Question about Brother 1034D Mechanical Sewing Machine
Cutter knife switch not moving to left on Brother 1034D
Need help. Cutter knife switch won't slide to left to deactivate knife.
    New Friend:
  • 3 Answers
Not sure but try pushing the blade down with your finger then moving the switch to the left.
Posted on Apr 02, 2014
SOURCE: Brother 925D - threads do not lock
threads do not overlock stich
Posted on Sep 27, 2008
SOURCE: parts for 1034D brother serger
UGGGGHHHH I Give already!!!!!!!!!!!!!!!!
I have been online looking for two weeks every night, i have hit every store i can think of. Even the store the Brother 3034D was purchased at and i STILL cant find the replacement knives. I am getting them as a gift for a friend for Christmas and talk about a nightmare. I have tried more than 20 sites. I give in... HELP!!!
THanks
Posted on Nov 25, 2008
  • 3 Answers
SOURCE: Brother 1034D
I had the same problem with the blue thread- it would sew and inch then pop- mine worked wihtout breaking after I re threaded in this order: green, blue, red then yellow
Posted on Sep 17, 2009
  • 1116 Answers
SOURCE: How do you thread the brother 1034D serger? A
You can download a free manual at the Brother website http://www.brother-usa.com/ModelDocuments/Consumer/Users%20Manual/UM_1034D_ENES_178.PDF
Posted on Mar 16, 2010
SOURCE: My 1034D Brother Serger foot raiser lever on
mine just did the same thing - i opened it up (you have to remove the light) and it's a small plastic piece that seems to be just glued into place to lift the pressure foot when it rotates... a bit disappointing - i will try glueing it back but i don't know if it will last for long. i am very disappointed!!!
Posted on Sep 16, 2010
Trim sensor error
Dust may have accumulated within the moving cutter.
Clean the moving cutter.
For details, see "Maintenance (Cleaning around the needle plate)".
Jan 17, 2018 | Sewing Machines
Why does lower knife hit the upper knife?
the serger needs to be checked to see if it needs a adjustment or if there is a timing problem
Mar 14, 2016 | Brother 1034D Serger Sewing Machine
Cutter not working
Hi Jackie, I'm Julie, what brand and model of sewing machine are you using, please?
Aug 05, 2015 | Sewing Machines
How do I adjust the seam allowance to cut 1/4 inch
Hello
To the right of the cutter, on the front cover, there are markings indicating various seam allowances. Placing the fabric edge along the specific seam allowance will automatically cut off the required amount of fabric and the serged seam will be on the seam line. Do a test sample first to ensure that the marked lines refer to the left needle or to the single needle that you are using.
Yes, there is a blade position dial too. It is located closest to you on the left side on the bottom. The larger the number, the wider the seam. Again make a few test samples to ensure the results that you are seeking.
Happy stitching.
Sep 10, 2014 | Brother 1034D Serger Sewing Machine
Machine wont cut
Sounds like the blade didn't go in all the way. Try to reingage it. You should feel/hear a click when it is where it needs to be. Good luck
Jun 28, 2014 | Brother 1034D Mechanical Sewing Machine
Knife cutting knives
Remove the stichplate and snap out the plastic cover over the thread cutter (left most end of machine). This exposes the thread cutter mechanism. You should then be able to position the knife arm back into the mechanism (two pins on the cutter mechanism that insert in a hole in each actuating arm).
Apr 11, 2014 | Husqvarna Viking 1
Brother 1034d serger. Seems unusually noisy (mechanically) in needle/cutter area. Not motor or belt as noise is metal parts clacking even after new needles, cleaning, oiling. Is this sound normal for...
in response to all serger, no, after my babylock serger is cleaned and serviced it runs quietly.
as for the brother, it's possible thats normal, try contacting a repair shop in your area and tell them about the serger and see what they say.
it's possible that the serger may need some type of adjustment
or a part may have broken .
Sep 06, 2013 | Baby Lock Eclipse Serger
We are hving problems with the juki ddl 550. the automatic thread cutter is not cutting.
hi there
1 - remove throat plat and mak sure the movment for thread cutter working or NO if working maybe need to change fixed knife or movable knife.
2 - if no movment mak sure plug for cutter solenoid is connect secur.
3 - make sure the output signal is coming to the cutter solenoid or no.
4 - maybe solenoid is dameged and need to change.
with my best regards
ashraf abozid
aabozid@hotmail.com
Nov 05, 2010 | Juki DDL-8700
Open Questions:
See all Brother 1034D Mechanical Sewing Machine Questions
Brother 1034D Mechanical Sewing Machine Logo
114 people viewed this question
Top Brother Sewing Machines Experts
Tally Girl
Tally Girl
Irene Tulloch
Are you a Brother Sewing Machine Expert? Answer questions, earn points and help others
