Question about Cycling
Pocket bike 49cc engine only stayy running with choke on most of the way
    New Friend:
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 70 Answers
Clouged air filter, clean it
Posted on Apr 05, 2014
  • 104 Answers
SOURCE: pocket bike prblems
Get some engine starting fluid and spray a small amount in the air intake. If that doesn't work take out the spark plug and see if it sparks when you pull the cord and make sure it is not fouled. If it is wet with fuel dry out the plug and pull the cord a few times to clear the cylinder. Fresh premium fuel always works best on temperamental engines.
Posted on Sep 06, 2009
  • 255 Answers
SOURCE: like to know if it takes any type of oil in clutch
Those are usually wet clutches. Just look for a filler plug. Better yet, your local bike shop will tell you exactly what will be needed (and they would be glad to sell you the correct oil too!)
Posted on Nov 25, 2009
  • 10 Answers
SOURCE: what does the Ignition Coil for a 49cc 2 stroke pocket bike gap a
6mm-8mm.
Posted on May 05, 2010
SOURCE: my 49cc pocket bike starts but wont stay on when i
That problem has happened to me to and i just ajusted the needle on the side becuase it was too rich or the breather on the gas tank sometimes that gets fratured and the gas fumes cant get out right
Posted on May 15, 2010
PWCYoda
  • 118 Answers
SOURCE: pocket bike starts with starting fluid but then
Did u put oil on the air filter? if thats ok then it sounds like you have a clogged pilot jet in the carb, pull the float bowl and remove jets then poke thru with fine wires untill clean. also take note of air mixture screw which will be located around the opening of the carb. clockwise will richen it up and start to make the idle drop and counter clockwise will do the opposite.
Posted on Aug 20, 2010
I need to know the size of the center hole on a 19 tooth transmission sprocket for an apc mini chopper Thanks
Why do you need to know the size of the centre hole. That one look in great condition. The size is the size of the shaft it fits on, so you measure the narrower distance, which is between the sprocket tooth that is under the middle of your thumb nail, to the second tooth past your index finger. All this links have info.
  • mini chopper sprockets ' eBay www.ebay.com > Search > mini chopper sprockets Refine your search for mini chopper sprockets. ... Mini Chopper Pocket Bike Parts 19 Tooth Front ... 28 Teeth Rear Driven Sprocket L for #410 Chain APC Mini Chopper ...
  • mini chopper sprocket in Parts & Accessories ' eBay www.ebay.com > Search > mini chopper sprocket Find mini chopper sprocket from a vast selection of ... Mini Chopper Pocket Bike Parts 19 Tooth Front Chain Sprocket ... APC MINI CHOPPER 48" THROTTLE CABLE ...
  • I need to know the size of the center hole on a 19 tooth ... www.fixya.com > Forum > Motorcycles > APC ... a 19 tooth transmission sprocket for an apc mini ... on a 19 tooth transmission sprocket for an apc ... rear 28 tooth sprocket for an apc mini chopper.I ...
  • Mini Chopper Sprocket and Clutch - DIY Go Karts www.diygokarts.com/chopper-plans/drive-assembly.html ... a torque converter can be used which effectively gives the project an automatic transmission. ... mini-chopper's clutch ... tooth #35 pitch. This size sprocket ...
  • mini chopper parts ' eBay www.ebay.ca > Search > mini chopper parts mini chopper parts 352 listings. ... 28 Teeth Rear Driven Sprocket L for #410 Chain APC Mini Chopper ... #428 Chain 17 Tooth 14mm Pitch Sprocket Part Gear Go Kart ...
  • Sprockets - PartsForScooters www.partsforscooters.com/Pocket-Bikes-Parts/Pocket-Bikes-Sprocket Mini-Chopper Parts; ... 127-19 . Stock 6 Tooth Front Sprocket with M10x1.00 thread size for 47 and 49cc 2-stroke cag style pocket bikes and mini-quads.
  • Mini Chopper Parts ' Mini Bike Parts ' We Ship https://www.gokartsupply.com/chopper.htm Home >> Parts Catalog> Mini-Chopper Parts. Parts For Mini Choppers Seats - Hand Controls - Fenders. ... SPROCKET 60T #35. 7-1/4" 28.50. 04-470. SPROCKET 72T ...
  • Electra / APC Mini Chopper w 49cc PS engine - Pocket Bike ... www.pocketbikeplanet.com/showthread.php?t=84442
    • 20 POSTS
    • FIRST POST: 2014-06-29
    2014-07-26 · Electra / APC Mini Chopper w 49cc PS engine Mini Choppers. ... Sounds like you got a transmission with slag on the internal gears ... do a search as mini chopper parts.
  • mini chopper bike ' eBay www.ebay.ca > Search > mini chopper bike Find great deals on eBay for mini chopper bike and ... 43CC 49CC APC MINI CHOPPER MINI BIKE MONKEY ... 17 tooth sprocket gear Pocket Bike Mini Chopper ...
  • Rawge's Mini Chopper Information Site - Gearing and Sprockets www.rawge.bravepages.com/minichoppers/speedo.htm Rawge's Mini Choppers ... The Simple Mini Chopper Drive ... you can expect from your mini chopper, given the size of the sprocket on your ...
  • Pagination
  • Apr 08, 2016 | APC Motorcycles
    I have a quibo 49cc pocket bike it runs good but will not idle
    you need to open the screw on the carberator prolly a 1/4 turn
    Jun 30, 2014 | Quad 47 cc / 49 cc Pocket Mini Bike...
    Wheres the choke on a 49cc pocket rocket
    The choke is on the carb. Check if the carb set screw is set right, turn it all the way in and then back out 1 1/4 turns. then fine tune by 1/4 turn increments.
    Feb 02, 2012 | Quad 47 cc / 49 cc Pocket Mini Bike...
    My pocket bike wont stay running
    Adjust the air screw and idle screw situated on carby.
    Mar 12, 2011 | RTO 47cc / 49cc Pocket Dirt Bike Atv...
    Does the coil have to grounded to the engine block or just the engine bolted to frame ok for 47 cc pocket bike
    coil needs to be grounded and make sure theres no paint at mounting points of motor to frame
    Feb 22, 2011 | RTO 47cc / 49cc Pocket Dirt Bike Atv...
    Pocket bike starts with starting fluid but then even after its warm it wont start on its own, and when its running the idol is higher with the choke on, the bike almost wants to take off, if I turn the...
    Aug 20, 2010 | RTO 47cc / 49cc Pocket Dirt Bike Atv...
    Pocket bike prblems
    Sep 06, 2009 | Quad 47 cc / 49 cc Pocket Mini Bike...
    49cc 2 stroke engine
    I have a 49cc cateye mini bike it starts idles fina dn every thing but when you ride it it goes fine i can reach around 55 almost 60 with the stock engine but it seems to quit on my after about 15 mabey a little less sometimes and then will not start for about another half hour
    Jun 18, 2008 | 1997 Acura CL
    Cycling Logo
    49 people viewed this question
    Top Cycling Experts
    John Egan
    John Egan
    Are you a Cycling Expert? Answer questions, earn points and help others
