How to fix 50.7 fuser error turn off and then on on hp clor laserjet 2605n
When the is turn the fuser moter runs but the main motor does not then it show 50.7 fuser error turn off then on
Hp color laserjet 5500 error 59 ck printer error
list of error codes
http://www.printertechs.com/printer-troubleshooting/hp-error-codes/195-numeric-error-codes-50-59-hp-laserjet
HP COLOR LASER PRINTERS 4600, 5500 ERROR 59.3, 59.4 1. A fuser motor error. 2. Replace the fuser drive assembly. 3. Replace the D.C. controller board.
Jan 04, 2017 | HP Office Equipment & Supplies
What is Error Code:59.A0 for Hp laserjet 400 M401d?
A main motor error occurred. X description: 0 = Motor error 1 = Motor startup error 2 = Motor rotation errorA main motor error occurred. X description: 0 = Motor error 1 = Motor startup error 2 = Motor rotation error HP LaserJet Error Codes 50 59 Looks like a motor error check the fuser unit and drum are seated properly.
Mar 09, 2015 | HP Office Equipment & Supplies
59.9 Error turn off then on
1. Turn the printer off, and then turn the printer on.
2. Check and reseat the fuser and toner cartridge to make sure they are not hindering gear movement in the drive train.
3. Check the main motor's cable to ensure that it is seated properly.
4. Replace the main motor.
More Info... Hp Error Code 59 Service Repair Errors 59 Fix Codes Message And...HP Printer Support
Thanks,
Jul 10, 2014 | HP LaserJet Pro 100 color MFP M175nw -...
Hello, I have a HP Color Laserjet CP4525. After it starts, it gets an error 59.CO error. Can you offer any advise to rectify this problem? Thank you
Its a 3 step process follow it it will fix your issue
3. Check the main motor's cable to ensure that it is seated properly. 4. If the error persists, replace the main motor.
Feb 28, 2011 | HEWLETT-PACKARD 110v Fuser Kit Fuser Unit...
How can i fix hp3600 59.Fo error
59.X PRINTER ERROR A main motor error occurred. X description: 0 = Motor error 1 = Motor startup error 2 = Motor rotation error 1. Turn the printer off, and then turn the printer on. 2. Check and reseat the fuser and toner cartridge to make sure they are not hindering gear movement in the drive train. 3. Check the main motor’s cable to ensure that it is seated properly. 4. If the error persists, replace the main motor.
Apr 21, 2010 | HP LaserJet 3600n Printer
How do i fix a 59.90 error?
Mar 19, 2010 | HP LaserJet 3600n Printer
Hp 2605n Fuser error 50.7
50.7 means that the photo sensor ps6 detected no movement
Open the side of the printer power on the printer and check if the fuser motor moves forward and back. If it does the problem is with the movement sensor or feedback circuitry. If it doesn't its the motor, gear system jamming, motor driver or power supply pcb.
Aug 11, 2009 | HP Color LaserJet 2600n Printer
I get a 59.4 error trying to print with the 2840
The problem is not the fuser, is the main motor, you have to change it
May 26, 2009 | HP LaserJet 3600n Printer
HP Laserjet 5m, appear error code 50...please help.
Error 50 will be a faulty fuser unit or DC controller board. Try replacing the fuser unit.
May 20, 2009 | HP LaserJet 4m plus Printer
Hp color laserjet 4700dn error code 59.30
turn off the printer. remove the duplex device from the printer. turn on the printer. enter the diagnostic menu. enter the menu for sensor and motors. select the fuser motor and let it run. if you can hear it its ok (its not such a noicy one ... you have to listen very good) - follow up the next steps:
turn off the printer. turn on the printer. enter the service menu - pin code is: 09470005. set to 0 all counters for mono print, color print and the counter after service. leave the menu.
turn off the printer, reinstall the duplax device. turn on the printer.
result: the error msg is gone. its just HP wants to sell theyr service contracts.
Feb 25, 2009 | HP LaserJet 4700 Printer
Open Questions:
k24674
