies, the problem may be the computer or the USB cable. If the printer does not copy also. The problem is in the scanner or in the flat cable.
Apr 10, 2012 | Canon Office Equipment & Supplies
My office jet G85 won't print. No error messages appear,it has a new color cartridge,it copies, but won't print from my computer.
If it copies ok, then the issue is either the way it is cabled to computer or the print driver software settings on pc.... How is it connected via USB? Check port and correct driver is in windows/control panel/printers. Reinstall.
Nov 30, 2011 | HP OfficeJet G85 All-In-One InkJet Printer
Hp photosmart premium wifi failure
@ Other computers might be beyond the range of wi fi limits, run the CD in other computers ask to detect.. if not detected suspect out range.Check obstructions of walls, beams, magnetic fields.
@ If printer is not scanning check whether copy happening or not, if copy is happening uninstall the drivers and reload it once again, if copy not happening check scanner unit warming up or not.
Nov 24, 2011 | HP Photosmart C6180 All-In-One InkJet...
X4270 won't copy after replacing black cartridge. It did run an alignment page, however.
Try this approach:
  1. On the printer operator panel, on Copy mode, press Options.
  2. Select Maintenance.
  3. Select Clean Cartridges
Your printer will then print a test page forcing ink through the cartridge nozzles and clean them.
Try to print your document again to verify that Copying is properly functioning now.
Aug 08, 2011 | Lexmark X4270 All-In-One InkJet Printer
How do I copy documents?
Unfortunately you won't be able to copy directly from this machine since it's only a printer. If you have access to a scanner you can use it to scan your document, save it to your machine, and then print it on this device. Otherwise you'll need to purchase a Multi-Function machine that includes a Scan/Copy feature.
May 05, 2011 | HP Hewlett Packard LaserJet 1018 Printer
My brother mfc 210c won,t scan or copy
I just called Brothers product support and found out that these machines WILL NOT scan or copy or do anything until the ink cartridges have been replaced. So there is no other solution.
Nov 26, 2007 | Brother MFC-5840CN All-In-One InkJet...
Canon Pixma MX452 Logo
old marine
old marine
