Question about Edimax 3G6200n Wireless Router
No power but power supply is good
No light monitor in power, wifi and lan even thier is cable connected in respective port,only the monito light of wan and 3G is lighted if i plug to the power source
2 Suggested Answers
  • 669 Answers
SOURCE: I've setup the router (edimax 3G-6200n)and all was working well for a couple of days. This morning however, only the power light is on. The LAN network cable is fine as i connected it directly to
If the only light you have on is the power light, it is most likely dead. You try unplugging the router then plugging it back in to see if this clears the issue. If it does, the issue will probably come back. Your best bet is to replace this router.
Posted on Apr 04, 2012
EdiMax Br-6482nS doesnt give internet
A router is only used to connect devices together in a LAN (local area network). In order to get out to the internet you also will need a modem (cable or dsl depending on your service) You will also need to pay for service through an ISP (Internet Service Provider)
May 02, 2013 | Edimax Computers & Internet
TP-Link TL-WR642G recovery after failure upgrade to latest firmware
may find this page helpful. http://www.dd-wrt.com/wiki/index.php...om_a_Bad_Fl ash Its not for the TP-Link router but the same principle could be applied to you with the correct firmware. Its worked for me on more than a few occasions. Providing you can ping the router via a lan cable then the chances of recovering it are very high.
Apr 19, 2012 | TP-LINK TL-WR642G Router
HELLO My problem is that I cannot enter to the configuration of router, that is to say which is the direcion of ip and to come in the explorer up to where he asks for the login me of which the defaul is...
Hi - I suspect that you may possibly be attempting to log on to a different router than you Encore ENHWIN3. This can happen if you're trying to access it wirelessy or if this router is connected to a LAN port of another router "upstream".
1) Power off the cable modem or DSL modem, Encore ENHWIN3 and the computer(s).
2) Connect the first network cable to the LAN or output of the cable modem or DSL modem.
3) Connect the other end of the first network cable to the WAN jack of the Encore ENHWIN3.
4) Connect the antenna to the Encore ENHWIN3.
5) Connect a second network cable to any one of the numbered LAN jacks on the Encore ENHWIN3.
6) Connect the other end of the second network cable to the computer's network jack.
7) Power up the cable modem or DSL modem, and wait 30 seconds.
8) Power the Encore ENHWIN3 and wait 30 seconds. The red power LED indicator should be on. The WLAN (Wireless LAN) should also be on or flickering. If the DSL or cable modem is passing data, the WAN light should be on or flickering.
9) Reset by PRESSING AND HOLDING THE RESET BUTTON IN FOR 10 FULL SECONDS.
9) Power up the computer that is connected via network cable to the Encore ENHWIN3. Wait for the boot process of the computer to complete.
10) After login to the computer, the LAN port number associated with the connected computer should be lit up or blink green on the front of Encore ENHWIN3. If the LAN piort number is NOT lit or flickering, remove the cable from that numbered LAN port and reconnect to a different LAN port. The new LAN port number should light as described above.
11) Open your browser (IE, Firefox, Opera, etc.) and type 192.168.0.1 into the address bar. Supply the default username "admin" and password "admin" to access and change the defaults of the router.
You can view the manual for the router here. I hope this helps and good luck. Please rate my reply. Thanks!
Jun 27, 2011 | Encore ENHWIN3 Wireless Router
When powering on get no input to monitor board nu a7n8x-e
Make sure you have connected into the correct video port. DVI should be used for LCD monitors and VGA should be used for CRT monitors. Since both ports look the same people often get confused. Try it and let me know.
Sai.
Jan 02, 2010 | ASUS A7N8X-E Deluxe NForce 2 Ultra 400...
How do i use external monitor with acer aspire 5516-5474
look for the 9 pin plug similar shape to that on the monitor but female.. check the rear of the laptop (plugs) and match the plug to the socket. The laptop will automatically connect and display once the plug is mated.
Please rate my help++++Thanks for usimg FIXYA
Nov 16, 2009 | Televison & Video
Acer X223W monito won;t wake up after sleep.
I have a dual monitor system, both are the x223w. Same problem but only on the second monitor. Backlight shuts off.On/off light stays blue. I have to turn off the monitor and turn it back on. I returned it and Acer could not find any problem so I got it back. No problem for awhile and now a few times over the past couple days. Not good...
Aug 10, 2009 | Acer 22" X223w LCD Monitor
Lan port will not light up when ethernet cable is pluged in
The lan link light will only come on if a valid connections is made between the device and another computer.Even if the computer is turned off the link light will come on as the computer still uses some standby power, check to see if the cables are terminated correctly on either sides, that the cable hasn't been cut or badly bent somewhere, possibly try the same cable on the same port with another good device.Also swap the cable with another known good cable and try on the same port and see if the light does come on.
Aug 02, 2009 | D-Link DI 514 Wireless Router (DI-514)
I have a new network printer (Samsung SCX-5635FN) I cant get connection to the printer. I have connected to the LAN port of my router and tried both DHCP and static IP. I have try to change the LAN cable...
have yo installed the printer on to the system ( add a printer ), have you installed the correct driver for the printer
it is not a matter of just connecting leads and expecting it to work
Apr 11, 2017 | OKI C5300n Led Printer
Laptop to pc monitor
Connecting the laptop to an external monitor hooked uip to the VGA connector at the back of the laptop cannot damage the laptop, even if the monitor is connected to a different power supply, as on the VGA port and cable there is not high voltage being carried.
Apr 05, 2009 | Computers & Internet
Help
Signal lost usually means the cable is lose that connects the monitor to the back of your computer.
with the computer off and unplugged , disconnect the monitor cable from the video port on the back of the computer and physically inspect the pins to make sure they are not bent on the monitor end.
some monitors have the same plug on both ends , so it doesn't hurt to check the monitor side of the cable.
Once the cable has been checked, if the cover is off the computer, i would check all cables and add-in card to make sure they are fully in thier slots and ports.
check memory for the same issues.
If your monitor is a multi-function device , make sure you didnt forget to hit the source button on it , could be on the wrong input.
Oct 23, 2008 | E-Machines eMachines Desktop PC
Edimax 3G6200n Wireless Router Logo
18 people viewed this question
Top Edimax Computers & Internet Experts
Prashant M
Prashant M
Michael Vincent Cruz
Are you an Edimax Computer and Internet Expert? Answer questions, earn points and help others
