Home | Nokia | IP 350 Firewall | Messed up Bootmgr on a N...
Nokia IP 350 Firewall
Problem for Nokia IP 350 Firewall
Messed up Bootmgr on a Nokia IP350
By gr8m8 on Jun 15, 2009
I have a Nokia IP350 firewall appliance running IPSO 3.7. I have to upgrade this to Nokia IPSO 4.2.
I have started the process by accessing the bootmgr after a reboot. I issued the "install" command and it has prompted me for a password. All personnel that might have known the password have moved. I found several solutions which suggested removing the hard drive, doing a dd copy of the nkipflash.bin file and the result is now the bootmgr has been hosed. At the current time, the bootmge prompt does appear but only after I receive the following on the console:
/dev/wd0f on /mnt: Incorrect super block
Error: /image on /dev/wd0f
does not exist or is not a file
umount: /mnt: not currently mounted
boot failed
Any help would be appreciated.
Comments:
Jun 16, 2009
- While this reply was helpful, it does not fix my problem. At the bootmgr prompt, ftp is not available as a command option. I can not issue the "install" command without having to issue a password to verify that I have access to the hard drive. That bootmgr password has been lost/forgotten. I have tried a "dd" copy of the nkipflash.bin prior to this as well. I beleive that is what messed up the boot process.
Sponsored Links
Solution #1
posted on Jun 16, 2009
Somewhat Helpful)
ciscoroute
Rank: Wiz
Rating: 84%, 34 votes
Have you tried the steops below
1. Get the IPSO image you want to install.
2. Copy it to an internal host capable of FTP.
3. Connect to the console on the IP130 and start it up, when you
get past the bootmanager part where it shows the prompt
BOOTMGR[1]>install then ftp or help a few other commands
4. The interactive prompts should help you figure out what to do (like assign it an IP and ftp to the server).
5. Let it install the image and reboot.
Was this helpful?
Yes
No
Popular Solutions for Nokia IP 350 Firewall
Questions and Unsolved Problems for Nokia IP 350 Firewall
Do you recommend Nokia IP 350 Firewall?
Answer
Answer
Where are the historical logs? Need to clear some space. IP 350 IPSO 3.9
Answer
how can i unlock the barracuda span blocker i need a password and a username
Answer
i just got dumped in alaska for a year and my school has this idiot barricoda thing that blocks... (More)
Answer
unlock the spam blocker barracuda to get to crigslist
Describe your problem:
Select a Category:
Sponsored Links
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Nokia IP 350 Firewall:
Top Firewall Experts
Rank: Guru Guru
Solutions: 3237
Experience: Semi retired, was network administrator, proficient with hardware, software, networks, CAD systems
Ask Me
Find more Firewall Experts
Top Computer & Laptop Repair
(952) 890-7770
Zkarlo.com provides discount and used laptop parts...
Zkarlo.com
(513) 874-3306
We fix and repair laptop motherboard no video, no...
LaptopOnCall Inc.
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
