Question about Keurig B60 Coffee Maker
Ran out of water , need to prime
Trying to clean with vin
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 92 Answers
Lift the reservoir, then reseat it. This will clear the prime message. If it repeatedly comes back then your machine is dead. If in the year warranty, call Keurig they will ship you a replacement. Good luck.
Posted on Sep 28, 2014
Machine says needs priming. Water light stays on but no water comes out when opening valve. No water for coffee either. Water pump broken?
hi,
can you hear a quite louder noise when trying to make water flow?
If no or very faint noise can be heard, pump is probably faulty or needs to be disassembled and cleaned (see tutos on the Net)
If you can hear a loud noise, the pump is working but unable to suck water, keep on trying, if still unsuccessfull you will have to open the machine and fill yourself the watel inlet tube to "help" the pump priming.
Hope that thelps
M
Apr 24, 2016 | Saeco Incanto Classic Espresso Machine
Well pump losing prime
you might have a leak in the foot valve, you can try installing a check valve several inches before the intake to maintain a prime, or check and clean/replace the foot valve.
If the pump ran dry, check the inlet fitting. the pump can get hot and melt pvc piping connected to it, causing air to leak in the inlet side.,
Feb 14, 2014 | PENTAIR WATER Pentair Sta-Rite DynaPro 1HP
How do i reprime ?
Close the supply valve to the tank. Open the priming port of the pump, (plug on the upper most part of the casing) pour in water until the pump is filled -up. Close the plug just finger tight. Run the pump. slightly open the plug just to bleed the air with little water. If all water is coming out, the pump motor should cut-off indicating the pump is already primed. Gradually open the supply valve. Pump motor will restart again.
Nov 12, 2012 | Fresh Water Systems WellMate Tank Fittings...
Does this pump Dynamo DYN 11-n1-1 serial no 1-23-JO9 have to be backwashed and if so...how?
Pumps don't need to be backwashed, some filters do. Sand and DE filters need to be backwashed when the filter pressure has increased to 10 or 11 psi. depending on the manufacturers recommendation. The cartridge filter cannot be backwashed but instead it is removed and a hose sprayer is used to clean out the dirty outside. Your pump does need to be primed so it is not trying to pump mostly air. Each time the pump basket area is low in water then it needs to be primed. You will know how low it can go before it needs to be priming by turning it on when it is low and if it cannot start pumping water at full rate then at that level of water it needs to priming. If it is pumping water at full flow and you turn it off it should not need re-priming because there is enough water in it to force the air through the system. I hope this helps.
Aug 14, 2011 | Dynamo ABOVEGROUND POOL PUMP - 3/4HP -
Brand new GE modelGLD4408RWW, runs for avery long time on the normal cycle (3 or 4 hrs.). Did not even flush the detergent out of the cup on the light wash, which ran for about an hour and 30 minutes. The...
is the water hot enough prime the sink first then start the dish washer/make sure its hooked to hot water i know it sounds dumb but i have ran across that
May 14, 2010 | Dishwashers
I have a Sta-Rite Max-E-Glas II (1.5hp) Pool pump and a Hayward Navigator sweep. The sweep was working then stopped. Pulled it apart found bad bearings replaced them. Ran sweep again worked at first...
Is the pump leaking water? If you lost the prime or are having trouble priming then there would be an air leak somewhere on the suction side of the pump. Poor suction would interfere with the sweep. One way to ell if the pump or suction line(s) are leaking is to examine the inlet basket once the pump is primed. Any air left in there after a few minutes of operation once primed would indicate a leak in the suction/pump.
Jan 04, 2010 | Zodiac BARRACUDA G3 IN-GRND CLEANER
Noy working
Well, ok, I found that I just needed more water to prime it.  Apparently, a self-prime pump needs to be primed pretty well to use the first time.
May 23, 2009 | Dynamo Garden
My Gaggia stopped pumping after I ran it pumped for 10 minutes
Hi
First thing don't use vinegar because it can damage your machine. Citric Acid is what you should use. You may need to prime the machine again. Force water down the intake receptacle below the water tank.
May 03, 2009 | Saeco Vienna De Luxe Espresso Machine
Keurig B60 Coffee Maker Logo
87 people viewed this question
Top Keurig Coffee Makers & Espresso Machines Experts
Lisa
Lisa
Jason
Are you a Keurig Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
