Question about Brookstone U-control Silver Bullet Rc Helicopter Easy To Fly Indoors
Brookstone silver bullet helicopter does not fly it just sits on the floor with the blades spinning
My brookstone silver bullet helicopter will not fly. The blades spin but it has no lift. If you move the forward control it will move across the floor but will not lift off.
There aren't green light in charger
Search Results
    How To Fix Your RC Helicopter - YouTube
    ? 4:22
    https://www.youtube.com/watch?v=R65JJYwSH50
    Jun 28, 2010 - Uploaded by R/C 101
    Does your RC helicopter spin out of control in the air or ... thing that the video says but there nothing wrong about it the remote is fine but the propeller .... i have a brookstone RC stunt copter that i have not used in a few months. i .... however when I come to fly it, it makes a sound but the wings aren't working.
    All comments on How To Fix Your RC Helicopter - YouTube
    https://www.youtube.com/all_comments?v=R65JJYwSH50
    where can I buy new gears and pinions for my mini rc helicopter?. Read more Show.... The two pins on the charger port aren't working they won't charge ..... The charging light is off meaning the battery is charged. Any ideas? ..... So, the motor spins the correct way but there is no gear to transfer the power to the rotors 'A'.Missing: silver ‎bullet
    rc helicopter light flashing Remote Controls Questions
Jan 19, 2016 | Brookstone Rc Mini Helicopter Silver...
Helicopter is not getting charged
1) test the contacts and clean it very well +adjust it
2) if after cleaning the problem remain, the power supply inside is faulty. some capacitor, diode, or resistence is faulty. Repair
God bless you
Jan 25, 2013 | Brookstone U-control Silver Bullet Rc...
A brook stone RC silver bullet helicopter. Quite a bit of hair got in it so I cleaned the hair out and took it apart to see if I could find anything obviously wrong, I only took the plastic shell off
What your witnessing is that the blades are not catching on the spindle, normal function locks the central unit to that silver shaft that drives the blades. There is not enough friction driving them so they just lazily spin like that. There should be a secondary coupling link that helps engage the blades for flight please refer to the manufacturing specifications.
Source: http://www.brookstone.com/static/customerService.jsp?panelId=100011
Oct 15, 2012 | Toys
The bottom blade's of my brookstone silver bullet helicopter keep's on hitting the tail of it.
One of the weights on the rotor has fallen off. There should be a silver weight on each end of the top skinny rotor
Jan 17, 2011 | Toys
I have Brookstones silver bullet u control helicopter and have a problem. I crashed it, and when I went to fly it again it seems like the bottom blade is hit off the tail of the helicopter. Do I just...
Sometimes the metal weights fall out of the top rotating bar causing the blades to be out of balance and the bottom blade to hit the tail. Check to see if both the weights are in the top bar.
Dec 27, 2010 | Shuttle 9094 Emax Remote Control...
My rc helicopter can not fly it spin in floor
Hi
This type of helicopter uses a fixed pitch blade. Have you recently replaced one or all the blades? If the blades are correctly positioned then once the motor comes to speed, the pitch of the blade creates enough lift to overcome the force of gravity. The problem you're having can only be that the motor is not coming to speed or the blades have been replaced but the pitch is now at the wrong angle.
May 11, 2010 | RC New 3 Ch Co-Comanche RAH-66 Helicopter
Brookstone U-control Silver Bullet Rc Helicopter Easy To Fly Indoors Logo
35 people viewed this question
Top Brookstone Televison & Video Experts
L Pfaff
L Pfaff
danoyachtcap
danoyachtcap
Are you a Brookstone Televison and Video Expert? Answer questions, earn points and help others
