Question about Kenmore Vacuums
Kenmore 116.25513506 vacuum electrical troubleshooting
Wont turn on ,power cord has continuity, hose has continuity powerhead runs with test cord.
reddevil6
  • 1673 Answers
SOURCE: Kenmore canister model 116.25512 won't start
Sounds like you have a switch problem. Some of the Sears models also have a relay in them, which could be bad. The complete model isn't stated so couldn't look it up. But you can go to Sears.com, click on parts, enter your complete model number and a parts list with diagram of parts will come up.
Posted on Feb 14, 2008
  • 1214 Answers
SOURCE: Brush does not turn on my vaccum
If there is no suction when you disconnect the beater bar assembly near the hand hold where you grab the vacuum, then there may be either a restriction in the vacuum line between there and the vacuum section (that rolls around behind you), or the vacuum line from the handle point to the rollaround section is not properly connected. This all assumes the vacuum motor in the rollaround is running.
The beater bar section does nothing but cause dirt particles to be sucked into the vacuum system. The vacuum or suction is created in the rollaround unit.
Posted on Jan 22, 2009
  • 3 Answers
SOURCE: Need to know if a replacement part can be purchased and where
IT CAN BE FIXED BUT YOU NEED TO KNOW THE ROPES
I HAVE THE KNOWHOW AND THE PARTS
PRICE IS 40$ + YOU PAY ONE WAY SHIPPING
RETURN IN 1 WEEK
EMAIL LESGUEST@VERIZON.NET
Posted on Mar 05, 2009
Vac Belts
  • 701 Answers
SOURCE: Sears Kenmore Whispertone Vacuum Problem:
If you push inwards on each side of the light cover on top you can remove it. With the light cover removed remove the (2) access screws. Now you will be able lift of the entire top cover from the base. You will then see the belt and roller brush, remove the old belt and replace with a new one. You can get the replacement belt you need here:
Kenmore Whispertone Replacement Belt
Posted on Oct 29, 2009
  • 3 Answers
SOURCE: I have a Kenmore Vacuum
The retraction mechanizm is likely jammed. Mostly likely the cord has jumped it's groove in the retraction wheel/hub. If you are good with tools there is a 70% chance you can get it to work again with a basic DCR operation. Most mechanical problems can be solved using this simple rule: Dissassemble Clean and Reassemble.
CAUTION: The retract mech has a powerful spring inside, avoid exposing. Most retract mech units are rivoted closed so consumers won't poke thier eye out.
CAUTION: UNPLUG THE UNIT
Open the unit from the bottom and the top lid of the canister should come off.
The retract mech should be obvious as it is where the cord comes into the unit.
Look for the cord being bound by iteslf either on top or underneath (lie two cordes in one groove)
Remove any binding.
If you see no debris or obsticals for the cord to retract (where it is getting stuck)
Your spring could have sprung!
Do you feel and retract at all?
Can you locate the releae mechagnism?
Does the Release button seem to function? When Pressed it should take pressure off of the cord hub.
The retract mech may need replaced. Overall the cost will be about $60 for parts.
Posted on Feb 12, 2011
Electrolux EL7055 powerhead not working
Have you tried testing the continuity in the hose, wand, and power nozzle? You can also try putting the hose directly in to the power nozzle. If you still need help with you electrolux vacuum try contacting evacuumstore.com
Nov 17, 2013 | Vacuums
Kenmore Progressive Vacuum electrical issue. My
It could be the wires or switch in the hose and/or the connection between the hose and the vacuum. It could be the power cord or a loose or bad wire inside the canister. It could be the carbon brushes in the motor are worn out. To find a short or electrical problem you need to know how to trace the power flow from the plug and cord all the way to the motor. You can test the wiring in the hose with an electrical tester to see if there is a problem with it before you purchase a new one.
Mar 08, 2017 | Kenmore Vacuums
My magic Blue vacuum is turning off and on when the hose ifs moved I think
I would recommend checking where the end of the hose attaches to. On Kenmore vacuums where the end of the hose plugs into the vacuum and to the powerhead there is normally two prongs that plug in to the canister and the power head. It is either one of the ends that is not connecting right especially if you say when the hose is moved. It may also be the cord inside the hose that connects to those prongs might be torn inside the hose or not connecting right to each end.
Jul 18, 2012 | Kenmore Magic Blue 24195 Bagged Canister...
Vacuum will not shut off
Sounds like you have wires crossed at the switch. The 2 wires coming in go to the center posts, 2 to the power head & 2 to the main motor.
Jan 31, 2009 | Kenmore 25512/ 25513 Progressive Canister...
Royal 3050 power head does not run
The sounds like powerhead motor either burned up, or the belt broke and got tangled in the turning motor shaft. Pull the bottom off the power head and look for a curled up rubber band. If you find one, it's the belt.
If it's the motor, you won't hear it running when you turn the powerhead on.
Jan 23, 2009 | Royal Procision 3050 Bagged Canister...
Jan 22, 2009 | Kenmore 25512/ 25513 Progressive Canister...
Powerhead does not work and the light doesn't work. Canister does work
Some of these has a reset button to push on the powerhead. Check the plug at the end of the hose handle, is it pushed in, if you push on it and it goes further in, then the tube in the handle will have to be replaced, the holding tab broke off of the tube. Pull the wand off and look at the prongs to see if they are burnt. it they are, then that power cord will have to replace as well as the want.
Jan 23, 2008 | Kenmore 23313 Whispertone Bagged Canister...
When you attach the hose to the wands, there is a connection made between the hose electrical receptacle and the cord from the powerhead. On the Kenmore, it is common for the receptacle on the hose to break away from it's seat and slide back into the handle. When this happens, the receptacle is not positioned far enough forward to make the plug-in connection. Look at the end of the hose and check the receptacle and see if it is sitting flush with the plastic opening that it sits in. If it is pushed back, that's your problem. Also check the re-set breaker on the powerhead. If you got something caught in the brush roll, the breaker will have kicked out to protect the motor.
Jan 20, 2008 | Vacuums
Hoover s3755 bagless windtunnel canister
Very likely it's the cord at the nozzle neck. These cords flex when you vacuum and they often break internally where the cord goes into the neck. Turn the vacuum on and wiggle the cord at the powerhead and see if the powerhead comes on and off. If this happens, then you will have to replace the cord.
On some of the early models, the receptacle in the hose, where it plugs into the top of the wands, will break away from the plastic pins it sits in, and the receptacle will slide back into the handle, which means that it will not plug into the powerhead connection when you connect the hose. You can check this by looking at the end of the hose and observing if the receptacle is sitting flush with the opening it sits in. If it is pushed back, it will not make a complete connection with the powerhead cord that is sitting at the top of the wands.
Jan 18, 2008 | Hoover S3755 WindTunnel Bagless Canister...
Power nozzle don't work
I don't know which model you have or how old it is, but most models have a cord on the hose that plugs into a receptacle on the main machine. Sometimes they can look like they're plugged in when in fact they're just barely hanging there. You could also check the cord at the powerhead. Because the cord flexes with the motion of vacuuming, the cords can break inside. Wiggle the cord while the machine is running and if the cord is defective, the powerhead is start and stop. On some models, there is a switch on the hose handle to turn the nozzle off and on, and these are prone to failure. Also, there should be a reset on the top right hand side of the nozzle, but if this kicked out, it indicates a motor or electrical problem and should be addressed by a service person. If your powerhead has this reset, it's possible that the reset is sticking. Push it down a couple of times and see if that helps.
Jan 15, 2008 | Rainbow 75th Anniversary Canister Vacuum
Vacuums Logo
54 people viewed this question
Top Kenmore Vacuums Experts
Chris Nomland
Chris Nomland
Are you a Kenmore Vacuum Expert? Answer questions, earn points and help others
