Question about NetGear Computers & Internet
Need a 5th CAT5 output from my router
My netgeat router has five outputs but now I want to hook a 5th computer into the router. Is there a solution other than an expensive Cat-5 distribution amp of a wireless card for my 5th desktop?
  • NetGear Master
  • 3,320 Answers
Buy a switch
Posted on Apr 02, 2014
cyrylthewolf
  • 143 Answers
SOURCE: hookup with Vonage device
I am going to attempt to give you a solution here. But you must understand a few things before I begin.
First, I would like to clarify that if you have Time Warner internet service, you are on Cable Internet. Not DSL. (This makes a world of difference when it comes to using a router.)
Secondly, you did not specify model numbers of your devices. Therefore I am assuming that you are using the following devices:
If this is not the correct equipment, continue to follow the instructions but be dynamic and adapt my instructions to the equipment you have. It should be similar enough that you shouldn't have any problem easily doing this.
This instruction set is going to begin from a point that is assuming that we're installing all of this equipment from the standpoint of a completely new installation. From the ground up.
Let's begin.
UNPLUG AND POWER DOWN ALL OF YOUR EQUIPMENT INCLUDING THE CABLE MODEM, ROUTER, PC AND VONAGE BOX. Do not power on any of the devices until instructed to do so.
1.) Connect your cable modem to the cable from the wall.
2.) Find the ethernet port on your cable modem. Connect the blue ethernet (CAT5) cable to the ethernet port.
3.) Plug the other end of the blue ethernet cable into the "Internet" port of the router. (Older routers used to also call this a "WAN" port.) It is the only port that is seperated from the rest of them.
4.) Connect another ethernet cable to port 1 of the router.
5.) Connect the other end of the ethernet cable to the network port of your PC.
6.) Connect yet another ethernet cable to port 2 of the router.
7.) Connect the other end of this ethernet cable to the ethernet port of the Vonage box.
8.) Plug in the power adapter of the cable modem. Wait 1 minute for the cable modem to acquire it's signal and set up the connection to Time Warner.
9.) Plug in the power adapter of the Linksys router. It should only take 15-20 seconds to set itself up. (If you have made any configurations to the router prior to this, I recommend pressing and holding the RESET button for at least 10 seconds to give you a fresh configuration state to start with.)
10.) Plug in the power adapter to the Linksys PAP2 VOIP Phone Adapter.
11.) Power on your PC. You should have an internet connection with it.
You see... As I read the configuration you described, I don't think that you're using a PAP2 phone adapter. You said that you connected the "vonage device" to both your modem and your PC. This is not possible with the PAP2 adapter as it only has ONE ethernet port.
I am led to believe that you are actually using the Linksys WRTP54G which is essentially the same thing as the WRT54G, but with Vonage support built-in.
If that is the case, then you will not need to use the WRT54G router. Instead, follow the instructions that I gave you assuming that the router and the phone device are combined into one device. (The ports will still be labeled the same.)
Download the installation guide for the WRTP54G from the product page link I just gave you. You'll find the link to the User Guide on the right-side panel. This will make everything clearer for you if you do indeed have that router instead of the PAP2 phone adapter.
If you continue to be confused, please let me know. DO NOT just give me a poor rating without asking more questions. I am here to help you solve your issue. Not have my rating decreased just because someone is too confused or lazy to ask more questions.
I'm happy to help you. :)
Good luck and let me know what the outcome is. (And please be sure to list your exact model numbers in the future!)
Cyryl
Posted on Nov 11, 2007
SOURCE: Connecting DLink thru Comcast Cable Modem and Vonage box
i have comcast wifi and i cannot set up vp eye to eye. i try to make phone call and get message says the phone number i call is unregistered. pls help me! thanks. my email is deafjrt@aol.com
Posted on Sep 17, 2008
  • 116 Answers
SOURCE: status light not on
upgrade the firmware
Posted on Jan 11, 2009
  • 13 Answers
SOURCE: Bright house modem and desktop
Connect the lan cable from the dsl modem into the first port on your netgear router ..
make sure your dsl modem is on PPPoE mode so that it autoconnects..
Now just connect to your wireless router via your pc interface..
*Do add a network key to your wireless network to avoid unwanted access
Posted on Jan 19, 2009
cnavarro
  • 2460 Answers
SOURCE: How to get wi fi at home for itouch?
Your better bet is a wireless access point. It plugs into your router and can be configured to be transparent to the network so that any IP address you get for your wireless device comes from the original router (better for networking).
At the blinkingly fast speeds of your Wireless internet, "N" is a waste. Get the "G". Here's a link to the product I would use...it runs about $50. http://www.tplink.com/products/product_des.asp?id=116
Carl
Posted on Feb 27, 2009
How to hook up earthlink dsl
can you connect screen I see in right side of your photo to vga output on laptop and use FN + F5 to switch windows output to secondary VGA device. IPad should connect to Wi Fi but not to Laptop.
Is the router wi fi if it is not plug laptop into ethernet port via cat5 ethernet cable . Do you have a DSL modem you need one to hook up DSL and then Ethernet cable to Router. Also DSL filters are needed on Phones or faxes .
Apr 19, 2014 | Computers & Internet
I've used a Netgear DG834GT with no problems, but when the wireless part stopped working, I've changed to a DGN1000. The original router will still work when connected to my PC, but the new one says I need...
If you change formats to Ethernet on the Netgear, simply run the CAT5/6 wire from the Cat output on the modem to the Ethernet port on the computer. A direct connection should always be AUTOMATIC as long as the operating system DRIVERS are up-to-date.
Feb 06, 2018 | NetGear N150 / RANGEMAX 150 Router
Can you remind me how you connect a router to the modem to the computer?
Output from the modem .. CAT5 from WAN port into
WAN port on back of Router
CAT5 from ethernet port ( netport card) on back of PC into any open port on back of router. Power up router and allow to finish booting
Power up PC
Jan 06, 2011 | Belkin (F5D5231-4) Router
How to set up this router
Plug in a CAT5 Ethernet cable onto your computer and then into one of the output ports on the router. Make sure it is the output port and not the one that goes to the cable or DSL modem. Power up the computer and then power up the router. Open your browser and type this IP number into the location bar
http://192.168.1.1
that will open up the router. The default password is "admin" if it has been changed and you don't know what it is, you will have to push and hold the reset button on the router for 30 seconds. That will reset it to the factory defaults. Open your browser and try again. Once you are in, then follow the instructions and helps. Also take a look at this web page.
http://www.tech-faq.com/how-to-setup-a-linksys-router.html
Nov 18, 2010 | Linksys WRT54GC Compact Wireless-G...
Central home network
(add small 4 port hub) from cable router out to hub port 1.-take cat5 from central insert in port 2 of hub.- insert cat5 in port 3 of hub then other end in now open cat5 port
Jan 03, 2010 | CommScope 1000 FT RG6 QUAD/CAT - 5E 4 -...
I can't hook up my PC with my wireless router how I can do this?
You could simply hardwire your computer directly to your router, unless you want to purchase a Wireless Card or USB. You will still need a computer connected to your Wireless router to act as a terminal to edit and set the settings on the router. Most regular routers use CAT5 (Ethernet) cord to setup their networks, which is what you should use.
Go to your local store and purchase 2 CAT5 Cables to connect one from your modem into your router and one from your router to your PC. Once you have set up your wireless router you can then access your router from anywhere in your house.
Good luck, if you need help feel free to comment.
Thanks,
Brandonmxb
Dec 14, 2009 | Linksys WRT160N Wireless Router
How do i hook this router up wpn824v2
Your router is connected between your modem (Cable or DSL) and your computer. Connect the modem output to the WAN or Internet connector on your router. Connect any of the output connectors to your computer's Network Input. Log in to the router by (with your Browser) going to 192.168.1.1 ... after logging to router (login parameters in manual) set your Network Name (SSID) and set up Wireless security. I prefer using WPS-PSK[TKIP] for its ease of setup.
Nov 11, 2009 | NetGear RangeMax WPN824 Router
How do i hook up a router
Let's proceed first with the physical connectivity. Please follow the steps below:
1. Make sure that your computer is working when directly connected to the modem.
2. Connect the CAT5 cable of your modem to the WAN port of your GWA504.
3. You should have another CAT5 cable. That CAT5 cable will be connected to any one of the LAN ports on the back of that router.
4. Connect the other end of the CAT5 cable to the network card of your computer.
5. After the physical connection, just let me know and we will proceed with the next steps. Because your statement is very broad. We have to consider lots of things here. Please reply so that I could further assist you.
Mar 27, 2009 | IOGear GWA504 Router
Set up
No. You do not need to have a computer connected via a CAT5 (Ethernet) cable to the router for a laptop to access the wireless signal.
However, to set up the router to broadcast that wireless signal or to alter some of the wireless security settings you will have to connect directly to the router with a CAT5 (Ethernet) cable.
If you need assistance connecting to that wireless connection, let me know. I have some instructions which can help retrieve the security information from the router so you can connect to the Internet via the wireless signal.
Mar 20, 2009 | Belkin (F5D7230-4) Router (587009)
How do you hook up your netgear wireless router to your clear wire modem?
Hi Leon,
have alook at Clearwire's webpage (here), where they describe different setups for your router.
I personally would always prefer to connect the modem to the router via a cable. The cable you will need is an Ethernet (CAT5) cable and the connectors at the end look like this (compared to a phone cable:
You will connect the output of your modem with the WAN port of your router. This port is usually separated form the 4 other LAN ports, which connect to your computers, printers, etc.
(You didn't specify which router model you have, so I can't give you more details, but it should be very obvious, when you look at the back of your router.)
For the initial setup of your router, you should use a second Ethernet cable connected to one of the LAN ports of the router and to the Ethernet port of your computer.
If you need help with the wireless setup of your router, you have to look either in your manual of give me the details of your router (like the model and version, i.e. Netgear WGR614) and I'm happy to assist you.
Feb 25, 2009 | NetGear WIRELESS-G WGR614 802.11G WIRELESS...
Computers & Internet Logo
32 people viewed this question
Top NetGear Computers & Internet Experts
Prashant M
Prashant M
Are you a NetGear Computer and Internet Expert? Answer questions, earn points and help others
