I have a H.264 Network DVR User Manual & see Chinese but can't login.
I have a H.264 Network DVR User Manual & see Chinese but I can't login. How can I hard reset the device to get logged in or bring it up in English?
  • 3,320 Answers
There is little point in posting a question with no real information.
Saying something is "broke", "doesn't work", "can't connect" or that you "need" or "want something" is pointless without ALL the information.
What actual products are you using? Makes, models, connections...everything about your problem is necessary. We are not there with you. We cannot see what is obvious to you. Most problems occur when you try to get something to work with something else. We need to know all the things you are using and doing that ends with your issue.
The issue is the last thing we need not the only thing.
If you did something stupid, then tell us. We aren't going to laugh at you, we want to help you. In all likelihood we did something similar and so we know if it can be fixed.
If you hope that by lying about the situation we will be able to fix your issue, you are WRONG.
If you are trying to do something illegal we know about that too.
We want to help you. We do not get paid for our work. We do it because we want to share our knowledge and help you.
If you do not post complete information, most likely your question will go unanswered, so you wasted your time and our time reading your post.
Posted on Apr 02, 2014
5 Suggested Answers
  • 192 Answers
SOURCE: factory default password/user name
contact linksas they might know
Posted on Jan 03, 2009
SOURCE: Got a dvr video system. connecting to network problem
I love it when people provide so much information such as the make and model of the DVR and the ISP. Makes it easy to figure out the problem, which in this case is most likely the ********* who is asking the question.
Posted on Apr 05, 2009
SOURCE: Cannot reset or log in as Admin
if you reset the router to factory settings, leave the username field blank, and use "admin" for the password
Posted on Apr 06, 2009
  • 60 Answers
SOURCE: sbg900 router, login problem
try to configure the browser settings, follow the steps below
1. Go to internet options and select the security tab
2. Highlight Internet and click customer level button
3. Scroll down to the very bottom, under user authentication select automatic logon with username and password
4.rest customer settings to medium
Posted on Jul 16, 2009
I want to reset my h 264 dvr but the remote stop working only the logo screen comes up
CCTV & Networking Technical Support
1. Connect Your DVR to Network.
2. Press Window Key + R in Your PC and Type "ping -t (DVRIPADDRESS)" if it is giving reply then you are ready to process next step.
3. You need to access your dvr with telnet port (23)
for that download tool "Putty" Link: https://www.chiark.greenend.org.uk/~sgtatham/putty/latest.html
4. Open Putty Tool and input dvr ip and port 23 (telnet)
click connect login username: admin password: xc3511
if success then email me on nitinplus@gmail.com
I will help you to reset your DVR.
Visit:- CCTV Networking Technical Support
Nov 28, 2017 | The Home Security
Why can't I login to my DVR web interface?
If you on are the same network as the DVR, you should be using the DVR's IP. Usually a 192.168......., depending on your service or router (COMCAST, AT&T etc...)
Aug 31, 2014 | Home Security
Forgot login password
Default User and Password on Everfocus is usually
Admin
Admin
Nevertheless, you should contact your local distributor, and after providing the product serial number, they can generate a reset user and password, that shall be used only once, and then, you must enter a new user/password combo.
Nov 16, 2012 | EverFocus ECOR264-9X1/2T ECOR264 Series 9...
Faget id password
USER LOGIN" device id 000000 end password ??????
Aug 09, 2012 | Digital Peripheral Solutions New Q-See...
I have a H.264 DVR with system V2.00.R05. What app or system can I use to view on a iPhone 4S?
IP CAM VIEW found in the Itunes Market: http://itunes.apple.com/us/app/ip-cam-view/id471794610?mt=8# should work as long as you have the network settings properly configured in both your DVR and Home Network. I recommend setting a Static IP for the DVR on your Home Router. After you have assigned the IP goto the network settings on your DVR and input the IP Address you assigned, the SubnetMask of your Home Router(usually 255.255.255.0 or 255.255.252.0), and the Gateway of yourHome Router.(i.e. 192.168.0.1/192.168.1.1/192.168.1.254). While you are on your Network screen I recommend changing your default TCP Port andHTTP Port to something that is not commonly allocated. As with most Routers you must Create a pinhole in the firewall to allow the outside traffic in. Select your DVR's IP on your Router and Create Definitions for both Ports that you set on your DVR's Network Menu. If your DVR and Router didn't reboot after saving these changes reboot.On the phone ap I found the following two cameras to work with the H.264 DVR System V2.00.R05:
  • Make: Unknown Brand Model: DVR-9008HV
  • Make:A.V.Sistemi Model:A.V.Sistemi 61xx DVR
For the Host/IP field, You use your Home Routers Internet IP. TCP port is the number you set on the network menu of your DVR. Ch.# is the Channel Cam (1-8, and 9 being a single feed of all 8 channels)user names and passwords are case sensitive.
I hope this helps
Jul 07, 2012 | Apple iPhone 3G
I need reset the password on a 16 ch. dvr dvs do you know how i can do this?
I have a H.264 Network DVR with ver. V2.00.R05 and I've forgotten the password can anyone help with resetting it...
Mikw
Nov 05, 2010 | CSi Speco Speco DVR-T4IP 4-Channel Triplex...
Open Questions:
Can I hold DHHS accountable for the burden they put upon me? If not, is there someone that can be held accountable? What can I logically and honestly do to remedy this prob. I explained my prob below! I was getting QMB part of Mainecare and my spouse at the time we were dating but living together was getting the QI part of Mainecare. We are both disabled and only get SSDI. However being honest and do our best to always do the right thing we go to DHHS office on Griffin RD in Bangor, ME within a month of us getting married where the worker we saw tells us we don't qualify for anything but the min of FS and both Q1 part of Mainecare and serious voice tells us to divorce. I have made a few trips within last months to same DHHS. One sends us to Eastern Area of Aging to see if there were secondaries we can get. This past Monday hubby and I went to our appt with Eastern Area of Aging & was told they strongly believe I could get spousal exclusion also warning it could mean my hubby loses help but because it was a volunteer a newer one at that she couldn't tell me definitely cause she didn't know the formula as she still learning; tells us to go back to DHHS to ask about spousal exclusion. So I go back to DHHS this past Thurs and got a worker with more smarts, heart with approx 10 yrs working for DHHS tells me I qualify for spousal exclusion and took the time to answer all my questions. I told her I had QMB till hubby and I married June 2016 & shared with her what the DHHS worker told us when hubby and I went in to show marriage certificate to update the change. She looked at me with shocked eyes and dropped jaw in bewilderment. Then says I would of never lost it as I would of qualified for spousal exclusion from the day we married. And had it been her that we got when we were being honest wouldn't have only told me about spousal exclusion but would of applied me as she could see I have major medical problems that is too much a financial burden for my hubby and I. She also told me I was to submit all unpaid bills even if monthly making payments were being made. I thought I was only to submit bills I paid in full or on a payment plan. So started Thurs night on a Medical Bills Tracker to go through all the medical bills and sort things out. I haven't even put a dent in the pile and see I'm responsible for just over 6K I'm predicting once done I could be closer, if not over, 10K. In collections is currently 1K but once done with pile amount in collections could be closer to 2K or more. So the mess has impacted my credit and if things were done by professionals I wouldn't be losing my hair stressing over my medical bills and how it declines my credit. I know I'm in a small group that actually pay their medical bills any and all bills to be honest! I am disabled and get SSDI. Worked 1992-2013 a lot of times working 2 jobs! Dr in 2013 practically dragged me out of work as was just diagnosed with Hep C, CKD Stage 3 & liver disease! I also have depression disorder, panic attacks, anxiety disorder! So even this incompetent DHHS worker putting extra financial burden on me unnecessarily affects those things. I am trying to do the right thing but get kicked down by the very people that are paid to help me. What are my rights and can I fix this at a faster pace then not even fixed it by the day I die?
Jun 23, 2018 | Major Computers & Internet
Computers & Internet Logo
47 people viewed this question
David Payne
David Payne
