Question about Gateway FPD1975W 19" LCD Monitor
The screen on my Gateway monitor suddenly went light blue. Has anyone else had this problem or know the solution to get it back to white?
  • 2 more comments
  • rcirrigation Jun 15, 2009
    yes
    yes, I was going to try that later
    already tried that but didnt change anything
    Thanks for your input...I'll try another computer later.
  • 110 Answers
Does the screen remain the same color when you turn it off and back on, unplug it and back in, or disconnect it from the pc and reconnect it?
Posted on Jun 15, 2009
  • 1 more comment
  • tgp1994 Jun 15, 2009
    Is it possible that you could try plugging it into a different pc, or even a laptop?
    Ok. If you want to right now, try accessing the monitor's menu (should be a button for that somewhere on the screen itsself) and see if there is an auto adjust button.
    I guess you ought to try it on a different computer then.
FPD1975W TFT LCD monitor my monitor blinks a blue power light and flsahis a white screen but it does not turn on ?
A flashing power light indicates a failure of the power supply, this will also cause the white screen. Here is a link to a page showing what parts need to be replaced to repair the power supply board and get your monitor back running again.
http://www.ccl-la.com/blog/index.php/gateway-fpd1975w-monitor-repair/
I hope this helps, if so please rate my solution,
BuddyMc
Oct 09, 2011 | Gateway FPD1975W 19" LCD Monitor
My moitor fpd1975w blinks blue power button and a white screen but does not turn on ?
The blinking power light is a good indication of a failed power supply board and the white screen backs that diagnosis up. Here is a link to information show what to look for and replace on the power supply board to get the monitor back up and running again. The repair involves replacing parts called capacitors on the power supply board and can be done in less than 20 minutes once you have the parts needed.
I hope this helps,
BuddyMc
I was watching a youtube video. Started fast forwarding through the video when all of a sudden the computer screen went white with light blue streaks but computer was still running. I could still hear...
Try connecting a know good monitor and see if you are able to see the display, if so your monmitor is toast and needs to be replaced. I hope this helped. Good luck and have a great day.
Jun 18, 2011 | Computers & Internet
Gateway FPD1750 monitor's keep go black screen, no picture at al
tgordon60, If you know how those NEW "CURLIE-Q" energy efficient CFL light bulbs produce WHITE LIGHT, then you will know what makes an LCD display panel produce all the pretty colors and the WHITE BACKGROUND of the FIXYA web page!!! Only difference is that your "cold-cathode-fluorescent-lamps" are thinner and straight, and hung on rear of LCD glass panel and have a DC to AC electronic ballast called an "INVERTER" circuit to produce 600 to 1000vac to light them up. Get to my FIXYA profile and read my responses to other BLACK screen lcd owners to learn about all your options for repair. Follow any of the links to other web pages you find there. Your monitor not any different than ACER, DELL, VIEWSONIC, BENQ, SONY, AOC!!!!! 12fixlouie aka louie12fix
Dec 30, 2009 | Gateway Computers & Internet
No picture - blinking blue light. My daughter was
There are a few things you can check. First, try to see if the monitor cables are firmly connected on both sides (computer and monitor) no need to remove any cable for now just check the monitor cables (ends should be blue or white on both sides) Then check if you got an imput button on your screen (like all TV and some monitors now has) This input gives you the choice between a few possible connections and it may be on the wrong one. Just cycle trough the input modes and I think you will have your image back. If Still, you dont see anything, try a different monitor or try to connect your monitor on a different PC/laptop. In fact blinking blue could be there because the monitor is awaiting a signal on the input it's listening. At worst it could be because your video chip/card dont send a signal to your monitor, could happen, but imo it's probably not the case.
Jun 08, 2009 | Gateway 1532121 Monitor
White screen
Blue and whit screens of death. these are hated as if it is the video card you will need it replaced. if it is the screen then replace it . to find out try it on an external monitor. if it is still white, you're laptop is toast! the internal graphics card is fryed and cannot be removed. either get it fixed or buy a new one.
do not attempt to fix it your self it will only be worse.
Apr 15, 2009 | Toshiba Computers & Internet
Black screen after a couple of seconds
The monitor needs to be replaced. I had an LG LCD that did this luckily it was still under warranty. Contact the maker and have your receipt handy. Otherwise buy a new monitor. Monitors tend to be replacement only
Apr 11, 2009 | Gateway FPD1960 19" Flat Panel LCD Monitor
Syncmaster Screen went blank on my Dad
check and see if there is any buttons on the side of the monitor or in the front area. also, check wiring plug connections.
Jun 21, 2008 | Gateway FPD2275W LCD Monitor
Monitor (model #LCM 17v8), has suddenly gone "white".
Just done fixing 2 of these "white out" (model #LCM 17v8), monitors. Contact me at ekwhoward@yahoo.com for solution.
Thanks
Feb 16, 2008 | Gateway FPD2275W LCD Monitor
Gateway FPD1975W 19" LCD Monitor Logo
147 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
