Question about Miele Washing Machines
I have a Brada BRW200BW Top Load Washer with a pulsator. All of a sudden it won't spin anymore.
It washes and drains but the pulsator isn't spinning anymore. When it gets to the spin cycle there is a humming noise but no spinning. Also a burnt rubber smell.
  • 641 Answers
SOURCE: Spin Cycle/Machine makes noise and moves
You can't tight up the tub. You should replace the damper pads that located beneath main support housing on base's machine. Goog luck !
Posted on Jul 26, 2007
  • 188 Answers
SOURCE: Kenmore front-load washer stops at rinse cycle
When the washer initially fills for the wash, is it only hot water entering the drum? Try switching the water temperature between hot and cold as it fills. If any of them show little or no water getting through, it sounds too easy but check to make sure water supply taps are on, and that the cold/hot fill hoses aren't reversed. Remove the fill hoses and check any of the screen filters for blockage (in the hoses and in the inlet water valve). When the machine stops and waits to fill but all you hear is a hum, it sounds like there is power going to the valve but water is not able to get through it.
Posted on Mar 03, 2009
JULIANFIX
  • 975 Answers
SOURCE: Burnt Rubber smell and spin cycle didn't work
the main motor needs to be serviced , sounds like the couplings broke , hope this helps , AJ
Posted on May 18, 2009
buckeruu
SOURCE: GE WASHER WJRR4170G0WW-SPIN Cycle does not work- just make sound.
My washer is 2 years old and this is 1/2 the cost I paid for it new. My review of this product after 35 years of technical experience; GE products (Hotpoint)aren't worth buying any longer.
The problem is the Motor. There is an electronic PC Board attached to the top of the motor and under the drip protector, which protects the PC Board. On this board, there is a green flashing light which displays trouble codes by flashing. Unplug the washer, remove the 3 screws from behind the control panel. Slowly pull the control panel toward you and slide it to the right to release. Inside the washer, there is a diagram with the trouble codes printed in the lower right hand corner. Everything else is self explained. Flashes indicate the problem and the solution is all written. Since I have the same problem and a technician, this is a defective product GE has discontinued and re-manufactured. After phoning GE the motor # Normal 0 WH20X10051 cost $252.25 to ship to my location.
Posted on Jun 18, 2009
repairman45
  • 130 Answers
SOURCE: wont drain water in spin
You will need to pull off the drain pump to see if you have a clogg, if you do not, the drain pump has seized up and will need to be replaced, for information on how to get to the pump please reply.
If my solution was helpful please rate me.
Thanks, Repairman45
Posted on Dec 12, 2010
Won't spin out washing machine
Problems with a washing machine not spinning or not draining are often interrelated..
If you are having a problem with your top load washer then check out thistip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkoutthis tip...
Front Load Washing machine not draining and or not spinning
heatman101
Aug 14, 2011 | General Electric WBSR3000G Top Load Washer
Washer isn't spinning. Everything else seems to work.
heatman101
Aug 13, 2011 | Washing Machines
My GE washer #WDSR2080DEWW washer won't spin
heatman101
Aug 13, 2011 | GE WDSR2080D Top Load Washer
Washer will wash but won't spin or drain
heatman101
Aug 11, 2011 | Kenmore 22422 Top Load Washer
My samsung WA10R3 won't spin - it making a noise as if its trying to spin but the drum isn't turning and the water isn't coming out Thanks
heatman101
Aug 11, 2011 | Samsung Washing Machines
GE Washer will wash but won't drain?
heatman101
Jul 24, 2011 | GE Washing Machines
WASHER FILLS WITH WATER, THEN WON'T AGITATE. TURN KNOB TO SPIN AND IT DRAINS THEN SPINS. STILL WON'T AGITATE
WASHER FILLS WITH WATER, THEN WON'T AGITATE. TURN KNOB TO SPIN AND IT DRAINS THEN SPINS. STILL WON'T AGITATE please show me a diagram
Jun 14, 2011 | Whirlpool LSR7333 Top Load Washer
It won't drain, code nd. Hose isn't kinked.
Problems with a washing machine not spinning or not draining are often inter related..
If you are having a problem with your top load washer then check out this tip...
If you are having problems with your front load washing machine then checkout this tip...
heatman101
May 16, 2011 | Maytag Neptune FAV6800AW Top Load Washer
Front loader won't spin and is filled up with water. Won't drain.
heatman101
May 15, 2011 | Kenmore Energy Star 44092 Front Load...
Hi. my ge wjse3110a won.t spin unless is start spinning it first by hand
The motor is going bad...
heatman101
Sep 07, 2010 | GE WJSE3110A Top Load Washer
Washing Machines Logo
414 people viewed this question
Top Miele Washing Machines Experts
Gerry Harvey
Gerry Harvey
mpservices
Are you a Miele Washing Machine Expert? Answer questions, earn points and help others
